i've tried both options, with on command and with script_device. Both with same results. The script only runs one time.
I've enebled the full logging.
Here's the log.
I've set the switch to on @11:08:55.058 and the script ran. then i've activated the switch again @11:10:03.471 and nothing happend. Then i've stopped the service.
2018-05-31 11:08:27.396 RxQueue: queue worker started...
2018-05-31 11:08:29.397 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SecStatus')
2018-05-31 11:08:29.397 SQLR result: 0;;
2018-05-31 11:08:29.398 EventSystem: reset all events...
2018-05-31 11:08:29.398 SQLQ query : SELECT EventRules.ID, EventMaster.Name, EventRules.Conditions, EventRules.Actions, EventMaster.Status, EventRules.SequenceNo, EventMaster.Interpreter, EventMaster.Type FROM EventRules INNER JOIN EventMaster ON EventRules.EMID = EventMaster.ID ORDER BY EventRules.ID
2018-05-31 11:08:29.399 SQLQ query : SELECT ID, Name, Interpreter, Type, Status, XMLStatement FROM EventMaster WHERE Interpreter <> 'Blockly' AND Status > 0 ORDER BY ID
2018-05-31 11:08:29.399 SQLR result: 1;phidget;Python;Device;1;import sys
sys.path.append('/usr/local/lib/python3.4/dist-packages')
import time
from Phidget22.Devices.VoltageOutput import *
from Phidget22.PhidgetException import *
from Phidget22.Phidget import *
from Phidget22.Net import *
try:
ch = VoltageOutput()
except RuntimeError as e:
print("Runtime Exception %s" % e.details)
print("Press Enter to Exit...\n")
readin = sys.stdin.read(1)
exit(1)
def VoltageOutputAttached(self):
try:
attached = self
print("\nAttach Event Detected (Information Below)")
print("===========================================")
print("Library Version: %s" % attached.getLibraryVersion())
print("Serial Number: %d" % attached.getDeviceSerialNumber())
print("Channel: %d" % attached.getChannel())
print("Channel Class: %s" % attached.getChannelClass())
print("Channel Name: %s" % attached.getChannelName())
print("Device ID: %d" % attached.getDeviceID())
print("Device Version: %d" % attached.getDeviceVersion())
print("Device Name: %s" % attached.getDeviceName())
print("Device Class: %d" % attached.getDeviceClass())
print("\n")
except PhidgetException as e:
print("Phidget Exception %i: %s" % (e.code, e.details))
exit(1)
def VoltageOutputDetached(self):
detached = self
try:
print("\nDetach event on Port %d Channel %d" % (detached.getHubPort(), detached.getChannel()))
exit(1)
def ErrorEvent(self, eCode, description):
print("Error %i : %s" % (eCode, description))
try:
ch.setOnAttachHandler(VoltageOutputAttached)
ch.setOnDetachHandler(VoltageOutputDetached)
ch.setOnErrorHandler(ErrorEvent)
# Please review the Phidget22 channel matching documentation for details on the device
# and class architecture of Phidget22, and how channels are matched to device features.
# Specifies the serial number of the device to attach to.
# For VINT devices, this is the hub serial number.
# The default is any device.
# ch.setDeviceSerialNumber(<YOUR DEVICE SERIAL NUMBER>)
# For VINT devices, this specifies the port the VINT device must be plugged into.
# The default is any port.
# ch.setHubPort(0)
# Specifies which channel to attach to. It is important that the channel of
# the device is the same class as the channel that is being opened.
# The default is any channel.
# ch.setChannel(0)
# In order to attach to a network Phidget, the program must connect to a Phidget22 Network Server.
# In a normal environment this can be done automatically by enabling server discovery, which
# will cause the client to discovery and connect to available servers.
# To force the channel to only match a network Phidget, set remote to 1.
Net.enableServerDiscovery(PhidgetServerType.PHIDGETSERVER_DEVICEREMOTE);
# ch.setIsRemote(1)
print("Waiting for the Phidget VoltageOutput Object to be attached...")
ch.openWaitForAttachment(5000)
exit(1)
if(ch.getDeviceID() == DeviceID.PHIDID_1002):
ch.setVoltage(0)
ch.setEnabled(1)
print("Setting Voltage to 4 for 5 seconds...\n")
ch.setVoltage(4)
time.sleep(5)
print("Setting Voltage to 1.5 for 5 seconds...\n")
ch.setVoltage(1.5)
time.sleep(5)
print("Setting Voltage to 0 for 5 seconds...\n")
ch.setVoltage(0)
time.sleep(5)
try:
ch.close()
exit(1)
print("Closed VoltageOutput device");
2018-05-31 11:08:29.399 EventSystem: reset all device statuses...
2018-05-31 11:08:29.400 SQLQ query : SELECT A.HardwareID, A.ID, A.Name, A.nValue, A.sValue, A.Type, A.SubType, A.SwitchType, A.LastUpdate, A.LastLevel, A.Options, A.Description, A.BatteryLevel, A.SignalLevel, A.Unit, A.DeviceID FROM DeviceStatus AS A, Hardware AS B WHERE (A.Used = '1') AND (B.ID == A.HardwareID) AND (B.Enabled == 1)
2018-05-31 11:08:29.400 SQLR result: 2;1;TestSwitch;0;0;244;73;0;2018-05-31 10:58:02;0;;;255;12;1;00014051;
2018-05-31 11:08:29.400 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:08:29.401 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:29.401 SQLR result: 60;;
2018-05-31 11:08:29.401 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:29.401 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:29.401 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:29.402 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used, A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) WHERE (A.ID=='1')
2018-05-31 11:08:29.402 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 10:58:02;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:29.403 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:29.403 SQLR result: 0;
2018-05-31 11:08:29.403 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:29.403 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:08:29.404 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:08:29.404 SQLQ query : SELECT ID, Name, nValue, SceneType, LastUpdate FROM Scenes
2018-05-31 11:08:29.405 SQLQ query : SELECT ID,Name,Value, ValueType, LastUpdate FROM UserVariables
2018-05-31 11:08:29.537 Python EventSystem: Initalizing event module.
2018-05-31 11:08:29.537 EventSystem: Queue thread started...
2018-05-31 11:08:29.537 EventSystem: Started
2018-05-31 11:08:29.739 PluginSystem: Entering work loop.
2018-05-31 11:08:30.423 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757083
2018-05-31 11:08:30.424 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:08:30.424 SQLR result: 1;;
2018-05-31 11:08:30.424 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:30.424 SQLR result: 60;;
2018-05-31 11:08:30.425 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:30.425 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:30.425 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:30.425 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:30.426 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:08:30.426 SQLR result: 1;
2018-05-31 11:08:30.426 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:08:30.427 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:30.427 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 10:58:02;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:30.428 Incoming connection from: 127.0.0.1
2018-05-31 11:08:30.429 SQLQ query : SELECT SessionID, Username, AuthToken, ExpirationDate FROM UserSessions WHERE SessionID = '204115dc7ef673d240d4a659ece807ab'
2018-05-31 11:08:30.430 SQLQ query : INSERT INTO UserSessions (SessionID, Username, AuthToken, ExpirationDate, RemoteHost) VALUES ('204115dc7ef673d240d4a659ece807ab', '', '30d62c253bf83345542bf5fcbda47959', '2018-05-31 11:18:30', '127.0.0.1')
2018-05-31 11:08:39.397 WEBH : Host:127.0.0.1 Uri;/html5.appcache
2018-05-31 11:08:39.399 SQLQ query : SELECT sValue FROM Preferences WHERE (Key='WebTheme')
2018-05-31 11:08:39.399 SQLR result: default;
2018-05-31 11:08:39.446 SQLQ query : SELECT ID FROM Floorplans ORDER BY [Order]
2018-05-31 11:08:42.160 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=getconfig
2018-05-31 11:08:42.160 WEBS GetJSon :getconfig :/json.htm?type=command¶m=getconfig
2018-05-31 11:08:42.161 SQLQ query : SELECT sValue FROM Preferences WHERE (Key='Language')
2018-05-31 11:08:42.161 SQLR result: en;
2018-05-31 11:08:42.161 SQLQ query : SELECT sValue FROM Preferences WHERE (Key='DegreeDaysBaseTemperature')
2018-05-31 11:08:42.161 SQLR result: 18.0;
2018-05-31 11:08:42.161 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='DashboardType')
2018-05-31 11:08:42.161 SQLR result: 0;;
2018-05-31 11:08:42.161 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='MobileType')
2018-05-31 11:08:42.161 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='5MinuteHistoryDays')
2018-05-31 11:08:42.161 SQLR result: 1;;
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='ShowUpdateEffect')
2018-05-31 11:08:42.162 SQLR result: 0;;
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='Location')
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabFloorplans')
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabLights')
2018-05-31 11:08:42.162 SQLR result: 1;;
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabScenes')
2018-05-31 11:08:42.162 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabTemp')
2018-05-31 11:08:42.163 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabWeather')
2018-05-31 11:08:42.163 SQLR result: 1;;
2018-05-31 11:08:42.163 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabUtility')
2018-05-31 11:08:42.163 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EnableTabCustom')
2018-05-31 11:08:42.246 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=getversion
2018-05-31 11:08:42.246 WEBS GetJSon :getversion :/json.htm?type=command¶m=getversion
2018-05-31 11:08:42.246 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='UseAutoUpdate')
2018-05-31 11:08:42.246 SQLR result: 1;;
2018-05-31 11:08:42.247 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='ReleaseChannel')
2018-05-31 11:08:42.247 SQLR result: 0;;
2018-05-31 11:08:42.573 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=getauth
2018-05-31 11:08:42.573 WEBS GetJSon :getauth :/json.htm?type=command¶m=getauth
2018-05-31 11:08:43.407 WEBH : Host:127.0.0.1 Uri;/json.htm?type=plans
2018-05-31 11:08:43.407 SQLQ query : SELECT ID, Name, [Order] FROM Plans ORDER BY [Order]
2018-05-31 11:08:43.407 SQLR result: 1;$Hidden Devices;1;
2018-05-31 11:08:43.421 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0
2018-05-31 11:08:43.421 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:08:43.421 SQLR result: 1;;
2018-05-31 11:08:43.421 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:43.421 SQLR result: 60;;
2018-05-31 11:08:43.421 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:43.421 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:43.421 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:43.422 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:43.422 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:08:43.422 SQLR result: 1;
2018-05-31 11:08:43.422 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:08:43.422 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:43.422 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 10:58:02;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:43.423 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:43.423 SQLR result: 0;
2018-05-31 11:08:43.423 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:43.423 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:08:43.423 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:08:43.522 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=getSunRiseSet
2018-05-31 11:08:43.522 WEBS GetJSon :getSunRiseSet :/json.htm?type=command¶m=getSunRiseSet
2018-05-31 11:08:53.558 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757723
2018-05-31 11:08:53.559 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:08:53.560 SQLR result: 1;;
2018-05-31 11:08:53.560 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:53.560 SQLR result: 60;;
2018-05-31 11:08:53.561 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:53.561 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:53.561 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:53.562 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:53.562 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:08:53.562 SQLR result: 1;
2018-05-31 11:08:53.562 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:08:53.563 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:53.564 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 10:58:02;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:55.058 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On&level=0&passcode=
2018-05-31 11:08:55.058 WEBS GetJSon :switchlight :/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On&level=0&passcode=
2018-05-31 11:08:55.058 WEBS switchlight idx:1 switchcmd:On level:-1
2018-05-31 11:08:55.058 SQLQ query : SELECT [Protected],[Name] FROM DeviceStatus WHERE (ID = '1')
2018-05-31 11:08:55.058 SQLR result: 0;TestSwitch;
2018-05-31 11:08:55.058 User: Admin initiated a switch command (1/TestSwitch/On)
2018-05-31 11:08:55.058 MAIN SwitchLight idx:1 cmd:On lvl:-1
2018-05-31 11:08:55.058 SQLQ query : SELECT HardwareID,DeviceID,Unit,Type,SubType,SwitchType,AddjValue2,nValue,sValue,Name,Options FROM DeviceStatus WHERE (ID == 1)
2018-05-31 11:08:55.058 SQLR result: 2;00014051;1;244;73;0;0.0;0;0;TestSwitch;;
2018-05-31 11:08:55.058 MAIN SwitchLightInt : switchcmd:On level:-1 HWid:2 sd:2 00014051 1 244 73 0
2018-05-31 11:08:55.059 SQLQ query : SELECT LastLevel FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:08:55.059 SQLR result: 0;
2018-05-31 11:08:55.059 MAIN SwitchLightInt : switchcmd=="On" || level < 0, new level:0
2018-05-31 11:08:55.059 MAIN ProcessRX Msg 1BF44900514001000100000001000CFF000000000000000000000000
2018-05-31 11:08:55.059 SQLQ query : SELECT ID,Name, Used, SwitchType, nValue, sValue, LastUpdate, Options FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:08:55.059 SQLR result: 1;TestSwitch;1;0;0;0;2018-05-31 10:58:02;;
2018-05-31 11:08:55.059 SQLQ query : UPDATE DeviceStatus SET SignalLevel=12, BatteryLevel=255, nValue=1, sValue='0', LastUpdate='2018-05-31 11:08:55' WHERE (ID = 1)
2018-05-31 11:08:55.060 SQLQ query : INSERT INTO LightingLog (DeviceRowID, nValue, sValue) VALUES ('1', '1', '0')
2018-05-31 11:08:55.060 SQLQ query : SELECT Name,SwitchType,AddjValue,StrParam1,StrParam2,Options,LastLevel FROM DeviceStatus WHERE (ID = 1)
2018-05-31 11:08:55.060 SQLR result: TestSwitch;0;0.0;;;;0;
2018-05-31 11:08:55.060 RFXN : GetLightStatus Typ:244 STyp:73 nVal:1 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:On
2018-05-31 11:08:55.060 SQLH HandleOnOffAction: OnAction:
2018-05-31 11:08:55.060 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EmailServer')
2018-05-31 11:08:55.060 SQLQ query : SELECT SceneRowID FROM SceneDevices WHERE (DeviceRowID == 1)
2018-05-31 11:08:55.060 SQLH UpdateValueInt TestSwitch HwID:2 DevID:00014051 Type:244 sType:73 nValue:1 sValue:0
2018-05-31 11:08:55.060 SQLQ query : SELECT ID, SwitchType, LastUpdate, LastLevel, Options FROM DeviceStatus WHERE (Name == 'TestSwitch')
2018-05-31 11:08:55.061 SQLR result: 1;0;2018-05-31 11:08:55;0;;
2018-05-31 11:08:55.061 RFXN : GetLightStatus Typ:244 STyp:73 nVal:1 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:On
2018-05-31 11:08:55.061 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:55.061 SQLR result: 60;;
2018-05-31 11:08:55.061 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:55.061 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:55.061 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:55.061 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used, A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) WHERE (A.ID=='1')
2018-05-31 11:08:55.061 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:55.062 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:55.062 SQLR result: 0;
2018-05-31 11:08:55.062 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:55.062 RFXN : GetLightStatus Typ:244 STyp:73 nVal:1 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:On
2018-05-31 11:08:55.062 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:08:55.063 SQLQ query : SELECT ID FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:08:55.063 SQLR result: 1;
2018-05-31 11:08:55.063 SQLQ query : SELECT A.ParentID, B.Name, B.HardwareID, B.[Type], B.[SubType], B.Unit FROM LightSubDevices as A, DeviceStatus as B WHERE (A.DeviceRowID=='1') AND (A.DeviceRowID!=A.ParentID) AND (B.[ID] == A.ParentID)
2018-05-31 11:08:55.063 SQLQ query : SELECT a.DeviceRowID, b.Type FROM LightSubDevices a, DeviceStatus b WHERE (a.ParentID=='1') AND (b.ID == a.DeviceRowID) AND (a.DeviceRowID!=a.ParentID)
2018-05-31 11:08:55.063 SQLQ query : SELECT ID, Activators, SceneType FROM Scenes WHERE (Activators!='')
2018-05-31 11:08:55.063 (Dummy) Light/Switch (TestSwitch)
2018-05-31 11:08:56.084 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757723
2018-05-31 11:08:56.085 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:08:56.085 SQLR result: 1;;
2018-05-31 11:08:56.086 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:08:56.086 SQLR result: 60;;
2018-05-31 11:08:56.086 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:08:56.086 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:08:56.086 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:08:56.087 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:56.087 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:08:56.087 SQLR result: 1;
2018-05-31 11:08:56.088 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:08:56.089 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:08:56.089 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:08:56.090 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:56.090 SQLR result: 0;
2018-05-31 11:08:56.090 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:08:56.090 RFXN : GetLightStatus Typ:244 STyp:73 nVal:1 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:On
2018-05-31 11:08:56.091 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:09:00.400 SQLQ query : SELECT ID FROM Timers WHERE (Type == 5 AND ((Date < '2018-05-31') OR (Date == '2018-05-31' AND Time < '11:09')))
2018-05-31 11:09:00.400 SQLQ query : SELECT ID FROM SceneTimers WHERE (Type == 5 AND ((Date < '2018-05-31') OR (Date == '2018-05-31' AND Time < '11:09')))
2018-05-31 11:09:06.173 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:06.174 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:06.174 SQLR result: 1;;
2018-05-31 11:09:06.174 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:06.174 SQLR result: 60;;
2018-05-31 11:09:06.174 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:06.174 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:06.175 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:06.175 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:06.175 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:06.176 SQLR result: 1;
2018-05-31 11:09:06.176 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:06.177 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:06.177 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:09:16.200 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:16.201 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:16.201 SQLR result: 1;;
2018-05-31 11:09:16.201 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:16.201 SQLR result: 60;;
2018-05-31 11:09:16.202 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:16.202 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:16.202 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:16.202 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:16.202 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:16.203 SQLR result: 1;
2018-05-31 11:09:16.203 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:16.204 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:16.204 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:09:26.229 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:26.230 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:26.230 SQLR result: 1;;
2018-05-31 11:09:26.230 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:26.230 SQLR result: 60;;
2018-05-31 11:09:26.231 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:26.231 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:26.231 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:26.232 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:26.232 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:26.232 SQLR result: 1;
2018-05-31 11:09:26.232 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:26.234 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:26.234 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:09:27.390 SQLQ query : DELETE FROM UserSessions WHERE ExpirationDate < datetime('now', 'localtime')
2018-05-31 11:09:27.394 SQLQ query : DELETE FROM UserSessions WHERE ExpirationDate < datetime('now', 'localtime')
2018-05-31 11:09:36.253 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:36.254 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:36.254 SQLR result: 1;;
2018-05-31 11:09:36.254 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:36.254 SQLR result: 60;;
2018-05-31 11:09:36.254 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:36.254 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:36.254 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:36.255 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:36.255 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:36.255 SQLR result: 1;
2018-05-31 11:09:36.255 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:36.256 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:36.256 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:09:46.283 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:46.284 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:46.284 SQLR result: 1;;
2018-05-31 11:09:46.285 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:46.285 SQLR result: 60;;
2018-05-31 11:09:46.285 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:46.285 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:46.285 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:46.286 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:46.286 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:46.286 SQLR result: 1;
2018-05-31 11:09:46.287 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:46.288 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:46.288 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:09:56.319 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:09:56.320 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:09:56.321 SQLR result: 1;;
2018-05-31 11:09:56.321 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:09:56.322 SQLR result: 60;;
2018-05-31 11:09:56.322 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:09:56.322 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:09:56.322 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:09:56.323 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:56.324 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:09:56.324 SQLR result: 1;
2018-05-31 11:09:56.325 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:09:56.326 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:09:56.326 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;1;0;2018-05-31 11:08:55;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:10:00.407 SQLQ query : SELECT ID FROM Timers WHERE (Type == 5 AND ((Date < '2018-05-31') OR (Date == '2018-05-31' AND Time < '11:10')))
2018-05-31 11:10:00.407 SQLQ query : SELECT ID FROM SceneTimers WHERE (Type == 5 AND ((Date < '2018-05-31') OR (Date == '2018-05-31' AND Time < '11:10')))
2018-05-31 11:10:00.574 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.575 SQLR result: 60;;
2018-05-31 11:10:00.575 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=80 OR Type=81 OR Type=82 OR Type=84 OR Type=247 OR Type=87 OR Type=86 OR Type=64 OR Type=112 OR Type=253 OR Type=70 OR Type=71 OR Type=72 OR (Type=243 AND SubType=5) OR (Type=242 AND SubType=1) OR (Type=243 AND SubType=26))
2018-05-31 11:10:00.576 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.576 SQLR result: 60;;
2018-05-31 11:10:00.576 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=85)
2018-05-31 11:10:00.577 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.577 SQLR result: 60;;
2018-05-31 11:10:00.577 SQLQ query : SELECT ID,DeviceID, Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=86)
2018-05-31 11:10:00.578 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=87) OR (Type=243 AND SubType=25)
2018-05-31 11:10:00.578 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.578 SQLR result: 60;;
2018-05-31 11:10:00.579 SQLQ query : SELECT ID,Name,HardwareID,DeviceID,Unit,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=113 OR Type=251 OR Type=252 OR Type=90 OR Type=92 OR Type=249 OR Type=248 OR Type=246 OR Type=93 OR (Type=254 AND SubType=3) OR (Type=243 AND SubType=1) OR (Type=243 AND SubType=2) OR (Type=243 AND SubType=3) OR (Type=243 AND SubType=4) OR (Type=112 AND SubType=1) OR (Type=112 AND SubType=2) OR(Type=243 AND SubType=8) OR(Type=243 AND SubType=23) OR(Type=243 AND SubType=24) OR(Type=243 AND SubType=27) OR (Type=243 AND SubType=9) OR (Type=243 AND SubType=28) OR (Type=243 AND SubType=29))
2018-05-31 11:10:00.579 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.579 SQLR result: 60;;
2018-05-31 11:10:00.580 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=250 OR Type=89 OR Type=91)
2018-05-31 11:10:00.580 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.580 SQLR result: 60;;
2018-05-31 11:10:00.581 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=243 AND SubType=6) OR (Type=243 AND SubType=30) OR (Type=243 AND SubType=31)
2018-05-31 11:10:00.581 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:00.581 SQLR result: 60;;
2018-05-31 11:10:00.581 SQLQ query : SELECT ID,Type,SubType,nValue,sValue,LastUpdate FROM DeviceStatus WHERE (Type=243 AND SubType=7)
2018-05-31 11:10:00.582 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='5MinuteHistoryDays')
2018-05-31 11:10:00.582 SQLR result: 1;;
2018-05-31 11:10:00.582 SQLQ query : DELETE FROM Temperature WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.583 SQLQ query : DELETE FROM Rain WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.583 SQLQ query : DELETE FROM Wind WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.584 SQLQ query : DELETE FROM UV WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.584 SQLQ query : DELETE FROM Meter WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.585 SQLQ query : DELETE FROM MultiMeter WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.586 SQLQ query : DELETE FROM Percentage WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:00.586 SQLQ query : DELETE FROM Fan WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')
2018-05-31 11:10:03.470 WEBH : Host:127.0.0.1 Uri;/json.htm?type=command¶m=switchlight&idx=1&switchcmd=Off&level=0&passcode=
2018-05-31 11:10:03.470 WEBS GetJSon :switchlight :/json.htm?type=command¶m=switchlight&idx=1&switchcmd=Off&level=0&passcode=
2018-05-31 11:10:03.471 WEBS switchlight idx:1 switchcmd:Off level:-1
2018-05-31 11:10:03.471 SQLQ query : SELECT [Protected],[Name] FROM DeviceStatus WHERE (ID = '1')
2018-05-31 11:10:03.471 SQLR result: 0;TestSwitch;
2018-05-31 11:10:03.471 User: Admin initiated a switch command (1/TestSwitch/Off)
2018-05-31 11:10:03.471 MAIN SwitchLight idx:1 cmd:Off lvl:-1
2018-05-31 11:10:03.472 SQLQ query : SELECT HardwareID,DeviceID,Unit,Type,SubType,SwitchType,AddjValue2,nValue,sValue,Name,Options FROM DeviceStatus WHERE (ID == 1)
2018-05-31 11:10:03.472 SQLR result: 2;00014051;1;244;73;0;0.0;1;0;TestSwitch;;
2018-05-31 11:10:03.472 MAIN SwitchLightInt : switchcmd:Off level:-1 HWid:2 sd:2 00014051 1 244 73 0
2018-05-31 11:10:03.472 SQLQ query : SELECT LastLevel FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:10:03.472 SQLR result: 0;
2018-05-31 11:10:03.472 MAIN SwitchLightInt : switchcmd=="On" || level < 0, new level:0
2018-05-31 11:10:03.473 MAIN ProcessRX Msg 1BF44900514001000100000000000CFF010000000000000000000000
2018-05-31 11:10:03.473 SQLQ query : SELECT ID,Name, Used, SwitchType, nValue, sValue, LastUpdate, Options FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:10:03.473 SQLR result: 1;TestSwitch;1;0;1;0;2018-05-31 11:08:55;;
2018-05-31 11:10:03.483 SQLQ query : UPDATE DeviceStatus SET SignalLevel=12, BatteryLevel=255, nValue=0, sValue='0', LastUpdate='2018-05-31 11:10:03' WHERE (ID = 1)
2018-05-31 11:10:03.484 SQLQ query : INSERT INTO LightingLog (DeviceRowID, nValue, sValue) VALUES ('1', '0', '0')
2018-05-31 11:10:03.484 SQLQ query : SELECT Name,SwitchType,AddjValue,StrParam1,StrParam2,Options,LastLevel FROM DeviceStatus WHERE (ID = 1)
2018-05-31 11:10:03.484 SQLR result: TestSwitch;0;0.0;;;;0;
2018-05-31 11:10:03.484 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:10:03.485 SQLH HandleOnOffAction: OffAction:
2018-05-31 11:10:03.485 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='EmailServer')
2018-05-31 11:10:03.485 SQLQ query : SELECT SceneRowID FROM SceneDevices WHERE (DeviceRowID == 1)
2018-05-31 11:10:03.486 SQLH UpdateValueInt TestSwitch HwID:2 DevID:00014051 Type:244 sType:73 nValue:0 sValue:0
2018-05-31 11:10:03.486 SQLQ query : SELECT ID, SwitchType, LastUpdate, LastLevel, Options FROM DeviceStatus WHERE (Name == 'TestSwitch')
2018-05-31 11:10:03.486 SQLR result: 1;0;2018-05-31 11:10:03;0;;
2018-05-31 11:10:03.486 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:10:03.487 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:03.487 SQLR result: 60;;
2018-05-31 11:10:03.488 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:10:03.488 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:10:03.488 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:10:03.489 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used, A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) WHERE (A.ID=='1')
2018-05-31 11:10:03.489 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 11:10:03;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:10:03.490 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:10:03.491 SQLR result: 0;
2018-05-31 11:10:03.491 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:10:03.491 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:10:03.492 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:10:03.493 SQLQ query : SELECT ID FROM DeviceStatus WHERE (HardwareID=2 AND DeviceID='00014051' AND Unit=1 AND Type=244 AND SubType=73)
2018-05-31 11:10:03.493 SQLR result: 1;
2018-05-31 11:10:03.493 SQLQ query : SELECT A.ParentID, B.Name, B.HardwareID, B.[Type], B.[SubType], B.Unit FROM LightSubDevices as A, DeviceStatus as B WHERE (A.DeviceRowID=='1') AND (A.DeviceRowID!=A.ParentID) AND (B.[ID] == A.ParentID)
2018-05-31 11:10:03.494 SQLQ query : SELECT a.DeviceRowID, b.Type FROM LightSubDevices a, DeviceStatus b WHERE (a.ParentID=='1') AND (b.ID == a.DeviceRowID) AND (a.DeviceRowID!=a.ParentID)
2018-05-31 11:10:03.494 SQLQ query : SELECT ID, Activators, SceneType FROM Scenes WHERE (Activators!='')
2018-05-31 11:10:03.494 (Dummy) Light/Switch (TestSwitch)
2018-05-31 11:10:04.519 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757736
2018-05-31 11:10:04.520 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:10:04.520 SQLR result: 1;;
2018-05-31 11:10:04.520 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:04.520 SQLR result: 60;;
2018-05-31 11:10:04.520 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:10:04.521 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:10:04.521 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:10:04.521 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:04.521 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:10:04.522 SQLR result: 1;
2018-05-31 11:10:04.522 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:10:04.523 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:04.523 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 11:10:03;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:10:04.524 SQLQ query : SELECT COUNT(*) FROM Timers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:10:04.524 SQLR result: 0;
2018-05-31 11:10:04.524 SQLQ query : SELECT COUNT(*) FROM SetpointTimers WHERE (DeviceRowID==1) AND (TimerPlan==0)
2018-05-31 11:10:04.524 RFXN : GetLightStatus Typ:244 STyp:73 nVal:0 sVal:0 llvl: 0 isDim:1 maxDim:100 GrpCmd:1 lstat:Off
2018-05-31 11:10:04.524 SQLQ query : SELECT ID FROM LightSubDevices WHERE (DeviceRowID=='1')
2018-05-31 11:10:14.557 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757804
2018-05-31 11:10:14.558 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:10:14.558 SQLR result: 1;;
2018-05-31 11:10:14.559 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:14.559 SQLR result: 60;;
2018-05-31 11:10:14.560 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:10:14.560 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:10:14.560 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:10:14.561 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:14.561 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:10:14.561 SQLR result: 1;
2018-05-31 11:10:14.561 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:10:14.562 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:14.563 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 11:10:03;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:10:24.586 WEBH : Host:127.0.0.1 Uri;/json.htm?type=devices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1527757804
2018-05-31 11:10:24.588 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='HideDisabledHardwareSensors')
2018-05-31 11:10:24.588 SQLR result: 1;;
2018-05-31 11:10:24.589 SQLQ query : SELECT nValue, sValue FROM Preferences WHERE (Key='SensorTimeout')
2018-05-31 11:10:24.589 SQLR result: 60;;
2018-05-31 11:10:24.589 SQLQ query : SELECT ID, Name, Enabled, Type, Mode1, Mode2 FROM Hardware
2018-05-31 11:10:24.589 SQLR result: 1;Domoticz Internal;1;67;0;0;
2018-05-31 11:10:24.590 SQLR result: 2;Dummy;1;15;0;0;
2018-05-31 11:10:24.590 SQLQ query : SELECT A.ID, A.Name, A.nValue, A.LastUpdate, A.Favorite, A.SceneType, A.Protected, B.XOffset, B.YOffset, B.PlanID, A.Description FROM Scenes as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==1) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:24.590 SQLQ query : SELECT ID FROM Plans WHERE (Name=='$Hidden Devices')
2018-05-31 11:10:24.591 SQLR result: 1;
2018-05-31 11:10:24.591 SQLQ query : SELECT DeviceRowID FROM DeviceToPlansMap WHERE (PlanID=='1') AND (DevSceneType==0)
2018-05-31 11:10:24.592 SQLQ query : SELECT A.ID, A.DeviceID, A.Unit, A.Name, A.Used,A.Type, A.SubType, A.SignalLevel, A.BatteryLevel, A.nValue, A.sValue, A.LastUpdate, A.Favorite, A.SwitchType, A.HardwareID, A.AddjValue, A.AddjMulti, A.AddjValue2, A.AddjMulti2, A.LastLevel, A.CustomImage, A.StrParam1, A.StrParam2, A.Protected, IFNULL(B.XOffset,0), IFNULL(B.YOffset,0), IFNULL(B.PlanID,0), A.Description, A.Options, A.Color FROM DeviceStatus as A LEFT OUTER JOIN DeviceToPlansMap as B ON (B.DeviceRowID==a.ID) AND (B.DevSceneType==0) ORDER BY A.[Order],A.LastUpdate DESC
2018-05-31 11:10:24.592 SQLR result: 1;00014051;1;TestSwitch;1;244;73;12;255;0;0;2018-05-31 11:10:03;1;0;2;0.0;1.0;0.0;1.0;0;0;;;0;0;0;0;;;;
2018-05-31 11:10:28.407 Closing application!...
2018-05-31 11:10:28.407 Stopping worker...
2018-05-31 11:10:28.407 RxQueue: queue worker stopped...
2018-05-31 11:10:28.408 WebServer(HTTP) stopped
2018-05-31 11:10:28.909 WebServer(SSL) stopped
2018-05-31 11:10:29.410 TCPServer: shared server stopped
2018-05-31 11:10:29.410 Stopping all hardware...
2018-05-31 11:10:29.410 Scheduler stopped...
2018-05-31 11:10:29.563 EventSystem: Stopped...
