Thermostat setpoint with % or new device for Humidifier
Recently I start using humidifier in my room when humidity drops to 25%. It is controlled by relay and it works. I used Thermostat setpoint device and it also works but it is confusing set temperature as humidity. So please add posibillity to change label from C to % or create extra new device Humidifier Setpoint.
kimot
- Domoticz version: v3.8153
Re: Thermostat setpoint with % or new device for Humidifier
And dimmer device is not good for this?
It is in percentage setting.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
Mibeus
solution with dimmer is fine, but I dont found how can add dimmer. In my dummy sensor not visible.
For more information. I have foger which I can control with realy. This I have seted in domoticz as switch. '
Same I have added temp and humidity sensor.
For control temperature I using thermostat setpoint, but I need same this utility but for humidity.
Can you help me some one? Thank you.
- waaren
Add as a virtual switch and in the switch tab select edit on the new switch. You will presented with a new page where you can change the switchtype to dimmer.Mibeus wrote: Sunday 29 November 2020 20:39 solution with dimmer is fine, but I dont found how can add dimmer. In my dummy sensor not visible.
Mibeus
Thank you. I see it now:). I must more play with all this settings.waaren wrote: Sunday 29 November 2020 22:09Add as a virtual switch and in the switch tab select edit on the new switch. You will presented with a new page where you can change the switchtype to dimmer.Mibeus wrote: Sunday 29 November 2020 20:39 solution with dimmer is fine, but I dont found how can add dimmer. In my dummy sensor not visible.
Mibeus
Okay,
I have one more question: Now I have Dimmer and humidity sensor and relay for control foger. But in blocky I dont know how program for correct function.
With Thermostat SetPoint I do it an work fine. But when I use as value for compare data from sensor and setted dimmer, nothing it do :{
- Domoticz version: 2025.1
A new setpoint has been introduced in latest beta. See viewtopic.php?p=307044#p307044
