Outdoor light at nighttime
jandirkv
- Domoticz version: 3.9117
Hello I'm new to DZvents scripting. I have Lots of VBA experience but I cant get the sintax right. I want a script that turns on my outdoor light 15 minutes before Sunset and 15 minutes after Sunset. But when I use Siri to turn off my lights when i go to bed and want de outdoor light to turn on again. I made the following script.
timer = { 'every 1 minutes'}
execute = function(domoticz,timer)
if (domoticz.time > '30 minutes before sunset' and domoticz.time < '15 minutes after sunrise' and domoticz.devices('Lamp Buiten').state) == 'Off' then
domoticz.devices('Lamp Wand 1').switchSelector(55)
if (domoticz.time > '16 minutes after sunrise' and domoticz.time < '16 minutes before sunset' and domoticz.devices('Lamp Buiten').state) == 'On' then
domoticz.devices('Lamp Buiten').switchOff()
Domoticz log give the following error: attempt to compare string with table.
I would appreciatie the help.
SweetPants
Re: Outdoor light at nighttime
Please put your code between code blocks to make it more readable
jandirkv
NuNca
think the problem is that == 'Off' and == 'On' are outside the ).jandirkv wrote: Wednesday 28 February 2018 22:17Code: Select all
return { on = { timer = { 'every 1 minutes'} }, execute = function(domoticz,timer) if (domoticz.time > '30 minutes before sunset' and domoticz.time < '15 minutes after sunrise' and domoticz.devices('Lamp Buiten').state) == 'Off' then domoticz.devices('Lamp Wand 1').switchSelector(55) else if (domoticz.time > '16 minutes after sunrise' and domoticz.time < '16 minutes before sunset' and domoticz.devices('Lamp Buiten').state) == 'On' then domoticz.devices('Lamp Buiten').switchOff() end end end }
try this.
timer = { 'every minute'}
if (domoticz.time > '30 minutes before sunset' and domoticz.time < '15 minutes after sunrise' and domoticz.devices('Lamp Buiten').state == 'Off') then
if (domoticz.time > '16 minutes after sunrise' and domoticz.time < '16 minutes before sunset' and domoticz.devices('Lamp Buiten').state == 'On') then
jandirkv
Thank you for your help nunca. I tried your code but still no luck. Log still gives the following error: 'attempt to compare string with table'
NuNca
No problem, I didn't check the rest of the code. but the time rules don't seem to check out.
Here is another try, did test it and seems to work for me.
if (domoticz.time.matchesRule('between 30 minutes before sunset and 15 minutes after sunrise') and domoticz.devices('Lamp Buiten').state == 'Off') then
if (domoticz.time.matchesRule('between 16 minutes after sunrise and 16 minutes before sunset') and domoticz.devices('Lamp Buiten').state == 'On') then
tlpeter
Try something like this (this is not a tested and used script so you need to fix it for your self!!!)
active = true,
devices = {'Keuken'}
execute = function(domoticz, roomSwitch)
if
(roomSwitch.state == 'On') then
domoticz.devices('Keukenkastjes wit').dimTo(100)
elseif
(roomSwitch.state == 'Off') and (domoticz.time.matchesRule('at sunset-22:00')) then
domoticz.devices('Keukenkastjes wit').dimTo(20)
elseif
(roomSwitch.state =='Off') and (domoticz.time.matchesRule('at 22:01-23:59')) then
domoticz.devices('Keukenkastjes wit').dimTo(0)
elseif
(roomSwitch.state =='Off') and (domoticz.time.matchesRule('at 00:00-sunset')) then
jandirkv
I tried it but it did not work for me. The outdoorlamp was not turned on this evening. I see you used the matchesrules Command. Is there a user manual besides the very limited one on the domoticz site where I can find commands like that.NuNca wrote: Thursday 01 March 2018 23:39 No problem, I didn't check the rest of the code. but the time rules don't seem to check out.
return { on = { timer = { 'every minute'} }, execute = function(domoticz,timer) if (domoticz.time.matchesRule('between 30 minutes before sunset and 15 minutes after sunrise') and domoticz.devices('Lamp Buiten').state == 'Off') then domoticz.devices('Lamp Wand 1').switchSelector(55) else if (domoticz.time.matchesRule('between 16 minutes after sunrise and 16 minutes before sunset') and domoticz.devices('Lamp Buiten').state == 'On') then domoticz.devices('Lamp Buiten').switchOff() end end end }
jandirkv
Thank you all for the help. I finally figured it out. I was running the stable version and that version had dzvents 2.2.0 which did not support the between rule. I update to the beta and now al my scripts work.
Users browsing this forum: hemant5400z and 1 guest
