SMS to Domoticz
assenzuid
SMS to Domoticz
Post by assenzuid »
Not sure if it's possible what I wants.
I have an Alarm System (vendor Visonic) with a GSM module. The alarm system is monitored by an alarm central. When I enable or disarm the alarm system I get a notification on my GMS (through SMS). Is it possible to make use of an system that can send the SMS to my Domoticz to get the status?
Kind regards,
sion
Re: SMS to Domoticz
Post by sion »
You may be able to tap into the alarm panel?
I hooked up a couple of relays, and rf senders, so domoticz knows if alarm is set, disarmed, or ringing and can act accordingly. You would need to look inside and see what connections you have. Is the gsm built in? Or separate?
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
assenzuid
Re: SMS to Domoticz
Post by assenzuid »
GSM module is build in. Have not a Ethernet module
jvdz
Domoticz version: 4.107
Re: SMS to Domoticz
Post by jvdz »
Doesn't the Alarm system have some external connect possibility with some sort of NC/NO pins to indicate its status?
If so, you could hook up an arduino board and report the status to domoticz.
Jos
assenzuid
Re: SMS to Domoticz
Post by assenzuid »
That's something what I have to check.
