Smappee
Smappee
is it possible to introduce smappee in domoticz natively?
Re: Smappee
anyone that have resolved this?
- Egregius
- Domoticz version: v2024.7
Re: Smappee
Use a script to query the smappee and push the data to domoticz.
- Egregius
Re: Smappee
This is what I do with it:
Above script is executed every 10 seconds. It gives me the current power consumption and solar power. The data is stored in a SQL database and is the consumption is more than 8000W I receive a message.
And then in a cron job that runs every 2 minutes:Here I grab the daily totals and push them to php cache so I can see them on my floorplan and they're sent to a site where I monitor consumptions together with some friends.
<?php
$smappee=json_decode(file_get_contents('http://192.168.2.19/gateway/apipublic/reportInstantaneousValues'),true);
if(!empty($smappee['report'])){
$zon=apcu_fetch('zon');
preg_match_all("/ activePower=(\\d*.\\d*)/",$smappee['report'],$matches);
if(!empty($matches[1][1])){
$newzon=round($matches[1][1],0);
if($newzon<0)$newzon=0;
if($zon!=$newzon)apcu_store('zon',$newzon);
if(!empty($matches[1][2])){
$consumption=round($matches[1][2],0);
if($consumption!=apcu_fetch('verbruik'))apcu_store('verbruik',$consumption);
$timestamp=strftime("%Y-%m-%d %H:%M:%S",time());
$query="INSERT INTO `smappee` (`timestamp`,`consumption`) VALUES ('$timestamp','$consumption');";
$db=new mysqli('127.0.0.1','domotica','domotica','domotica');if($db->connect_errno>0)die('Unable to connect to database [' . $db->connect_error . ']');if(!$result=$db->query($query))die('There was an error running the query ['.$query .' - ' . $db->error . ']');$db->close();
if($consumption>8000){
if(past('notify_power')>3600){
apcu_store('Tnotify_power',time());
telegram('Power usage: '.$consumption.' W!',false);
}else{
if(shell_exec('curl -H "Content-Type: application/json" -X POST -d "" http://192.168.2.19/gateway/apipublic/logon')!='{"success":"Logon successful!","header":"Logon to the monitor portal successful..."}')exit;
function past($name){return time()-apcu_fetch('T'.$name);}
function telegram($msg,$silent=true,$to=1){
$msg=str_replace('__',PHP_EOL,$msg);
shell_exec('/var/www/html/secure/telegram.sh "'.$msg.'" "'.$silent.'" "'.$to.'" > /dev/null 2>/dev/null &');
$timefrom=time-86400;
$chauth = curl_init('https://app1pub.smappee.net/dev/v1/oauth2/token?grant_type=password&client_id='.$smappeeclient_id.'&client_secret='.$smappeeclient_secret.'&username='.$smappeeusername.'&password='.$smappeepassword.'');
curl_setopt($chauth,CURLOPT_AUTOREFERER,true);
curl_setopt($chauth,CURLOPT_RETURNTRANSFER,1);
curl_setopt($chauth,CURLOPT_FOLLOWLOCATION,1);
curl_setopt($chauth,CURLOPT_VERBOSE,1);
curl_setopt($chauth,CURLOPT_SSL_VERIFYHOST,false);
curl_setopt($chauth,CURLOPT_SSL_VERIFYPEER,false);
$objauth=json_decode(curl_exec($chauth));
if(!empty($objauth)){
$access=$objauth->{'access_token'};
curl_close($chauth);
$chconsumption=curl_init('');
curl_setopt($chconsumption,CURLOPT_HEADER,0);
$headers=array('Authorization: Bearer '.$access);
curl_setopt($chconsumption,CURLOPT_HTTPHEADER,$headers);
curl_setopt($chconsumption,CURLOPT_AUTOREFERER,true);
curl_setopt($chconsumption,CURLOPT_URL,'https://app1pub.smappee.net/dev/v1/servicelocation/'.$smappeeserviceLocationId.'/consumption?aggregation=3&from='.$timefrom.'000&to='.time.'000');
curl_setopt($chconsumption,CURLOPT_RETURNTRANSFER,1);
curl_setopt($chconsumption,CURLOPT_FOLLOWLOCATION,1);
curl_setopt($chconsumption,CURLOPT_VERBOSE,1);
curl_setopt($chconsumption,CURLOPT_SSL_VERIFYHOST,false);
curl_setopt($chconsumption,CURLOPT_SSL_VERIFYPEER,false);
$objconsumption=json_decode(curl_exec($chconsumption),true);
if(!empty($objconsumption['consumptions'])){
$verbruikvandaag=$objconsumption['consumptions'][0]['consumption']/1000;
apcu_store('verbruikvandaag',round($verbruikvandaag,1));
$zonvandaag=$objconsumption['consumptions'][0]['solar']/1000;
apcu_store('zonvandaag',round($zonvandaag,1));
$gas=apcu_fetch('gasvandaag')/100;
$water=apcu_fetch('watervandaag')/1000;
@file_get_contents("https://xxx.xxx.xxx/secure/insertdata.php?user=xxx&verbruik=$verbruikvandaag&gas=$gas&water=$water&zon=$zonvandaag");
lg("verbruik => gas = $gas | verbruik = $verbruikvandaag | zon = $zonvandaag | water = $water");
curl_close($chconsumption);
Re: Smappee
if would i control the plug?
- Egregius
Re: Smappee
You didn't specify that...
I don't have any smappee plugs but I guess you can easily grab the url from developper console from your browser.
- Domoticz version: 3.8807
Re: Smappee
Have you looked in the Wiki?
https://www.domoticz.com/wiki/Smappee
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
- Egregius
Re: Smappee
@simonrg
If you remove the code block the link will be clickable.
Re: Smappee
Thanks, I meant to use:
[url]http://www.domoticz.com/wiki[/url]
Re: Smappee
this is new specific send by smappe organizzation to me to control plug with mqtt system
thank a lot
if someone can create script to control plug with mqtt systemthank a lot
- MQTT broker configuration on Smappee Plus Pro (1).pdf
- (190.71 KiB) Downloaded 88 times
Re: Smappee
Great, I haven't used MQTT at all, but it looks like it should simple to talk to Smappee via MQTT.
However, there needs to be some programming to translate Smappee MQTT messasges which into MQTT messages which Domoticz would understand and for Domoticz MQTT to be transleted for Smappee.
Time to read the wiki - https://www.domoticz.com/wiki/MQTT and look at other people using MQTT https://www.sigmdel.ca/michel/ha/domo/domo_03_en.html.
I sse you have already posted in the MQTT support thread - http://www.domoticz.com/forum/viewtopic ... &start=320
