Is it possible to update the value of a dummy sensor with the type soil moisture via json?
Can't find anything in wiki about soil moisture.
Trying to send data from espeasy to domoticz.
json call from espesy to update value on soil moisture dummy sensor - Solved
Xztraz
- waaren
Re: json call to update value on soil moisture dummy sensor
http://domoticz_IP:domoticz_PORT/json.htm?type=command¶m=udevice&idx=yyy&nvalue=xx
yyy = your device number
xx: moisture
00 - 09 ==> "saturated
10 - 19 ==> "adequately wet"
20 - 59 ==> "irrigation advice"
60 - 99 ==> "irrigation"
> 99 ==> "Dangerously dry"
xx: moisture
Xztraz
Alright.
That explains why the standard dummy sensors in espeasy won't update soil moisture.
All preset modes seem to send variations of svalue instead of nvalue.
GET /json.htm?type=command¶m=udevice&idx=927&nvalue=0&svalue=3.00&rssi=9 HTTP/1.1
Xztraz
Solution:
As adviced, nvalue needs to be set for soil moisture sensor in domoticz api. Thanks waaren
Since none of the predefined dummy sensor types does that i had to make up a rule in espeasy
I had to rearrange in the url a bit since a oddity in espeasy, param needs to be first. otherwise it mucks up the url
on SoilRaw#Raw do // this event comes in every minute
TaskValueSet 5,1,[SoilRaw#Raw]/5 // set SoilMoist#Moisture dummy sensor
SendToHTTP 192.168.1.199,8080,/json.htm?param=udevice&type=command&idx=927&nvalue=[SoilMoist#Moisture]
endonWho is online
