so "sync my devices" isn't adding the new devices?
- Domoticz version: 4.10264
Never mind, seems working now... think I had some internet problems... Sorry!
Google now allow you to leave a review, as well as rate Controlicz. Please feel free to leave me a review, and if the person who rated it 1* could say why it was so poor, it would be helpful!
Ciao @art4meart4me wrote:Never mind, seems working now... think I had some internet problems... Sorry!
Can you tell me the command to sync the devices?
You mean that if I add/remove/change a device in Domoticz in one of the room it will be updated via controlicz in the google home list?
Only found https://assistant.google.com/services/a ... 2?hl=en-US which shows a rating of ★ 4.7
Can you give the url where we can review?
I had to swipe right on my phone on the rating bit to get to the writing a review bit
@Akerboom thanksAkerboom wrote: 'sync my devices' as command to the assistant
Some weeks ago in Italian was not working, now with "sincronizza i miei dispositivi" it works fine.
Re: Google assistant/Google home integration
Website link is broken..Madgeni wrote: ↑Wednesday 15 November 2017 20:58 You can use the device description in Domoticz to create 'Friendly Names' as per https://www.controlicz.com/FAQ.
I'll look at the temperature now
I'll be happy testing on Google Home too!
Same behaviour. I'm using italian as well.
The blinds are seen as a light/switch so it's not possible to set the %. If you change the control (domoticz) )to dimmer, you can set the % but as my binds are "inverted" I have to exchange open with close and so on. % as well.
mantoz wrote: ↑Wednesday 25 April 2018 21:59 Hi,
I did some more tests with Controlicz and I'm very happy with it. Using Italian.
Only strange things I noticed:
1. blinds appear to be inverted. In domoticz they're set as "Blinds percentage" and icons (open/closed) are correct. In Controlicz/Google home they appear to be inverted, as I have to say "switch off the blinds" to open them and vice versa. I could invert them in Domoticz, but then I'd have the wrong icons in domoticz (open when they're really closed and so on). Any workaround available?
2. related to 1. --> In Italian we usually say "Open blinds" and "Close blinds" instead of "Switch on/off the blinds" (translated, of course). This does not work. I assume that this is a Google Home bug, and/or is due to Google Home thinking that my blinds are really switches.
Can you confirm this please?
Thanks,
mantoz
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- Neo CoolCam Door Detector and plug
- FIBARO FGWPE Wall Plug
- 6 FIBARO System FGRM222 Roller Shutter Controller 2
- Kodi SamnsungTV Yamaha plugin
- pluginn manager
- Netatmo
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
I wish this place had a vote system.
Historically, when this all first went live on Alexa, on = close, off = open - then with feedback, it was inverted. Then after other people complained, it was put back the way it was.
If there is a general consensus driving change (We love a referendum in this country), i'll change it.
You're right, both Alexa and Google are missing open/close.
domoticz has different switch types for the blinds:
- Blinds
Blinds Inverted
Blinds percentage
Blinds percentage inverted
Madgeni wrote: ↑Wednesday 02 May 2018 15:17 I wish this place had a vote system.
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
If only the Domoticz API had blinds as a device type. (it doesn't).
If I send /json.htm?type=devices&filter=all&used=true&order=Name in the response I can get the switch type
SubType: "Switch",
SwitchType: "Blinds Percentage Inverted",
SwitchTypeVal: 16,
SubType: "Switch",
SwitchTypeVal: 16,
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
Referendum!
For me opposite then now will stick to What i have in domoticz as icon/state!
I stand corrected!
Let me see what I can do. The issue is mainly around storing that your blinds are inverted, for controls. I don't query that every time you issue a command, only for discoveries, so i have to store and replay that data, then invert the command.
Let me know if I can help
A
A
Madgeni wrote: ↑Thursday 03 May 2018 8:15I stand corrected!
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
Hi everyone,
Thanks for this great service and I can't wait to try it out. However I do have some problem some other have mentioned here. Everything works and checks out, however in the last step, adding Controlicz in the Google Home app, I get the 'Couldn't update the setting, check your connection' error.
I've tried with both a standard Google (gmail) account and a Google apps account. Controlicz itself returns a successful test in the website. I also have the scenes tab enabled (with several scenes on it), as well as the rooms, roomplans, and devices in the rooms.
Any suggestions?
Any suggestions?
Hi jakeB -
you can email Controlicz from your Profile now - if you do, i'll take a look for you
