timer + variable
TheCondor
timer + variable
Post by TheCondor »
Hello, i've currently a script triggered at 7.45 during mon-sat and at 8.45 on sunday. I've found a script here on the forum for set a variable (string) with the info if today is a working day or a bank-holiday and i want to let use my blind script that variable info.
The actual trigger is that:
        timer = {
            'at 22:30',
            'at 7:45 on mon,tue,wed,thu,fri,sat',
            'at 8:45 on sun'
its possible to use in conjunction in this way?
        timer = {
            'at 22:30',
            'at 7:45 on (day == working_day),
            'at 8:45 on (day == holiday)'
dannybloe
Re: timer + variable
Post by dannybloe »
No, that is not possible.You'll have to test it 'manually'.
maluko
Post by maluko »
hi ,
i can use like me.
I have at my google calendary all day off/holidays marked like any word i want, like "holiday" , at my android phone i have the tasker app that scan the calendary if the word "holiday" are there each day.
at midnight of holiday the tasker send the json http to domoticz switch.
if this domoticz switch is on, goes disable the scene that open my blind everyday by blockly rule.
the day after holiday goes back normal with another tasker rules
TheCondor
Post by TheCondor »
Hi, thanks both for the answer.
I ended with a double check directly in the script:
I set ON timer for all the three hours, after i check for the variable = working + time.hour = 7
or
Variable = holiday + time.hour =8
It's not optimal.... Anyway it works fine since some days...
