how to transfert data
multinet
Post by multinet »
Hello
I accidentally delete a device and I lost all my history (wind device)
I just face up the delete today
So, recreate my device and I want to know if it is possible to transfert all date from my backup from this wind device to the new I created today (and I don't want to reuse all my backup because I will lost all data for 2 weeks for all other devices)
Is it possible via sql ?
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
Re: how to transfert data
This should be possible but I have not tested it yet.
!! make sure you have a backup of your current domoticz.db !!
sudo sqlite3 "your backup with old data domoticz".db
.output myWind_Calendar
.dump Wind_Calendar
.q
edit myWind_Calendar
only keep INSERT INTO lines for your device. First number after "(" is device number. Delete other lines.
example line: INSERT INTO "Wind_Calendar" VALUES(3,208.77,51,123,106,170,'2017-10-21');
change old device number into new device number
save edited file
stop domoticz
sudo sqlite3 domoticz.db < myWind_Calendar
start domoticz
