To be complete, I'm on computer now
My options.xml:
<?xml version="1.0" encoding="utf-8"?>
<!-- To be effective, this file should be placed in the user data folder specified in the Options::Create method -->
<Options xmlns='http://code.google.com/p/open-zwave/'>
<Option name="logging" value="true" />
<!-- <Option name="UserPath" value="/domoticz" /> -->
<Option name="Associate" value="true" />
<Option name="NotifyTransactions" value="false" />
<Option name="DriverMaxAttempts" value="5" />
<Option name="SaveConfiguration" value="true" />
<Option name="RetryTimeout" value="5000" /><!-- 40000 --><!-- 15000 -->
<Option name="PerformReturnRoutes" value="true" /><!-- added -->
<Option name="AssumeAwake" value="false" /><!-- added -->
<Option name="SaveLogLevel" value="3" /><!-- added -->
<Option name="QueueLogLevel" value="3" /><!-- added -->
<Option name="DumpTriggerLevel" value="3" /><!-- added -->
<Option name="NetworkKey" value="0x09, 0x05, 0x03, 0x04, 0x01, 0x06, 0x07, 0x01, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10" />
<Option name="RefreshAllUserCodes" value="false" />
<Option name="ThreadTerminateTimeout" value="5000" /><!-- 5000 -->
</Options>
Log Levels:
0 No Logging
1 All Messages
2 Fatal Messages Only
3 Error Messages and Higher
4 Warning Messages and Higher
5 Alert Messages and Higher
6 Info Messages and Higher
7 Detailed Messages and Higher
8 Debug Messages and Higher
9 Protocol Information and Higher
And in /etc/init.d/domoticz.sh:
do_start()
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
cp /domoticz/options.xml /domoticz/Config/options.xml
start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
$DAEMON_ARGS \
|| return 2
Without the AssumeAwake line you'll see that after a restart of Domoticz in the Zwave node list all nodes will have a green checkmark. Nodes are queried one by one. The sleeping nodes are marked with a moon icon after a timeout. If you refresh the table you'll see that one by one the sleeping nodes get that icon.
With the AssumeAwake line you'll see that all sleeping devices instantly marked with a moon. Then openzwave either doesn't query them or the timeout is a lot shorter resulting in a faster available zwave network after restart.
