HOW TO send an email after, for example, 3min.
hve22
Post by hve22 »
IS there a way to send a email after, for example, 3 minutes when a switch is triggerd.
Re: HOW TO send an email after, for example, 3min.
There are probably more ways to accomplish this. My solution that works with dzVents >= 2.4.0 :
		Delayed Email test ( dzVents >= 2.4.0 )
	devices = { 'emailTestSwitch'} ,
        variables = { 'emailTrigger'}
	execute = function(domoticz, trigger)
		if trigger.isVariable then
			domoticz.email('Hey', 'The Switch state was updated', 'your Email adress')
			domoticz.variables('emailTrigger').set(0).silent()
			domoticz.variables('emailTrigger').set(1).afterSec(5)
Derik
Post by Derik »
mmm is there a option to use this script for sending 1 mail instead of multiple.
I mean now i set my X sensor to send a mail when setpoint y is reached...
Only Domoticz kept sending mails.
I like to use a option to send a mail when setpoint x is reached.
And then perhaps after 10 minutes again when the setpoint is still reached.
Or net when the setpoint is lower then i want..
Hope
Thanks !!
I am not quite sure that I understand what you want but from the sound of it, I guess it should be doable.
If settings -> notifications -> notification intervals does not serve your needs then please elaborate a bit more what you try to achieve
