openUrl (
bing69
openUrl (
Post by bing69 »
Another problem instead of "os.execute (" curl ") I try to fit" openUrl ("https:" to.
Get an error:
2017-08-20 09: 21: 16,548 Error: dzVents: Error: An error occured when calling event deals testpushover
2017-08-20 09: 21: 16,548 Error: dzVents: Error: ... oticz / scripts / dzVents / generated_scripts / testpushover.lua: 13: attempt to call global 'openUrl' (a nil value)
My full code is:
    active = true,
        devices = {
            'Test Dummy'
    execute = function(domoticz, TestDummy)
            local DeurBergingBuiten = domoticz.devices('Deur berging buiten')
            local LampBerging = domoticz.devices('Lamp berging')
        if (TestDummy.state == 'On')  then
            openUrl('https://api.telegram.org/botxxxxxxx:mycode/sendMessage?chat_id=xxxxxxx&text=Test van Ad')
Or can I use osexecute better?
Freemann
Domoticz version: >=Béta
Re: openUrl (
Post by Freemann »
Docs says
"openURL(url): Function. Have Domoticz 'call' a URL."
So URL should be in uppercase.
So this should, according to the docs, work;
    active = true,
        devices = {
            'Test Dummy'
            -- openUrl('https://api.telegram.org/botxxxxxxx:mycode/sendMessage?chat_id=xxxxxxx&text=Test van Ad')
               openURL('https://api.telegram.org/botxxxxxxx:mycode/sendMessage?chat_id=xxxxxxx&text=Test van Ad')
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
bing69
Re: openUrl (
Post by bing69 »
Freemann wrote: Sunday 20 August 2017 9:58 Docs says
    active = true,
        devices = {
            'Test Dummy'
Thank you, but that makes no difference
Doler
Re: openUrl (
Post by Doler »
Try domoticz.openURL(url).
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
bing69
Re: openUrl (
Post by bing69 »
In a other tread i found domoticz.openURL en that works!!!!
bing69
Re: openUrl (
Post by bing69 »
Doler wrote: Sunday 20 August 2017 11:30 Try domoticz.openURL(url).
Just one minute later found in another thread, thanks! :D
jandirkv
Domoticz version: 3.9117
Re: openUrl (
Post by jandirkv »
Hello Bing 69. Can you tell what post that is. I also want to use this for my pilot home automation notifications
Re: openUrl (
