send an email when the doorbell rings and is not opened within 1 minute.
DDuck
Post by DDuck »
I am new to Domoticz.
I have a thin client at home with Windows7 running domoticz.
it is connected with an RF link and Xiaomi gateway, switch, smart switches and door sensors are present.
I have been trying to get a script working that will send me a mail if the front door does not open within 1 minute after someone has pressed the bell
the hard part is to not send a mail if the door opens on time.
		devices = {'Bel', 'Door1'
	execute = function(dz, device)
	  if (device.state == 'On') then
		dz.log('Device ' .. device.name .. ' was changed- so sombody ring it', dz.LOG_INFO)
	    dz.mail('subject', 'message tekst','[email protected]').AfterMin(2)
	  if (dz.devices('Door1').state == 'Open') then
		dz.log('Device ' .. device.name .. ' was changed- so sombody opend the door', dz.LOG_INFO)
        dz.mail.cancelQueuedCommands()
i get this error:
2018-04-04 16:14:15.936 User: Admin initiated a switch command (77/Bel/On)
2018-04-04 16:14:15.962 (Dummy) Light/Switch (Bel)
2018-04-04 16:14:16.670 dzVents: Info: Handling events for: "Bel", value: "On"
2018-04-04 16:14:16.671 dzVents: Info: ------ Start internal script: test-deurbel: Device: "Bel (Dummy)", Index: 77
2018-04-04 16:14:16.671 dzVents: Info: Device Bel was changed- so sombody ring it
2018-04-04 16:14:16.671 dzVents: Error (2.4.2): An error occured when calling event handler test-deurbel
2018-04-04 16:14:16.671 dzVents: Error (2.4.2): ...oticz\scripts\dzVents\generated_scripts/test-deurbel.lua:9: attempt to call field 'mail' (a nil value)
2018-04-04 16:14:16.672 dzVents: Info: ------ Finished test-deurbel
if i thak line 9 out it is line 11 on error. Please Help me understand
Egregius
Domoticz version: v2024.7
Re: send an email when the doorbell rings and is not opened within 1 minute.
Post by Egregius »
Isn't this a dzvents script? Shouldn't this be posted in the dzvents board?
Anyway, in pass2php fairly simple to handle :lol:
<?php
sleep(60);
if(past('doorsensor')<60)mail('Doorbell pressed');
DDuck
Post by DDuck »
Egregius wrote: Wednesday 04 April 2018 18:06 Isn't this a dzvents script? Shouldn't this be posted in the dzvents board?
<?php
sleep(60);
Is the system taking any other commands while waiting/running this script??
DDuck wrote: Wednesday 04 April 2018 16:17 Hi,
if I thake line 9 out it is line 11 on error. Please Help me understand
dz.mail is not dzVents syntax and afterSec / afterMin is not implemented for .email so we need something to help us. My way is to use a uservar for this (see code example)
		Conditional Delayed Email test (dzVents > 2.4.0 )
	on = { devices = { 'Bel' },
	variables = { 'emailTrigger_for_Door1' } -- Need to be defined once via setup -> more options -> uservariables (as integer)
	execute = function(dz, trigger)
	  	if trigger.isVariable then
			if dz.devices('Door1').lastUpdate.secondsAgo < dz.devices('Bel').lastUpdate.secondsAgo then
				-- Door1 opened after Bel rang so no further action necessary
				dz.log("Door1 opened after Bel rang so no further action necessary", dz.LOG_INFO)
				dz.log("Door1 not opened in time sending Email", dz.LOG_INFO)
				dz.email('Hey', 'Why has no one opened the door ??', 'your Email address')
				dz.variables('emailTrigger_for_Door1').set(0).silent()
            -- domoticz Email afterSec not implemented so we need a uservariable to help us
			dz.variables('emailTrigger_for_Door1').set(1).afterSec(60)
DDuck
Post by DDuck »
Hi Waaren,
thanks for your help, the uservar's are a very interesting way of getting to the point.
I'm going to look into them next day's. for now the script is working. many thanks for that.
Egregius
Post by Egregius »
DDuck wrote: Wednesday 04 April 2018 20:00
<?php
sleep(60);
Of course, why wouldn't it?
