JSON response is:
"software_version": "NRZ-2017-099",
"age": "104",
"sensordatavalues": [
"value_type": "SDS_P1",
"value": "13.37"
"value_type": "SDS_P2",
"value": "11.23"
"value_type": "temperature",
"value": "19.10"
"value_type": "humidity",
"value": "54.00"
"value_type": "BME280_temperature",
"value": "23.80"
"value_type": "BME280_humidity",
"value": "38.49"
"value_type": "BME280_pressure",
"value": "100476.89"
"value_type": "samples",
"value": "589419"
"value_type": "min_micro",
"value": "243"
"value_type": "max_micro",
"value": "26699"
"value_type": "signal",
"value": "-60"
domoticz.log(item.json.software_version)
domoticz.log(item.json.age)
domoticz.log(item.json.sensordatavalues)Code: Select all
2018-05-10 09:55:01.483 dzVents: Info: ------ Start external script: luftdaten.lua: HTTPResponse: "luftdatenRetrieved"
2018-05-10 09:55:01.487 dzVents: Info: NRZ-2017-099
2018-05-10 09:55:01.487 dzVents: Info: 125
2018-05-10 09:55:01.487 dzVents: Info: {{["value"]="8.33", ["value_type"]="SDS_P1"}, {["value"]="5.37", ["value_type"]="SDS_P2"}, {["value"]="15.30", ["value_type"]="temperature"}, {["value"]="73.90", ["value_type"]="humidity"}, {["value"]="20.10", ["value_type"]="BME280_temperature"}, {["value"]="49.14", ["value_type"]="BME280_humidity"}, {["value"]="100752.16", ["value_type"]="BME280_pressure"}, {["value"]="590282", ["value_type"]="samples"}, {["value"]="238", ["value_type"]="min_micro"}, {["value"]="1129681", ["value_type"]="max_micro"}, {["value"]="-65", ["value_type"]="signal"}}
2018-05-10 09:55:01.488 dzVents: Info: ------ Finished luftdaten.lua
