JSON fields with a '-' (hyphen) in their name  [Solved]
rjblake
Post by rjblake »
Help - I'm trying to update some devices using the JSON being returned from a call to a device. However, the fields/variables are all named with a hyphen (e.g. door-state, light-state, etc.). When I try to assign these to a variable in dzVents, (local garage_door = item.json.door-state), I get an error "... attempt to perform arithmetic on field 'door' (a nil value)". I assume this is because of the '-' and trying to subtract state from door. How can I uses this naming convention in dzVents?
dannybloe
Re: JSON fields with a '-' (hyphen) in their name
Post by dannybloe »
item.json['door-state']
rjblake
Post by rjblake »
Many thanks - could not for the life of me work out the required syntax. Too many damn programming languages floating around in my aging brain!
dannybloe
Re: JSON fields with a '-' (hyphen) in their name  [Solved]
Post by dannybloe »
Yup.. just follow this presentation and you're good to go: https://www.lua.org/pil/1.html
