Version: 3.9174
Build Hash: ac7daa5b
Compile Date: 2018-04-03 12:59:46
dzVents Version: 2.4.2
Raspberry pi 3
Hai,
Today I wrote a little script in DzVents to let me know if there was a postal delivery.
(a mercury switch on an old remote doorbell attached to the postal box)
This works nice In combination with a Domoticz off switch so I can 'reset' the ''Postal' state to 'No'.
So far so good.
Next I wanted to know when the delivery was made so I added:
local Time = require('Time')
local currentTime = Time() -- current time
currentTime = currentTime.rawTime
but when I 'display' the variable currentTime with domoticz.notify, domoticz.email or domoticz.log there are no leading zeros.
for instance:
2018-04-03 23:05:14.178 Notification: Mailbox emptied: 23:5:14 uur clearly you can see on left the logtimestamp with and the log message 23:5:14 without a leading zero.
Is there a solution ?
Regards Frank
DzVentz time no leading zero's?
yfands
- Domoticz version: latest B
Re: DzVentz time no leading zero's?
So no fancy solution in Dzventz(?), I reverted back to the old school programming as solution.
local hours = currentTime .hour
local minutes = currentTime .minutes
local postalTime = string.format("%02d:%02d",currentTime .hour,currentTime .minutes)
Frank
Frank
- waaren
Solution / workaround :yfands wrote: Tuesday 03 April 2018 23:41
Regards Frank
local now = Time() -- current time
currentTime = now.rawTime
domoticz.log(tostring(currentTime))Debian buster, bullseye on RPI-4, Intel NUC.
dannybloe
Good catch. I fixed it for dzVents 2.4.4 so rawTime and rawDate have leading zeroes when necessary.
yfands
Hai dannybloe,dannybloe wrote: Wednesday 04 April 2018 20:38 Good catch. I fixed it for dzVents 2.4.4 so rawTime and rawDate have leading zeroes when necessary.
Ok thanks great, but 'have leading zeroes when necessary', do you mean there is gonne be a switch ? yes or no leading zero's if desired?
Frank
dannybloe
Only when below 10 of course.
yfands
