Tado.cpp compiler error.....
SiSu82
Post by SiSu82 »
Moving to a fresh install of Ubuntu 16.04 LTS on a vmware machine. Updated everything on Ubuntu and followed the stepps in the installation guide and it worked well until around 67% when it tried to compile the Tado.CPP
Any suggestions?
In file included from /usr/include/c++/5/regex:35:0,
                 from /home/xyzzyx/domoticz/hardware/Tado.cpp:25:
/usr/include/c++/5/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support \
/home/xyzzyx/domoticz/hardware/Tado.cpp: In member function ‘bool CTado::MatchValueFromJSKey(std::__cxx11::string, std::__cxx11::string, std::__cxx11::string&)’:
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:2: error: ‘match_results’ is not a member of ‘std’
  std::match_results<std::string::const_iterator> _Matches;
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:2: note: suggested alternative:
In file included from /usr/include/boost/asio/read_until.hpp:26:0,
                 from /usr/include/boost/asio.hpp:91,
                 from /home/xyzzyx/domoticz/hardware/../main/../tcpserver/TCPClient.h:3,
                 from /home/xyzzyx/domoticz/hardware/../main/../tcpserver/TCPServer.h:4,
                 from /home/xyzzyx/domoticz/hardware/../main/mainworker.h:11,
                 from /home/xyzzyx/domoticz/hardware/Tado.cpp:21:
/usr/include/boost/asio/detail/regex_fwd.hpp:29:7: note:   ‘boost::match_results’
 class match_results;
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:48: error: expected primary-expression before ‘>’ token
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:50: error: ‘_Matches’ was not declared in this scope
/home/xyzzyx/domoticz/hardware/Tado.cpp:581:2: error: ‘regex’ is not a member of ‘std’
  std::regex _reSearch(sKeyName + ": '(.*?)'");
/home/xyzzyx/domoticz/hardware/Tado.cpp:581:2: note: suggested alternative:
In file included from /usr/include/boost/regex_fwd.hpp:27:0,
                 from /usr/include/boost/asio/detail/regex_fwd.hpp:20,
                 from /usr/include/boost/asio/read_until.hpp:26,
/usr/include/boost/regex/v4/regex_fwd.hpp:60:48: note:   ‘boost::regex’
 typedef basic_regex<char, regex_traits<char> > regex;
/home/xyzzyx/domoticz/hardware/Tado.cpp:582:7: error: ‘regex_search’ is not a member of ‘std’
  if (!std::regex_search(sJavascriptData, _Matches, _reSearch)) {
/home/xyzzyx/domoticz/hardware/Tado.cpp:582:52: error: ‘_reSearch’ was not declared in this scope
/home/xyzzyx/domoticz/hardware/Tado.cpp: In member function ‘bool CTado::GetTadoApiEnvironment(std::__cxx11::string)’:
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:2: error: ‘match_results’ is not a member of ‘std’
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:2: note: suggested alternative:
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:48: error: expected primary-expression before ‘>’ token
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:50: error: ‘_Matches’ was not declared in this scope
CMakeFiles/domoticz.dir/build.make:3662: recipe for target 'CMakeFiles/domoticz.dir/hardware/Tado.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/hardware/Tado.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
SweetPants
Re: Tado.cpp compiler error.....
Post by SweetPants »
I think this is related to https://github.com/domoticz/domoticz/pull/2334 I think you should upgrade GCC. I'm using GCC 6.3 on 16.04 LTS
dotms
Domoticz version: git
Post by dotms »
Above is correct. In the development a c++11 feature was used, even though not explicitly specified in the build scripts. Most compilers will compile it anyway.
Problem is that the gcc compiler that comes with Ubuntu 16.04 is rather old and does not handle this gracefully as you discovered. A fix to use the boost libraries instead of the standard c++ libraries has been made, it only needs to be merged into the development tree by a Domoticz project maintainer.
Until this is done the best way to compile is installing a more recent version of gcc (howto: https://gist.github.com/application2000 ... 56315a2d91).
