TomekM512 wrote: Thursday 05 April 2018 19:29
Node is in all cases is 0x0000
Type the same
IDs zeroed usually means inclusion was not done correctly.
I had this problem with some chinese PIRs from Neo-coolcam: I have a z-stick gen5 controller that can be unplugged & used standalone for inclusions, but these devices could not be correctly included this way: Had to keep controller plugged &include from Domoticz, with the device close to controller (was not a problem with a battery powered one that can be unmounted easily, could have been with an AC one already mounted!).
Z-wave inclusions can also be easily messed-up if not done at a few tens of cm from controller and device kept close for a minute or 2, to be sure parameters are setup correctly. If you do not stay close during all this process, you can experience problems like unrecognised device or being misconfigured (leading to device misbehaving or communication problems).
Reason: Inclusions are done with reduced radio power to avoid including devices in the neighborhood and, for secure inclusions, to limit the risk having symmetric crypto key exchanged at this step being intercepted.
After this step, z-wave is quite rock-solid.
