V_VAR1 in latest Domoticz
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
Hello
Does anyone know if Domoticz now can handle V_VAR1-V_VAR3?
I am using MySensors 2.3.0alpha
Alex
sincze
Domoticz version: 2024.4
Re: V_VAR1 in latest Domoticz
Post by sincze »
You can use them in a specific way, but what exactly are you trying to achieve as you won't actually find them in domoticz. as far as I know.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
kimot
Domoticz version: v3.8153
Post by kimot »
V_VAR are used only for store specific MySensor node data into Domoticz and read them back from Domoticz.
( When botting MySensors etc, ). You cannot change V_VAR by Domoticz itself.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
alexsh1
Post by alexsh1 »
sincze wrote: Thursday 29 March 2018 20:02 You can use them in a specific way, but what exactly are you trying to achieve as you won't actually find them in domoticz. as far as I know.
A lightning sensor. I have intensity, which is not available in MySensors so V_VAR1 has to be used.
sincze
Post by sincze »
alexsh1 wrote: Friday 30 March 2018 16:17
mmm indeed. If I remember correctly V_VAR1 can be used to tell the value to the controller, however Domoticz will not display it in a sensor.Same issue with V_CUSTOM. Back in the days i needed to misuse a different V_**** like V_WATTS to get the value into Domoticz and live with it.
A brave guy posted this to modify Domoticz Mysensors.cpp:
https://forum.mysensors.org/topic/3373/ ... ppearing/4
I did not try it.
Sorry for the not so positive answer. :|
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
