updateWeatherSensors (yet another buienradar script)  [SOLVED]
Re: updateWeatherSensors (yet another buienradar script)
New version available (bugfix) ; see first post here Latest version 0.20180424
20180423 Some additional user specific settings. Both files (main code and user settings) are in the attached zip
20180423 Added experimental Lux (based on Solar Power) this one still need a lot of work so do not rely on it.
20180423 Execution frequency controlled by user settings. Read the comments in the usersetting file
20180424 Rainforecast bugfix and improved lux forecast
poudenes
Domoticz version: 3.8993
Post by poudenes »
Nice !!! we gonna install it, test it, be happy with it !
waaren wrote: Monday 23 April 2018 18:40 New version available; see first post here Latest version 0.20180423
History
20180408 Start coding
20180411 First version active and shared on forum
20180412 Added check on text fields (do not overwrite same text)
20180413 Added more checks and logs
20180413 Corrected rain forecast formulas
20180413 Adjusted rain forecast devices
20180413 Added Alert,text and switch rain forecast devices (all optional)
20180414 User adjustable interval for Info logging to domoticz logfile
20180414 User adjustable interval for updating unchanged sensors/switches
20180414 Shortened long forecast string to 240 chars because of bug in domoticz
20180415 Separated user specific settings from main codefile
20180416 Improved layout text to logfile
20180420 Day-/night frequency now controlled by user-setting
20180423 Added experimental lux based on Solar Power
20180423 Added checks on empty returns
Bufoto
Post by Bufoto »
Version 2018-04-24 works fine for me! Thanks!
EddyG
Post by EddyG »
I can not figure out why this does NOT work.
    local function getUservars()
       require ('weatherSettings')
    if not(pcall(getUservars)) then
But only this WORKS!
Anybody any idea :?:
Hi EddyG,
It works with my version of dzVents (2.4.5) and on my OS (Debian stretch)
Could you add this
    if true then
       local status, err = pcall(getUservars)
        print(err)
        return
directly after
And check if you see any message in the domoticz log ? If not standard then after switch the script and dzVents into debug mode ?
Don't forget to remove this code afterwards :D
poudenes
Post by poudenes »
Here latest script is also working dzVents 2.4.4 / Rasbian Stretch
EddyG
Post by EddyG »
I raised dzVents logging to debug and put in:
print(err)
print("OK")
The logging only shows:
2018-04-28 09:44:00.667 dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua:, trigger: every minute
2018-04-28 09:44:00.668 dzVents: OK
2018-04-28 09:44:00.682 dzVents: Info: WUS: ------ Finished updateWeatherSensors.lua
So the codes gets to the OK, but the return of the pcall seems to be nothing. I am using lua 5.2
EddyG wrote: Saturday 28 April 2018 9:47 I raised dzVents logging to debug and put in:
print(err)
print("OK")
@EddyG,
what you have put in, is something different than what I proposed. The pcall can return two values and you interpret only one.
Can you please put in the code snippet I proposed ?
What do you mean with Lua 5.2 ?
As far as I understand dzVents use the Lua integrated with domoticz but I could be wrong (Would not be the first time either :D )
EddyG
Post by EddyG »
I tried everything, including your code, but the pcall returns nothing.
Code:
print(tostring(status).." - "..tostring(err))
Result:
2018-04-28 13:07:01.318 dzVents: true - nil
2018-04-28 13:07:01.318 dzVents: OK
This is some code I found on the Internet about pcall
function f()
  return 'some text'
local status, res = pcall(f)
if pcall succeeded, status is true and res is the return value of f().
if pcall failed, status is false and res is the error message.
About Lua version. I thought it was external.
poudenes
Post by poudenes »
I was scream to fast. I see now 3 times a fatal error pop up. Don't know if this is because of last release of script or just 1 plugin i installed.
Im now testing some things....
poudenes wrote: Saturday 28 April 2018 18:36 I was scream to fast. I see now 3 times a fatal error pop up. Don't know if this is because of last release of script or just 1 plugin i installed.
@poudenes,
can you please post the fatal errors. If possible I will try to catch these and handle them gracefully in later versions .
poudenes
Post by poudenes »
EDIT: removed the lines myself
EddyG
Post by EddyG »
Is not this the same crash from the latest beta. See section Bugs.
poudenes
Post by poudenes »
Yes i see it also. Sorry for the post ... :mrgreen:
poudenes wrote: Saturday 28 April 2018 20:56 You ask i got the error again:
@poudenes,
this segmentation fault is caused by one of the pull requests from github that were merged into Beta earlier today. It has already been reported at this forum and on github here .
Nothing related to dzVents or my script.
EddyG
Post by EddyG »
It might be an idea to separate the "Wind+Temp+Chill" device in 2 devices "Wind" and "Chill Temp"
The "Wind+Temp+Chill" is also separated in 2 devices but those have the same name.
So if I call it "Wind" then that device is present on the Temperature an Weather tab with the same name.
Just an idea.
Hi EddyG,
not quite sure what you propose. The "wind" device is already shown on both the temperature and the weather tab. If I mis-interpret your suggestion please let me know.
Device screen filtered on text Rotetrdam
New versions posted here Latest version 0.20180430
Use of setting file mandatory now.
Please find detailed information / explanation in files
History since last posting
20180425 Bug in updating rain-rate after forcedUpdateMinutes fixed (did not update when equal)
20180425 Prepared language choice
20180427 Added more translations
20180427 Added 5 and 10 day forecast device and information
20180429 Setting file mandatory now
20180429 Finished translations
20180429 Added location retrieval from domoticz settings
20180430 Adjusted Lux calculation
Have Fun !
EdwinK
Post by EdwinK »
Thanks. Trying out again :)
DannyG
Post by DannyG »
Looks / works great
