xiaomi 1080p in domoticz
remko2000
Post by remko2000 »
I have now applied the fanghack and the RTSP-feed of the xiaomi is working. I can view these in VLC. However, if I follow the wiki https://www.domoticz.com/wiki/Xiaomi_Camera for implementation in domoticz, I do not see a picture in domoticz (I do see a little blue square with a question mark in it) at test connection. However, I do not know in which way I should look for this to be solved. I finally want a photo to be sent when someone rings the doorbell.
febalci
Re: xiaomi 1080p in domoticz
Post by febalci »
Domoticz needs mjpeg streams or still jpegs. The hack you did is rtsp. So unless you find a hack with mjpeg capability, you cant get the picture in domoticz it does not support rtsp. Xiaomi cameras are the worst, not ONVIF capable.
remko2000
Post by remko2000 »
That explains a lot but what I don’t understand why the wiki says it can. Is the wiki not right and is there no possibility to integrate this cam in domoticz?
dlefol
Post by dlefol »
I haven't tried the hack since I don't have the camera, but from what I've read, the hack enables to have RTSP and a JPG image stream too. The JPG should be available at the following address:
http://IP-CAMERA/image.jpg
I advise you to read (google translate) the french webpage pointed at in the wiki. It gives more details than the wiki and provides the link I copied above to access the jpg images.
I hope this works ;)
devros
Post by devros »
i have dafang cam and domoticz guide looks little outdated, because flashing cam is now little different and firmware was updated, looks live even ONVIF is in progres :)
https://github.com/EliasKotlyar/Xiaomi- ... all_cfw.md
deennoo
Post by deennoo »
even with new fw, i still can have a pic on domoticz. Just needed to set login / password on https setting
Better than onvif, there a futur update with PTZ preset, who will allow us to use it on selector switch
http://domo-attitude.fr
Cynthia7264
Post by Cynthia7264 »
galadril
Domoticz version: latest
Post by galadril »
There are 2 hacked firmwares for newer cameras: MStar and AllWinner
Camera Hack
Yi 1080p Home 9FUS AllWinner
Yi 1080p Home BFUS AllWinner
Yi 1080p Home 4FUS MStar
Yi 1080p Home 6FUS MStar
Yi 1080p Home 9FUS MStar
Yi 1080p Home BFUS MStar
Yi 1080p Dome 6FUS MStar
Yi 1080p Dome BFUS MStar
Yi 1080p Home 6FCN MStar
That firmware enables RTSP, Snapshop, ONVIF and more!
I've created a python plugin to integrate them more with Domoticz:
https://github.com/galadril/Domoticz-Yi-Hack-Plugin
