LUA script in dir clogs up log
gcaley
Post by gcaley »
I have created a device script in the domoticz/script/lua directory.
I want to catch a set of contact sensors opening and then update a virtual switch with the overall status (i.e. House insecure). The aim is that i can dashboard the general house security status and see if someone has left a window open etc.
I've got the script working as a time script (checking device status every minute), but want to react quicker to a contact changing.
The only problem when converting to a device script is that it is triggered every few seconds when a new temperature reading comes in from one of the 12 or so temp devices i have. This then clogs the log with a "2018-05-13 21:51:57.586 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_test.lua" message every few seconds
Is there a way to either not have that message appear, or to not have the script trigger unless the devices im interested in change?
Thanks.
Running the latest Domoticz beta
Re: LUA script in dir clogs up log
gcaley wrote: Sunday 13 May 2018 23:05 Is there a way to either not have that message appear, or to not have the script trigger unless the devices im interested in change?
You could convert your script to dzVents Lua and let it trigger only on the relevant devices. It does take some reading but the wiki is excellent and conversion is relatively simple.
gcaley
Post by gcaley »
Ok thanks, I might try that. Yet another language to learn! :)
jvdz
Domoticz version: 4.107
Post by jvdz »
Sure, just make that change to line 12 of your script! ;)
... oh wait, you didn't post any script and expect us to advise you in how to change it which is asking for a "stab in the dark".
Likely you are creating an indefinite loop by acting on a changed device and then change that device, or it is simply the case that a device is changed this often which triggers all devices scripts by design!. We would need to see the script to figure that out.
Jos
gcaley
Post by gcaley »
Hi Jos,
Sorry, i thought (and not understanding how and when the device scripts are called or run, that i was just missing something obvious.
The script name is script_device_test.lua and the content is below. Normally the sensors all report back 'Closed', unless one is left Open.
local sensor1 = 'Front Door LR'
local sensor2 = 'Rear Door LR'
local sensor3 = 'Kitchen Window'
local sensor4 = 'Dining L Window'
local sensor5 = 'Dining R Window'
local sensor6 = 'Lounge R Window'
local sensor7 = 'Lounge F Window'
local alarm
local stext
stext = ""
alarm = "false"
if devicechanged[sensor1] == 'Open' then
alarm = "true"
stext = sensor1
print(sensor1 .. " Open")
if devicechanged[sensor2] == 'Open' then
alarm = "true"
stext = stext .. "-" .. sensor2
print(sensor2 .. " Open")
if devicechanged[sensor3] == 'Open' then
alarm = "true"
stext = stext .. "-" .. sensor3
print(sensor3 .. " Open")
if devicechanged[sensor4] == 'Open' then
alarm = "true"
stext = stext .. "-" .. sensor4
print(sensor4 .. " Open")
if devicechanged[sensor5] == 'Open' then
alarm = "true"
stext = stext .. "-" .. sensor5
print(sensor5 .. " Open")
if devicechanged[sensor6] == 'Open' then
alarm = "true"
stext = stext .. "-" .. sensor6
print(sensor6 .. " Open")
if devicechanged[sensor7] == 'Open' then
alarm = true
stext = stext .. "-" .. sensor7
print(sensor7 .. " Open")
if alarm == 'false' then
commandArray['UpdateDevice'] = '1014|0|No Alert'
stext = "Alert-" .. stext
commandArray['UpdateDevice'] = '1014|4|'..stext
print("Alarm=" .. tostring(alarm))
gcaley wrote: Monday 14 May 2018 0:07
About the learning aspect... Not really !!
From the dzVents wiki "And ... it is 100% Lua! So if you already have a bunch of event scripts for Domoticz, upgrading should be fairly easy."
jvdz
Post by jvdz »
gcaley wrote: Monday 14 May 2018 0:45 Sorry, i thought (and not understanding how and when the device scripts are called or run, that i was just missing something obvious.
No worries, I was just playing a little. :)
The thing to understand is that the eventsystem will run all script_device.xxxx.lua files each time when when any device is updated unless the "xxxxx"match a devicename, in which case only that specific device script is ran.
In your script you are having these lines:
That means that with each device update in your setup you will always do an update for device 1014 and when the alarm == 'false' it will also print a line in the log each time the script is ran... which is endless as you case a device change each time.
My guess is you only want to apply that logic when the alarm text device need to change its text ...right?
Something like like this should avoid that and only update the text device when it needs changing:
local alarm = "false"
local stext = "No Alert"
	alarm = "true"
	stext = sensor1
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = true
-- only update Text device when text changed
if (otherdevices["Nane-of=Text-Device"] ~= stext) then
	print("Alarm device updated to " .. tostring(alarm))
Jos
gcaley
Post by gcaley »
	alarm = "true"
	stext = sensor1
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = "true"
	alarm = true
Jos
Thanks for that. I’ll give it a try later on.
gcaley
Post by gcaley »
Thanks for the previous help. I now just get a lot of the message below:
2018-05-15 13:06:07.131 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_test.lua
2018-05-15 13:06:09.818 (RXFCom 433) Temp + Humidity (Bathroom)
2018-05-15 13:06:09.833 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_test.lua
Which I guess means the device script is running every time any device changes (e.g. the temp devices). Is there a way to avoid this?
Thanks.
jvdz
Post by jvdz »
That log entry can be disabled easily on regular use by simply going into the domoticz website, go into Setup/Settings and select the Other tab. Scroll down to the Event part and deselect the option "Log 'event script triggers"
Jos
gcaley
Post by gcaley »
jvdz wrote:That log entry can be disabled easily on regular use by simply going into the domoticz website, go into Setup/Settings and select the Other tab. Scroll down to the Event part and deselect the option "Log 'event script triggers"
Jos
Thanks, I’ll give that a go.
