IDIOT ALERT: Any way to recover from flashing the wrong firmware?
velkrosmaak
Post by velkrosmaak »
In a slightly stoned stupor and at 2am last night, I stupidly flashed the RFXRec firmware onto my RFXTRX433.
I know. Despite the warning on the firmware flashing page. I got confused between Type 1 and Type 2 and went with the one that was neither - which happens to be for RFXRec, which I believe only receives signals.
Other than trying to reflash the correct firmware (which fails at the bootloader) is there any way I can recover from this? I've ordered the (much, much cheaper) Sonoff 433Mhz RF Bridge, but have grown attached to the RFXTRX433 over the years.
I would owe you some serious beers if you can help. Thanks!
b_weijenberg
Re: IDIOT ALERT: Any way to recover from flashing the wrong firmware?
Post by b_weijenberg »
It should not be a problem to flash another type of firmware even after the RFXrec firmware.
If the flash procedure was interrupted it is possible that the bootloader cannot be accessed by a software command. try with RFXflash.
Please contact support rfxcom for the recovery procedure if flasing is not possible with RFXflash.
RFX-433, RFX-433EMC, RFX-868
velkrosmaak
If that's the case, that's great! I will try that immediately when I get back from work. I only tried it through the Domoticz UI, but will try with RFXflash on a windows box.
Fingers crossed! Thanks so much for the lead!
velkrosmaak
b_weijenberg wrote: Tuesday 27 March 2018 8:38 It should not be a problem to flash another type of firmware even after the RFXrec firmware.
You sir, are a legend. Flashed it from a Windows 10 machine, and hey presto - we're back in business. Thank you!
