Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
- Target OS: -
I got this Error anyone seen it before or know what it means?
I am using 3. 5721 on RPi. I am using JSON to get node data to a webpage, if it can have something to with JSON
Re: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
Same error i got this morning, no idea what this mean?
Using vs 3.8153 domoticz
- Domoticz version: 2025.1
Me too...
2018-01-27 07:00:59.177 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
v3.8153
RPi3
v3.8153
RPi3
me to, never see this error
2018-01-30 20:24:11.381 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: ...z/scripts/dzVents/../../dzVents/runtime/EventHelpers.lua:374: attempt to concatenate field 'hardwareName' (a nil value)
2018-01-30 20:25:16.259 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-01-30 20:25:16.260 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
beta v3.8872
RPi3
beta v3.8872
RPi3
- urbaxe
- Domoticz version: 4.10311
Me to, from this morning.
2018-05-30 11:30:56.341 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:57.345 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:58.350 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:59.357 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
Have any one some information of what this is for kind of problem?
Raspberry Pi 3/v4.9700 - Tellstick DUO - Aeon Z-Stick gen5 - RaspBee - Wall mounted tablet + Imperihome - MANY switches/sensors
- Target OS: -
I didn’t remember that I have had this error before.
A few days ago it started to give me this error again and now it is gone again.
Nothing changed and no restarts of PC or software.
If more users starts to get this again it must be something with Domoticz that sends data to somewhere?
- Siewert308SW
- Domoticz version: Stable
Yep, seen it a few times on my Rpi3 loaded Domoticz.
Never understood it but also never payed attention to it as it occurs very rarely.
Also no clue on how to reproduce as i don't know the culprit.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
- Target OS: -
I am using a laptop since 6-12 months back with Debian.
So it doesn’t seem to be related to RPi
- waaren
It has something to do with webserver not being able to connect to other processes on the server. This is not bound to a specific kind of server.Flopp wrote: ↑Monday 11 June 2018 15:01 I didn’t remember that I have had this error before.
In fact if the code reaches that point it protects the server from getting locked because of an exception. If you understand c++ and low level network connection stuff it might be worthwhile for you to look into the source (webserver/connection.cpp starting at line number 89)
For me it is far too complicated to understand the details of what is going on.
- urbaxe
I switched firewall recently from ipfire to pfsense and after that the problems occurred the first time.
I'll try to disable some security features in the firewall tonight to see if that could be a problem.
I will return with results.
- urbaxe
I can not really say what caused the problem to end for me.
I did not find that the firewall would be the problem.
I switched the domoticz port from 8080 to 80 and then the problem disappeared to return again after a while. Then I switched back to 8080 and then the error message disappeared and has not returned. Did some reboots too. So I really can not say what caused my problems to end.
- urbaxe
...and now it's back
2018-06-13 08:22:22.401 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:23.403 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:24.448 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:25.498 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
- urbaxe
I found my problem and it was not on Domoticz.
The mechanism behind the problem I do not know, I just know what caused it for me.
It was HAProxy that caused all the errors in the log.
There is a parameter called "Health Check Method" on one of my backends servers pointing to Domoticz on the LAN
This was set to Basic, I changed it to http and then ended all the error messages in the Domoticz log.
I am getting this error again on version 4.10915
It happend after I switched to this methode: viewtopic.php?f=6&t=28329&p=217179&hili ... dd#p217179
of running Domoticz as a service under an other user.
A few minutes after this error Domoticz restarted without crash log and no hints to the restart in the domoticz.log.
It looks like it has something to do with my pinger.lua script.
I will remove the pinger.lua and see what happens.
2019-07-04 11:25:02.504 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection::start
2019-07-04 11:25:02.752 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2019-07-04 11:25:00.562 Status: dzVents: Info: : ------ Start external script: pinger.lua:, trigger: every 5 minutes
2019-07-04 11:25:00.586 Status: dzVents: Debug: pinger: Checking 192.168.x.xxx
2019-07-04 11:25:00.608 Status: dzVents: Debug: pinger: Checking google-public-dns-a.google.com
2019-07-04 11:25:02.162 Status: dzVents: Debug: pinger: ports defined; Checking 192.168.x.xxx for port 80
2019-07-04 11:25:02.504 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in co$
2019-07-04 11:25:02.530 Status: dzVents: Debug: pinger: ports defined; Checking 192.168.x.xxx for port 8080
2019-07-04 11:25:02.752 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in co$
2019-07-04 11:25:02.777 Status: dzVents: Debug: pinger: Checking 192.168.x.xxx
2019-07-04 11:25:02.789 Status: dzVents: Debug: pinger: Checking Diskstation
2019-07-04 11:25:02.803 Status: dzVents: Info: pinger: ------ Finished pinger.lua
After removing the pinger.lua the error has gone, but domoticz restarts every 15-30 minutes.
So back to normal setup of domoticz running as root.
