Start camera recording on surveillance station by switch
markiemajax
- Domoticz version: 3.4834
I run Domoticz on my DS214 together with my raspberry (incl. Piface ) .
On the contacts of piface I switched a contact of my alarm .
Now domoticz knows whether the alarm is activated.
What I would like is that surveillance station will start recording when the alarm is activated.
The camera I've connected a D-Link 930L .
I read about API on surveillance station , but I have no idea how I should use this in Domoticz .
Does anyone know how I should do this?
Regards,
Mark
Regards,
Mark
- gizmocuz
Re: Start camera recording on surveillance station by switch
Hello Mark,
if you use the search option of the forum and enter 'synology record' you will find some ways todo it,
for example:
http://www.domoticz.com/forum/viewtopic ... ing#p21915
for example:
markiemajax
I finaly got it working:
Create a dummy switch and adjust the on/off action (see attatchment).
(My dummy gets triggered when my alarm is on and there is motion.)
Add both of the scripts to /domoticz/scripts/, using winscp or some program.
Adjust the ip, port, login and pass in both the scripts. These are all inputs of the surveillance station.
Now surveillance station will start recording when the dummy switch is activated.
- Camera aan_uit.zip
- (187.43 KiB) Downloaded 1057 times
scatman
- Domoticz version: 2.2563
Himarkiemajax wrote: Adjust the ip, port, login and pass in both the scripts. These are all inputs of the surveillance station.
Can I ask help ... I added both file to scripts and in log box I had this information:
2015-12-24 23:44:57.772 Executing script: /home/pi/domoticz/scripts/Turn_on.php
2015-12-24 23:44:57.783 Error: Error executing script command (/home/pi/domoticz/scripts/Turn_on.php). returned: 32256
I adjusted the ip, port, login and pass in both the scripts
$server = "http://192.168.178.130:9900";
$login = "admin";
$pass = "**********";
and I adjusted all important things on synology of the surveillance station.
Do you know what it's mind?
JanKarel
Does anyone have experience with setting up something similar as Mark developed for a QNAP NAS?
JanKarel
JanKarel
bbluff
HI to all,
I'am Noob about lua scripting and I would like to ask how to manage this:
I have a Synology NAS with Surveillance station and I can get on/off the SStation works with a SSH command / Tasker on my android phone, but now I would like to integrate that within a Domoticz dummy switch...
I run domoticz on Raspi, and I can't get the right lua code to access via SSH on Synology and launch the command I used to switch the surveillance...
Here the command SSH Surveillance ON:
/var/packages/SurveillanceStation/target/scripts/S82surveillance.sh start
and the OFF:
/var/packages/SurveillanceStation/target/scripts/S82surveillance.sh stop
please let me know
Inviato dal mio SM-G906K utilizzando Tapatalk
and the OFF:
please let me know
bbluff
Re: RE: Re: Start camera recording on surveillance station by switch
I changed the parameters and password but still get error:markiemajax wrote:I finaly got it working:
Error: Error executing script command (/home/pi/domoticz/scripts/Turn_on.php). returned: 32512
I also put 777 on the two php but without success
Please help me
mikkel75
Did you find a solution to this? I'm also looking for a way to start recording based on Domoticz alarm switch..bbluff wrote: Friday 18 March 2016 15:17 HI to all,
and the OFF:
please let me know
I ran into the same error 32512. what finally solved it for me was the following
follow markiemajax post but do not just add the files to the domoticz/scripts folder.
- in the folder domoticz/scripts: create two new php script files (ie. Turn_on.php and Turn_off.php) and paste the contents from php script files from the downloaded zip file. Note : so do not copy and paste the files themselves but instead copy and paste its contents!
- change the server, login and password
- make the php files excutable with
sudo chmod +x Turn_on.php sudo chmod +x Turn_off.php
- test if the script works in ssh:
php Turn_on.php php Turn_off.php
- Assign the scipts to the On- and Off action
Thanks a lot Wopper, it helped me to solve this error.
patj71
Script works fine, but how can I select which camera to start recording, all my cameras start to record using the script.
br Patrick
br Patrick
dannybloe
You will have to dive into the api I guess. The scripts loops over all cams and starts them all I believe (last time I looked). Shouldn't be so hard figure that out (and let me know when you did that coz I need it too
Or create a dzVents script to do this...
look for this line in the script:patj71 wrote: Saturday 12 May 2018 1:55 Script works fine, but how can I select which camera to start recording, all my cameras start to record using the script.
br Patrick
if($cam->enabled ) {Code: Select all
if($cam->enabled and $id_cam = XX) {)-
pimseb
- Domoticz version: 2020.1
I was searching for camera recordings on surveillance station when I found this (quite old) post.
You don't really need this script anymore.
You can add an action rule directly in surveillance station, telling it that an external device will do some actions you want (send a notification, start recording ...)
Surveillance station will give you an URL that looks like :
https://ip:port/webapi/entry.cgi?api=SYNO.SurveillanceStation.ExternalEvent&method="Trigger"&version=1&eventId=1&eventName="This is external event1"&account="{account}"&password="{password}"
Just add this URL in your "action on / action off" field switch in domoticz.
For exemple if you have a motion detector set up in domoticz, you can tell surveillance station to record the video if a movement is detected
Atis
pimseb wrote: Monday 11 February 2019 16:44 I was searching for camera recordings on surveillance station when I found this (quite old) post.
I hope you can help me. I would like disable and enable the camera with URL. I try the syno document but can not working. Can you help how can I enable/disable one camera?
Thx,
