Hello, I want to transfer my Domoticz application from a Windows 10 Orbsmart AW-07 to the new AW-09 Mini-PC. I am using the last Domoticz Beta and Firefox 59.01.
My problem: If I do a database backup via "Setup >Settings>Backup/Resore", I only get a zero bytes.php file, no .db backup.
Is there another simple way to transfer a Windows 10 Domoticz installation to a new PC?
Thanks for the help
Transfer to new Hardware Problem
Re: Transfer to new Hardware Problem
Addional information: Also the "Auto Update" Folders are empty, even Auto Update is enabled, but I would prefere a manual Backup to transfer Domotics to the new PC. Are there any settings in Firefox necessary to safe the Backup as a ".db" and not as a ".php" ?
Hope that somebody can help. Thanks !
Thank you, but even after reading the instructions the further procedure is not quite clear to me. To install the Windows version and updates of Domoticz I always use the setup.exe file. Hope you can answer me this:
Do I need to reinstall with a compiled version and then change permissions and security settings?
What kind of changed settings do I have to make? I hope there is also an easier way to get a backup of the running system without compiling.
Can I install Domoticz on the new PC only with the Setup.exe?
Until now, Domoticz always ran as an "application", so I should install it as a "service" in the future?
Thanks for your support !
Have you tried any other web browsers (just asking the obvious here)?
Im not running domoticz on a windows box, but you should be able to copy the db file manually from the domoticz folder.
..\domoticz\domoticz.db
Make a copy of your old domoticz folder as a backup as well, just in case.
Try using Chrome, Firefox does the same problem as 0 bytes backup db, but with chrome i do not have any problems.
Thank you for the advice,
strangely enough, even in my new Windows10 installation (Run as a application) the folder ..\Domoticz\Domoticz.db is not available. Also the backup folders (Daily, Hourly, Monthly) are empty, even with Chrome only a 0Byte.PHP backup file is saved.
I installed the stable Domoticz version first to be on the safe side. As no backup was available or possible again, I updated with the beta update version from March 28th. As there was no change in the backup behavior, I tested the latest beta updates after a few days. There was also no change, but this additional problem:
On the Browser pages "Switches" and "Dashboard" only the first 3 installed devices are displayed, the remaining 25 are missing. In the hardware list and in the devices everything is present and all switches/devices and Blockly rules are working. (except backup).
It doesn't matter which PC, laptop, tablet, smartphone, internal or external and what browser (cache is always cleaned) I access to Domoticz (internal IP directly, or via the router), only the first 3 devices are displayed. When I reinstall the beta update from 28.03. everything is OK (except the backup).
For me looks like a software problem. Anybody have an idea?
