Hello, I have this problem: when I import sqlite3 module into python plugin, Domoticz invoke the plugin and apparently there are no errors.
The problem is that Domoticz call never onStart() and all other functions on Class.
With others import module (Ex. sys, os, pprint....) the plugin work well.
Also with stopped Domoticz, the log error: Error: (Luca) Plugin did not finish start after 30 seconds
Thank you for answer.
Bye
Luca
Python plugin.py module error
- Domoticz version: V2024.4
Re: Python plugin.py module error
Some module do not work with python framework, this is the case with requests and probably with sqlite3. try to found some others one.lucasub wrote: ↑Sunday 20 May 2018 20:41 Hello, I have this problem: when I import sqlite3 module into python plugin, Domoticz invoke the plugin and apparently there are no errors.
Bye
Luca
- Dnpwwo
@lucasu,
@zak45 is correct. The framework is single threaded so any imports that attempt to do thread operations during the initial import will fail in this way. Sqlite3 is one of them.
Thank you for quick answer.
I'll have to look for another way to import data from the DJANGO database
Bye
Luca
Bye
Luca
