I'm trying to configure domoticz to recognize my broadlink RM2. I installed the plugin but my device isn't recognized nor from discover device nor configuring IP address and MAC address manually. I tried rebooting both my device and my Raspberry PI. this is domoticz's log from start to the error.
2018-04-04 15:50:40.975 Domoticz V3.9177 (c)2012-2018 GizMoCuz
2018-04-04 15:50:40.975 Build Hash: 8833e747, Date: 2018-04-03 22:05:17
2018-04-04 15:50:40.976 Startup Path: /home/pi/domoticz/
2018-04-04 15:50:41.019 Sunrise: 06:49:00 SunSet: 19:41:00
2018-04-04 15:50:41.020 Day length: 12:52:00 Sun at south: 13:05:00
2018-04-04 15:50:41.020 Civil twilight start: 06:20:00 Civil twilight end: 20:09:00
2018-04-04 15:50:41.020 Nautical twilight start: 05:46:00 Nautical twilight end: 20:43:00
2018-04-04 15:50:41.020 Astronomical twilight start: 05:11:00 Astronomical twilight end: 21:18:00
2018-04-04 15:50:41.020 EventSystem: reset all events...
2018-04-04 15:50:41.147 PluginSystem: Started, Python version '3.5.3'.
2018-04-04 15:50:41.156 Active notification Subsystems: http (1/14)
2018-04-04 15:50:41.158 WebServer(HTTP) started on address: :: with port 8080
2018-04-04 15:50:41.162 WebServer(SSL) started on address: :: with port 443
2018-04-04 15:50:41.164 Proxymanager started.
2018-04-04 15:50:41.165 Accepting shared server connections via MyDomotiz (see settings menu).
2018-04-04 15:50:41.165 Starting shared server on: :::6144
2018-04-04 15:50:41.165 TCPServer: shared server started...
2018-04-04 15:50:41.166 RxQueue: queue worker started...
2018-04-04 15:50:42.457 PROXY: Authenticate result: success.
2018-04-04 15:50:43.166 Wunderground: Worker started...
2018-04-04 15:50:43.167 (Broadlink) Started.
2018-04-04 15:50:43.167 EventSystem: reset all events...
2018-04-04 15:50:43.168 EventSystem: reset all device statuses...
2018-04-04 15:50:43.385 Python EventSystem: Initalizing event module.
2018-04-04 15:50:43.385 EventSystem: Queue thread started...
2018-04-04 15:50:43.385 EventSystem: Started
2018-04-04 15:50:43.521 PluginSystem: Entering work loop.
2018-04-04 15:50:43.739 (Broadlink) Entering work loop.
2018-04-04 15:50:43.740 (Broadlink) Initialized version 4.0.0, author 'zak45'
2018-04-04 15:50:43.742 (Broadlink) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-04-04 15:50:43.742 (Broadlink) 'DomoticzHash':'8833e747'
2018-04-04 15:50:43.742 (Broadlink) 'Mode2':'C:/BroadlinkRM2'
2018-04-04 15:50:43.742 (Broadlink) 'Mode5':'9000'
2018-04-04 15:50:43.742 (Broadlink) 'Key':'BroadlinkRM2'
2018-04-04 15:50:43.742 (Broadlink) 'HardwareID':'9'
2018-04-04 15:50:43.743 (Broadlink) 'Author':'zak45'
2018-04-04 15:50:43.743 (Broadlink) 'Mode6':'Debug'
2018-04-04 15:50:43.743 (Broadlink) 'Mode3':'RM2'
2018-04-04 15:50:43.743 (Broadlink) 'Version':'4.0.0'
2018-04-04 15:50:43.743 (Broadlink) 'DomoticzVersion':'3.9177'
2018-04-04 15:50:43.743 (Broadlink) 'Mode1':'34:ea:34:43:07:3f'
2018-04-04 15:50:43.743 (Broadlink) 'Port':'0'
2018-04-04 15:50:43.743 (Broadlink) 'Name':'Broadlink'
2018-04-04 15:50:43.743 (Broadlink) 'DomoticzBuildTime':'2018-04-03 22:05:17'
2018-04-04 15:50:43.743 (Broadlink) 'Address':'192.168.9.98'
2018-04-04 15:50:43.743 (Broadlink) 'Mode4':'no'
2018-04-04 15:50:43.743 (Broadlink) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2018-04-04 15:50:43.743 (Broadlink) Device count: 3
2018-04-04 15:50:43.743 (Broadlink) Device: 1 - ID: 23, Name: 'Broadlink - Discovery', nValue: 0, sValue: 'Off'
2018-04-04 15:50:43.743 (Broadlink) Device ID: '23'
2018-04-04 15:50:43.743 (Broadlink) Device Name: 'Broadlink - Discovery'
2018-04-04 15:50:43.743 (Broadlink) Device nValue: 0
2018-04-04 15:50:43.743 (Broadlink) Device sValue: 'Off'
2018-04-04 15:50:43.743 (Broadlink) Device LastLevel: 0
2018-04-04 15:50:43.743 (Broadlink) Device: 2 - ID: 24, Name: 'Broadlink - Discovery Info', nValue: 0, sValue: ''
2018-04-04 15:50:43.743 (Broadlink) Device ID: '24'
2018-04-04 15:50:43.743 (Broadlink) Device Name: 'Broadlink - Discovery Info'
2018-04-04 15:50:43.743 (Broadlink) Device sValue: ''
2018-04-04 15:50:43.743 (Broadlink) Device: 254 - ID: 25, Name: 'Broadlink - Remote', nValue: 0, sValue: ''
2018-04-04 15:50:43.743 (Broadlink) Device ID: '25'
2018-04-04 15:50:43.743 (Broadlink) Device Name: 'Broadlink - Remote'
2018-04-04 15:50:43.744 (Broadlink) Device nValue: 0
2018-04-04 15:50:43.744 (Broadlink) Device sValue: ''
2018-04-04 15:50:43.744 (Broadlink) Device LastLevel: 0
2018-04-04 15:50:43.744 (Broadlink) Pushing 'PollIntervalDirective' on to queue
2018-04-04 15:50:43.744 (Broadlink) Connecting to: 192.168.9.98:34:ea:34:43:07:3f
2018-04-04 15:50:43.744 Error: (Broadlink) Error Connecting to Broadlink device....192.168.9.98
2018-04-04 15:50:43.758 (Broadlink) No ini file :C:/BroadlinkRM2/remote/plugin_remote_9.ini
2018-04-04 15:50:43.758 (Broadlink) Custom Commands for Remote not managed
2018-04-04 15:50:43.758 (Broadlink) Device Number begin to : 2
2018-04-04 15:50:43.758 (Broadlink) Processing 'PollIntervalDirective' message
2018-04-04 15:50:43.758 (Broadlink) Heartbeat interval set to: 30.
2018-04-04 15:50:44.167 MQTT: Connecting to localhost:1883
2018-04-04 15:50:44.269 MQTT: connected to: localhost:1883
2018-04-04 15:50:44.369 MQTT: Subscribed
