I am trying to switch off my devices at a certain time "On Time" but it does not get trigged.
If I use "Fixed time" it triggs fine.
Can someone share any information on how to fix this?
I hope I don't need to go away from Domoticz as I like it apart from this issue.
Version: 3.8798
Build Hash: 8bb0420c
Compile Date: 2018-01-02 02:17:32
dzVents Version: 2.3.0
Switch off does not work
- Domoticz version: Latest β
Re: Switch off does not work
Possibly silly question but have you selected the correct days for the On Time command 'Everyday, Weekdays, etc
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Yes, I have i set to everyday.
The "On" command works fine - I am clueless,, no question is silly- my problems are probably something like yhat..
I have read about problems with timers in the beta versions of Domoticz but I haven't any experience as I stick to the stable versions as I can't afford for things not to be reliable.
For what it's worth I use 'On' and 'Off' timers and they are fine.
Not much help I know.
Could you post a screen shot of your 'Off' timer page, it might show something you may have missed.
Here it is
I really thought I had a stable version.. - I suppose I need to redo all configuration if I change, or can I upgrade to stable version from where I am?
My W/O now is to have a "Off" swtich mapped to day of week... so I have 7 of them....
That looks fine, I’m afraid that I can’t see why ‘On’ would work but not ‘Off’. Unless it’s related to using the beta but as I said before I have no experience of that.
What I have used when I want something to trigger at a time based on another event (ie: turn the heating program to low at 08:00 if my wife has gone to work but wait till 10:00 if she is at home that day). Is to use a script to check the time and change the heating program based on whether her phone is connected to our wireless network. You can make some quite flexible timers this way.
