Sunscreen script (feedback needed)
remb0
Post by remb0 »
I posted an article on gadget-freakz.com about my sunscreen script:
https://gadget-freakz.com/2018/04/make- ... scripting/
I have include an option to log to an csv file, So I can run Dryrun and write the reason to change into an CSV file.
And that excel file must give the details of the conditions/reason to pull up or going down. and that is handy to debug or to adjust the thresholds.
But the only Thing I log right now is the message: reason. that's an text string.
what would be the right way to do it as simple as possible and log the information the best way?
All tips and feedback is helpfull..
myfunc
- MyFunc --
-- Function library --
-- Release notes: --
-- 2016-06-01 First release --
MyScript = 'MyFunc' --
MyFuncVersion = 100 --
MyFuncVersion_Type = 'Beta 01' --
LuaDebug = false --
-- Functions
tempfilename = '/home/pi/domoticz/Logs/buienradar.tmp' --
local My ={}
function My.isBlank(x)
return not not tostring(x):find("^%s*$")
function My.PlaySound(msg)
Debug='Y'
if (Debug == 'Y') then print('>> Alarm zegt: '.. msg) end
os.execute ("sudo killall mplayer")
os.execute ("sh /home/pi/domoticz/scripts/bash/Play_sound.sh '" .. msg .. "' ")
function My.GetUserVar(UserVar)
Waarde=uservariables[UserVar]
if Waarde==nil then
print(". User variable not set for : " .. UserVar)
if My.isBlank(UserVarErr) or UserVarErr==nil then UserVarErr=0 end
UserVarErr=UserVarErr+1
return Waarde
function My.File_exists(file)
local f = io.open(file, "rb")
if f then f:close() end
return f ~= nil
function My.Round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
function My.GetValue(Text, GetNr)
Part=1
if Text==nil then
print(". GetValue error at : null " .. GetNr)
MyValue=0
for match in (Text..';'):gmatch("(.-)"..';') do
if Part==GetNr then MyValue = tonumber(match) end
Part=Part+1
return MyValue
-- replace the last character
function My.EnumClear(Text)
a=string.len(Text)
b=string.sub(Text,a,a)
if b=="," or b==" " then Text=string.sub(Text,1,a-1) end
a=string.len(Text)
return Text
function My.ConvTime(TimeX)
year = string.sub(TimeX, 1, 4)
month = string.sub(TimeX, 6, 7)
day = string.sub(TimeX, 9, 10)
hour = string.sub(TimeX, 12, 13)
minutes = string.sub(TimeX, 15, 16)
seconds = string.sub(TimeX, 18, 19)
ResTime = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
return ResTime
function My.TimeDiff(Time1,Time2)
if Time1==nil then
print(". TimeDiff with a nill value : Time1 ")
ResTime=0
if string.len(Time1)>12 then Time1 = My.ConvTime(Time1) end
if Time2==nil then
print(". TimeDiff with a nill value : Time2 ")
ResTime=0
if string.len(Time2)>12 then Time2 = My.ConvTime(Time2) end
ResTime=os.difftime (Time1,Time2)
return ResTime
function My.IsItGonnaRain( minutesinfuture, lat, lon )
url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
if LuaDebug then print(url) end
--read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
read = os.execute('curl --retry 1 --connect-timeout 1 -s -o '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
-- print (". http://www.google.com/maps/place/" .. lat .. "," .. lon .."/data=!3m1!1e3")
-- http://www.google.com/maps/place/51.840756,4.6249/data=!3m1!1e3
while true do
line = file:read("*line")
if not line then break end
if LuaDebug then print('Line:'..line) end
linetime=string.sub(tostring(line), 5, 9)
if LuaDebug then print('Linetime: '..linetime) end
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if (difference > 0) then
if (difference<=minutesinfuture*60) then
if LuaDebug then print('Line in time range found') end
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
if LuaDebug then print('Rain in timerange: '..rain) end
if LuaDebug then print('Total rain now: '..totalrain) end
if LuaDebug then print('Done processing rain data') end
break
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
averagerain=totalrain/rainlines
return(averagerain)
return My
-- Define all the sensors which needs to be considered for the sunscreen to close
local sensors = {
temperature = {
active = true,
device = 'Daikin - buitentemperatuur', --'Buienradar - Temperature',
closeRule = function(device)
return device.temperature <= 19
wind = {
active = true,
device = 'Wu - Wind',
return device.speed >= 50 or device.gust >= 150
rain = {
active = true,
device = 'Wu - Rain',
return device.rainRate > 0
rainExpected = {
active = true,
device = 'IsItGonnaRain', -- This needs to be a virtual sensor of type 'percentage'
return device.percentage > 15
uv = {
active = false,
device = 'Wu - Uv',
return device.uv <= 2
lux = {
active = false,
device = 'Lux',
return device.lux <= 500
local sunscreenDevice = 'Sunscreen' -- Define the name of your sunscreen device
local dryRun = 'Y' -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
-- Define the name of a virtual switch which you can use to disable the sunscreen automation script, Set to false to disable this feature
local manualOverrideSwitch = 'Sunscreen - Manual'
local timeBetweenOpens = 10 -- Minutes to wait after a sunscreen close before opening it again.
local LogFile= '/home/pi/domoticz/Logs/Sunscreen.csv ~m.csv'
local LogAction = 'Y'
local message = '.'
active = true,
timer = {'every minute'}
logging = {
level = domoticz.LOG_DEBUG,
marker = 'Sunscreen: '
execute = function(domoticz)
-- FUNCTIONS
function LogActions()
LogFile=string.gsub(LogFile,"~d",os.date("%Y-%m-%d"))
LogFile=string.gsub(LogFile,"~m",os.date("%Y-%m"))
if not My.File_exists(LogFile) then
f=io.open(LogFile,"a")
f:write("Datum ; Tijd ; dryRun ; Manual_or_Auto ; Message")
f:write("\r\n")
f=io.open(LogFile,"r")
c=f:read("*line")
f:close()
f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";" .. dryRun .. ";" .. domoticz.devices(manualOverrideSwitch).state .. ";" .. message )
f:write("\r\n")
f:close()
local function switchOn(sunscreen, message)
if LogAction == 'Y' or LogAction == 'A' then LogActions() end
if (sunscreen.state == 'Closed') then
if dryRun == 'N' then
sunscreen.switchOn()
--domoticz.notify('Sunscreen', message)
domoticz.log(message, domoticz.LOG_INFO)
domoticz.log('Sunscreen is already down' , domoticz.LOG_INFO)
local function switchOff(sunscreen, message)
if (sunscreen.state == 'Open') then
sunscreen.switchOff()
-- PROGRAM STARTS
if (manualOverrideSwitch and domoticz.devices(manualOverrideSwitch).state == 'On') then
domoticz.log('Automatic sunscreen script is manually disabled', domoticz.LOG_DEBUG)
return
local sunscreen = domoticz.devices(sunscreenDevice)
-- Sunscreen must always be up during nighttime
if (domoticz.time.isNightTime) then
switchOff(sunscreen, 'Closing sunscreen, It is night')
message = 'Closing sunscreen, It is night'
return
-- Check all sensor tresholds and if any exeeded close sunscreen
for sensorType, sensor in pairs(sensors) do
if (sensor['active'] == true) then
local device = domoticz.devices(sensor['device'])
local closeRule = sensor['closeRule']
domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_DEBUG)
if (closeRule(device)) then
switchOff(sunscreen, sensorType .. ' treshold exceeded, Sunscreen up')
domoticz.log(sensorType .. ' treshold exceeded', domoticz.LOG_DEBUG)
message = (sensorType .. ' treshold exceeded')
-- Return early when we exeed any tresholds
return
domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_DEBUG)
-- All tresholds OK, sunscreen may be lowered
if (sunscreen.lastUpdate.minutesAgo > timeBetweenOpens) then
message = 'Sun is shining, all thresholds OK, lowering sunscreen'
Re: Sunscreen script (feedback needed)
Hi Rembo,
can you elaborate a little bit more on what you want. My current understanding is that you want more info in th csv file.
An example line of what you have now and one line with an example of what you want might give me enough information to work with.
remb0
Post by remb0 »
Sorry for my late response.
Indeed I want more info in the csv. All the time the script changes something or not I want the data of that decision.
That way you can check in excel how many times the screen is moving and why. so you can easily adjust the thresholds.
The log works. but this is the current output:
2018-05-01;00:00:00;Y;Off;.
2018-05-01;00:00:00;Y;Off;Closing sunscreen, It is night
2018-05-01;00:01:00;Y;Off;.
2018-05-01;00:01:00;Y;Off;Closing sunscreen, It is night
2018-05-01;00:02:00;Y;Off;.
2018-05-01;00:02:00;Y;Off;Closing sunscreen, It is night
2018-05-01;00:03:00;Y;Off;.
2018-05-01;00:03:00;Y;Off;Closing sunscreen, It is night
2018-05-01;00:04:00;Y;Off;.
2018-05-01;00:04:00;Y;Off;Closing sunscreen, It is night
so I don't want the same repeating messages but only for changes.
My approach would be to safe the message using the dzVents script level persistent variable method and check if the message that you want to write to the logfile is different from the one last written.
See below (not tested):
local sensors = {
temperature = {
active = true,
wind = {
active = true,
rain = {
active = true,
rainExpected = {
active = true,
uv = {
active = false,
device = 'Wu - Uv',
lux = {
active = false,
device = 'Lux',
local message = '.'
    active = true,
    on      =   {   timer   =   {'every minute'} },
    logging =   {   level   =   domoticz.LOG_DEBUG,
                    marker  =   'Sunscreen' },
    data    =   {   safedMessage = { initial = "-" } },
    -- FUNCTIONS
        -- LogFile=string.gsub(LogFile,"~d",os.date("%Y-%m-%d"))
            f:write("\r\n")
            c=f:read("*line")
            f:close()
        if domoticz.data.safedMessage == message then
            domoticz.log("Same message skip write action",domoticz.LOG_DEBUG)
            domoticz.data.safedMessage = message
            f:write("\r\n")
        f:close()
    -- PROGRAM STARTS
        return
        return
                message = (sensorType .. ' treshold exceeded , Sunscreen up')
                switchOff(sunscreen, message )
                domoticz.log(message, domoticz.LOG_DEBUG)
                return
EdwinK
Post by EdwinK »
waaren wrote: Monday 21 May 2018 2:15 My approach would be to safe the message using the dzVents script level persistent variable method and check if the message that you want to write to the logfile is different from the one last written.
local sensors = {
temperature = {
active = true,
wind = {
active = true,
rain = {
active = true,
rainExpected = {
active = true,
uv = {
active = false,
device = 'Wu - Uv',
lux = {
active = false,
device = 'Lux',
local message = '.'
    active = true,
    -- FUNCTIONS
            f:write("\r\n")
            c=f:read("*line")
            f:close()
            f:write("\r\n")
        f:close()
    -- PROGRAM STARTS
        return
        return
                return
Will this also work with your buienradar script, or does it only rely on WU?
EdwinK wrote: Monday 21 May 2018 9:45 Will this also work with your buienradar script, or does it only rely on WU?
@EdwinK,
this script is made by remb0. I only made a suggestion how to prevent double entries in the csv file. My guess is that if you change the names of the devices (sunscreen and sensors) to the names you use, it will work.
But as long as you leave the dryRun variable to "Y" you can test and modify the script to your own liking until everything reacts as expected.
Only when dryRun is "N" the script will send commands to your sunscreen.
remb0
Post by remb0 »
Thanks waaren.
A simple but very effective!!
EdwinK
Post by EdwinK »
So far I get this:
2018-05-24 21:15:00.348 dzVents: Info: Sunscreen: : ------ Start internal script: SunScreen:, trigger: every minute
2018-05-24 21:15:00.349 dzVents: Debug: Sunscreen: : Processing device-adapter for Zonwering: Switch device adapter
2018-05-24 21:15:00.349 dzVents: Debug: Sunscreen: : Sensor not active skipping: rainExpected
2018-05-24 21:15:00.349 dzVents: Debug: Sunscreen: : Sensor not active skipping: uv
2018-05-24 21:15:00.349 dzVents: Debug: Sunscreen: : Checking sensor: rain
2018-05-24 21:15:00.350 dzVents: Debug: Sunscreen: : Checking sensor: temperature
2018-05-24 21:15:00.350 dzVents: Debug: Sunscreen: : Checking sensor: lux
2018-05-24 21:15:00.350 dzVents: Debug: Sunscreen: : Checking sensor: wind
2018-05-24 21:15:00.350 dzVents: Error (2.4.5): Sunscreen: : An error occured when calling event handler SunScreen
2018-05-24 21:15:00.350 dzVents: Error (2.4.5): Sunscreen: : ...domoticz/scripts/dzVents/generated_scripts/SunScreen.lua:73: attempt to index global 'My' (a nil value)
2018-05-24 21:15:00.350 dzVents: Info: Sunscreen: : ------ Finished SunScreen
Seems the script can't write to the specified location. For the rest, the sensors I have at 'buienradar' seem to work. (Dryrun = Y)
papoo
Domoticz version: 4.10
Post by papoo »
place the function library into: /home/pi/domoticz/scripts/lua/
-- MyFunc --
LuaDebug = false --
-- Functions
local My ={}
Debug='Y'
if Waarde==nil then
return Waarde
return f ~= nil
Part=1
if Text==nil then
MyValue=0
Part=Part+1
return MyValue
a=string.len(Text)
a=string.len(Text)
return Text
return ResTime
if Time1==nil then
ResTime=0
if Time2==nil then
ResTime=0
return ResTime
totalrain=0
rainlines=0
while true do
break
file:close()
return(averagerain)
return My
EdwinK
Post by EdwinK »
papoo wrote: Thursday 24 May 2018 21:32 place the function library into: /home/pi/domoticz/scripts/lua/
-- MyFunc --
LuaDebug = false --
-- Functions
local My ={}
Debug='Y'
if Waarde==nil then
return Waarde
return f ~= nil
Part=1
if Text==nil then
MyValue=0
Part=Part+1
return MyValue
a=string.len(Text)
a=string.len(Text)
return Text
return ResTime
if Time1==nil then
ResTime=0
if Time2==nil then
ResTime=0
return ResTime
totalrain=0
rainlines=0
while true do
break
file:close()
return(averagerain)
return My
It was already there.
EdwinK
Post by EdwinK »
rainExpected = {
active = true,
device = 'WUrainExpected', -- This needs to be a virtual sensor of type 'percentage' = Weather Underground
Weather underground makes this a rain device, so I think this might be a problem.
EdwinK
Post by EdwinK »
It's lying to me :(
dzVents: Info: Sunscreen: : Sunscreen is already down
It was not...
grpfge
Domoticz version: 4.10164
Post by grpfge »
Hey
I place the function library into /home/pi/domoticz/scripts/lua/
Start the sunscreen script and get:
2019-01-28 19:38:00.636 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sonnenschutz: Switch device adapter
2019-01-28 19:38:00.637 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Test: Switch device adapter
2019-01-28 19:38:00.637 Status: dzVents: Error (2.4.7): Sunscreen: An error occured when calling event handler sunscreen
2019-01-28 19:38:00.637 Status: dzVents: Error (2.4.7): Sunscreen: ...domoticz/scripts/dzVents/generated_scripts/sunscreen.lua:74: attempt to index global 'My' (a nil value)
2019-01-28 19:38:00.638 Status: dzVents: Info: Sunscreen: ------ Finished sunscreen
74: if not My.File_exists(LogFile) then
f:write("\r\n")
What's wrong with My ?
Matthias
EdwinK
Post by EdwinK »
It's part of the logging on line 53. Change the 'Y' to 'N', and the script will work. I don't know why it doesn't want to writ the file, but it isn't really important for the working of the script.
EdwinK
Post by EdwinK »
Since today I notice that my sunscreen isn't going to lower or raise automaticly anymore using this script although the debug output says it is. When I press the button on my tablet it just works, so the right signal is send to the KAKU switch.
2019-04-18 14:46:00.539 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: every minute
2019-04-18 14:46:00.540 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen - Manual: Switch device adapter
2019-04-18 14:46:00.541 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen: Switch device adapter
2019-04-18 14:46:00.542 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: rainExpected
2019-04-18 14:46:00.542 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Temperature: Temperature device adapter
2019-04-18 14:46:00.542 Status: dzVents: Debug: Sunscreen: Checking sensor: temperature
2019-04-18 14:46:00.543 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Wind: Wind device adapter
2019-04-18 14:46:00.543 Status: dzVents: Debug: Sunscreen: Checking sensor: wind
2019-04-18 14:46:00.543 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: uv
2019-04-18 14:46:00.544 Status: dzVents: Debug: Sunscreen: Checking sensor: lux
2019-04-18 14:46:00.544 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Rain: Rain device
2019-04-18 14:46:00.544 Status: dzVents: Debug: Sunscreen: Checking sensor: rain
2019-04-18 14:46:00.545 Status: dzVents: Info: Sunscreen: Sun is shining, all thresholds OK, lowering sunscreen
2019-04-18 14:46:00.545 Status: dzVents: Info: Sunscreen: ------ Finished SunScreen
