barometer without decimals
Done. Made it with a user controlled amount of decimals for display and a separate amount of decimals for sending it to the database to keep the graph as smooth as possible.
What I mean is that there exists a "wind temp chill" device in your case "wind Rotterdam"
Funny thing!EddyG wrote: ↑Friday 27 April 2018 19:14 I can not figure out why this does NOT work.But only this WORKS!Code: Select all
local function getUservars() require ('weatherSettings') end if not(pcall(getUservars)) then
Anybody any ideaCode: Select all
Sent you a PM with a link to a test version that adds the requested option.
2018-05-02 22:40:03.477 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.96&lon=5.56
2018-05-02 22:40:04.139 Error: dzVents: Error (2.4.5): WUS: Problem with trigger (not OK). Check it outError: 7103862
Thanks.
I see the same sometimes but luckily not very often.EddyG wrote: ↑Thursday 03 May 2018 6:58 I get this error a few times a day.It seems that buienrader does not respond.Code: Select all
2018-05-02 22:40:03.477 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.96&lon=5.56 2018-05-02 22:40:04.139 Error: dzVents: Error (2.4.5): WUS: Problem with trigger (not OK). Check it outError: 7103862
Do others get this error too, or is it my Internet connection?
2018-04-30 23:45:04.724 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-01 11:22:20.232 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-01 11:31:08.313 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-01 13:17:04.420 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-01 21:05:08.098 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-02 08:00:14.741 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
2018-05-02 14:00:15.068 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=51.xx&lon=4.xx
Unfortunately the script is now too big to post it like that. The Forum rules do not allow itpoudenes wrote: ↑Thursday 03 May 2018 23:12 Can you also post the new scripts in the first post between ""Code: Select all
download zip, unzip, copy, paste instead of copy paste ... last option is faster hehe
dzVents: Error (2.4.5): WUS: Problem with trigger (not OK). Check it outError: 28
