Controlling Toon [HACKED] from Domoticz
Johan1974
Re: Controlling Toon [HACKED] from Domoticz
Post by Johan1974 »
glsf91 wrote: Friday 23 March 2018 10:29
Johan1974 wrote: Friday 23 March 2018 10:18
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
I don't have these 2 lines. Try without them.
Otherwise add:
print(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
just before this curl line. And try the printed string in the browser.
Can you sent me your script.? I will try that..
Johan1974
Post by Johan1974 »
Johan1974 wrote: Friday 23 March 2018 11:25
When I do:
in the browser, is the resultat:
{"result": "error", "error":"no handler for action 'getThermostatInfo', ToonIP)))'"}
glsf91
Post by glsf91 »
Johan1974 wrote: Friday 23 March 2018 11:33
When I do:
You have to put this print line in the script.
Then wait until the script executes and then the url is printed in the log. Try that printed url in the browser.
Johan1974
Post by Johan1974 »
glsf91 wrote: Friday 23 March 2018 11:38
When I do:
I have in the script now:
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
and the error is in the log:
2018-03-23 11:52:40.965 Error: EventSystem: in ToonGetInfo: [string "-- Time script runs every minute, intended to..."]:23: unexpected symbol near ')'
2018-03-23 11:52:43.395 Error: EventSystem: in ToonGetInfo: [string "-- Time script runs every minute, intended to..."]:23: unexpected symbol near ')'
2018-03-23 11:52:50.875 Error: EventSystem: in ToonGetInfo: [string "-- Time script runs every minute, intended to..."]:23: unexpected symbol near ')'
2018-03-23 11:52:51.009 Error: EventSystem: in ToonGetInfo: [string "-- Time script runs every minute, intended to..."]:23: unexpected symbol near ')'
glsf91
Post by glsf91 »
Johan1974 wrote: Friday 23 March 2018 11:54
When I do:
Sorry, remove one ) at the end of the print line:
Johan1974
Post by Johan1974 »
glsf91 wrote: Friday 23 March 2018 12:19
The same error.. :(
2018-03-23 12:26:26.785 Error: EventSystem: Warning!, lua script ToonGetInfo has been running for more than 10 seconds
glsf91
Post by glsf91 »
Johan1974 wrote: Friday 23 March 2018 12:28
The same error.. :(
What is the printed string ?
And try without this line:
Johan1974
Post by Johan1974 »
glsf91 wrote: Friday 23 March 2018 12:33
The same error.. :(
Without that line, same error:
2018-03-23 13:10:54.466 Error: EventSystem: Warning!, lua script ToonGetInfo has been running for more than 10 seconds
Johan1974
Post by Johan1974 »
Johan1974 wrote: Friday 23 March 2018 13:12
The same error.. :(
And this is the message if I change the temp to 20 degrees:
2018-03-23 14:05:25.535 User: Johan initiated a SetPoint command
2018-03-23 14:05:25.650 dzVents: Setting Toon setpoint to 22.00
2018-03-23 14:05:25.651 EventSystem: Fetching url...
2018-03-23 14:05:25.651 EventSystem: Script event triggered: ToonSetPoint
2018-03-23 14:05:25.660 dzVents: curl http://192.168.1.36/happ_thermstat?action=getThermostatInfo
2018-03-23 14:05:25.751 dzVents: Updating thermostat sensor to new set point: 20
2018-03-23 14:05:25.751 dzVents: Updating Toon burner info
2018-03-23 14:05:25.753 EventSystem: Sending SetPoint to device....
2018-03-23 14:05:35.656 Error: EventSystem: Warning!, lua script ToonGetInfo has been running for more than 10 seconds
Johan1974
Post by Johan1974 »
I saved ToonGetInfo in the events as TIME, and ToonSetPoint as DEVICE..
Now is Domoticz not freezing, and it works perfect..
Sometime's I see at the log the message:
But it is working now better.
Thanks for your help glsf91 !!! :D :D :D :D
maikelvds
Domoticz version: 4.9700
Post by maikelvds »
FunFair wrote: Tuesday 20 March 2018 7:24 The php script doesnt need names. Only idxnumbers.
What is the output when you manually run the script?
Is the script executable?
When I run "chmod +x /home/pi/domoticz/scripts/p1_meter/gas_data_json.php" in Putty, I go directly to the next line. So no fault or something, is that correct? I don't see anything further...
When I run in manually:
pi@raspberrypi:~/domoticz/scripts/p1_meter$ ./gas_data_json.php
-bash: ./gas_data_json.php: /usr/bin/php: bad interpreter: No such file or directory
pi@raspberrypi:~/domoticz/scripts/p1_meter$ sudo ./gas_data_json.php
sudo: unable to execute ./gas_data_json.php: No such file or directory
I installed php5-curl... is that the problem maybe?
maikelvds
Post by maikelvds »
maikelvds wrote: Thursday 29 March 2018 21:15 I installed php5-curl... is that the problem maybe?
I re-installed this, and also installed php5 (Without curl)....
Now it is working!!
patzzz
Post by patzzz »
I own a Toon which is now without a Eneco subscription. Now, I was wondering whether it is possible to use the Toon the other way around; so controlling Domoticz from my Toon.
Because after all I do like the form factor, touch screen et cetera from the Toon unit.
Please advice, thanks.
FunFair
Post by FunFair »
patzzz wrote: Friday 06 April 2018 23:23 I own a Toon which is now without a Eneco subscription. Now, I was wondering whether it is possible to use the Toon the other way around; so controlling Domoticz from my Toon.
If your Toon is rooted you can use this.
https://www.domoticaforum.eu/viewtopic. ... 35bf881dfd
if not, root your Toon first :)
jozg
Post by jozg »
Hello All,
I'm using a script to get the temperature from the toon into domoticz from this forum.
I've tried different type of scripts DZVents and also LUA.
But sometimes, my toon is losing it's wifi connection, wich is not a problem for me.
The only thing is that the script is freezing domoticz with this error log: Error: EventSystem: Warning!, lua script GJK_Script_toon_OK has been running for more than 10 seconds.
The biggest problem is, that domoticz freezes up, until the wifi connection from the Toon is restored.
within the freeze i cannot switch my lights anymore, and that's a problem ;-)
Is there a way to make the script failsafe over a disconnected toon?.
Thanks for helping.
Regards,
glsf91
Post by glsf91 »
jozg wrote: Monday 09 April 2018 13:20 But sometimes, my toon is losing it's wifi connection, wich is not a problem for me.
Yes, with https://www.domoticz.com/wiki/DzVents:_ ... P_requests
Or make a 2 stage process:
1. get data in background process
2. process data
Example:
-- This script retrieves data from the Internet without risking to lock the Domoticz event system.
local ResultFile = '/var/tmp/tmpknmi.txt' -- Temporary file to store the servers response
local fetchIntervalMins = 5 -- (Integer) (Minutes, Range 5-60) How often the data shall be retrieved
local scriptVersion = '1.0.0'
local station = 267
local meanTemperatureInside = 18
local function round(num, idp)
   local mult = 10^(idp or 0)
   return math.floor(num * mult + 0.5) / mult
	active = true,
	logging = {
		level = domoticz.LOG_INFO, -- Uncomment to override the dzVents global logging setting
		marker = 'Graaddagen '..scriptVersion
		timer = {   'at 6:05-6:07',
		            'at 7:05-7:07',
		            'at 8:05-8:07',
		            'at 9:05-9:07',
		            'at 10:05-10:07',
		            'at 11:05-11:07',
		            'at 12:05-12:07',
		            'at 13:05-13:07',
		            'at 14:05-14:07',
		            'at 15:05-15:07',
		            'at 16:05-16:07',
		            'at 17:05-17:07'
		    } -- warning: don't change the last number 5 and 7; at every minute just for debugging
	    -- Only update if last update is yesterday
	    if ( domoticz.devices('Graaddagen').lastUpdate.hoursAgo <= 12 ) then
	        domoticz.log('Update already done today, end script', domoticz.LOG_INFO)
            return
		-- Every 5 minutes, call the URL and exit.
		-- The following minute, return to read the result file
		local callUrl = false
		if (os.date('*t').min % fetchIntervalMins) == 0 then
			callUrl = true
		elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
			--return
        previousday = os.date('%Y%m%d', os.time() - 60*60*24)
		if callUrl then
			local url = 'http://projects.knmi.nl/klimatologie/daggegevens/getdata_dag.cgi'
			startdate = os.date('%Y%m%d', os.time() - 2*60*60*24)
			local data = 'vars=TG&start='..startdate..'&end='..previousday..'&stns='..station
			domoticz.log('Requesting data from the knmi server...', domoticz.LOG_INFO)
			domoticz.log('URL used: '..url, domoticz.LOG_DEBUG)
			domoticz.log('DATA used: '..data, domoticz.LOG_DEBUG)
			os.execute('curl --data "'..data..'" -s "'..url..'" > '..ResultFile..'&')
			return -- Nothing more to do for now, we'll be back in a minute to read the data!
		---loads a json file with the provided name and returns it as a table (if it exists)
		local function readLuaFromFile(fileName)
		    local month = tonumber(os.date('%m'))
		    if ((month >= 4) and (month <= 9)) then
		        weegfactor = 0.8
		    elseif ((month == 3) or (month == 10)) then
		        weegfactor = 1.0
                weegfactor = 1.1
			local file = io.open(fileName, 'r')
			if file then
        	    while true do
                    local line = file:read("*line")
                    if not line then break end
                    if debug then domoticz.log('Line:'..line, domoticz.LOG_DEBUG) end
                    -- skip lines starting with #
                    if not string.find(line, "#", 1) then
                        linestation, linedate, linegraden = string.match(tostring(line), '([0-9]*),([0-9]*), *([-0-9]*)')
                        domoticz.log('linestation:'..linestation, domoticz.LOG_DEBUG)
                        domoticz.log('linedate:'..linedate, domoticz.LOG_DEBUG)
                        domoticz.log('linegraden:'..linegraden, domoticz.LOG_DEBUG)
                        graden = tonumber(linegraden)/10
                        domoticz.log('graden:'..graden, domoticz.LOG_DEBUG)
            			difference = os.difftime (linedate,previousday)
                        domoticz.log('previousday:'..previousday, domoticz.LOG_DEBUG)
                        domoticz.log('difference date:'..difference, domoticz.LOG_DEBUG)
	                    -- get only line from yesterday
                        if (difference == 0 ) then
                            io.close(file)
                            if graden >= meanTemperatureInside then
                                return 0
                            return round((meanTemperatureInside - graden) * weegfactor,0)
				io.close(file)
			return nil
		local graadgraden = readLuaFromFile(ResultFile)
		if not graadgraden then
			domoticz.log('Could not read data from file or not data for yesterday available: '.. ResultFile, domoticz.LOG_ERROR)
			return
		domoticz.log('Result graaddagen: '..graadgraden, domoticz.LOG_INFO)
		--domoticz.devices('Graaddagen').dump()
		domoticz.devices('Graaddagen').updateCustomSensor(graadgraden)
jozg
Post by jozg »
Hello Glsf,
I'm trying to get the openurl working in the given script from this forum, but i'm no scripter ;-)
This is the script i use, and the 2 lines with -- in front, that's a try from me to get it working, but it's not.
When i uncomment this line: local handle = assert(io.popen(string.format(domoticz.openURL('http://192.168.1.75/happ_thermstat?acti ... mostatInfo'))))
i receive errors:
2018-04-09 20:50:00.182 Error: dzVents: Error: /home/pi/domoticz/scripts/dzVents/generated_scripts/GJK.lua:22: bad argument #1 to 'format' (string expected, got no value)
Can you please look at the script?.
		timer = {
			'every minute'
	execute = function(domoticz)
        local ToonThermostatSensorName = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
        local ToonTemperatureSensorName = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
        local ToonScenesSensorName  = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
        local ToonAutoProgramSensorName = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
        local ToonProgramInformationSensorName = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
        local ToonIP = domoticz.variables('UV_ToonIP').value
        local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
        -- Handle json
        --local json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")()  -- For Windows
        local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
--          local handle = assert(domoticz.openURL('http://192.168.1.75/happ_thermstat?action=getThermostatInfo'))
--        local handle = assert(io.popen(string.format(domoticz.openURL('http://192.168.1.75/happ_thermstat?action=getThermostatInfo'))))
        local ThermostatInfo = handle:read('*all')
        handle:close()
        local jsonThermostatInfo = json:decode(ThermostatInfo)
        if jsonThermostatInfo == nil then
            return
        local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
        local currentProgramState = tonumber(jsonThermostatInfo.programState)
            if currentProgramState == 0 then currentProgramState = 10 -- No
                elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
                elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
        local currentActiveState = tonumber(jsonThermostatInfo.activeState)
            if currentActiveState == -1 then currentActiveState = 50 -- Manual
                elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
                elseif currentActiveState == 1 then currentActiveState = 30 -- Home
                elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
                elseif currentActiveState == 3 then currentActiveState = 10 -- Away
        local currentNextTime = jsonThermostatInfo.nextTime
        local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
        local currentBoiletSetPoint = jsonThermostatInfo.currentInternalBoilerSetpoint
        -- Update the thermostat sensor to current setpoint
        if domoticz.devices(ToonThermostatSensorName).setPoint*100 ~= currentSetpoint*100 then
            domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
            domoticz.devices(ToonThermostatSensorName).updateSetPoint(currentSetpoint).silent()
        -- Update the temperature sensor to current room temperature
--        if domoticz.round(domoticz.devices(ToonTemperatureSensorName).temperature, 1) ~= domoticz.round(currentTemperature, 1) then
            domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
            domoticz.devices(ToonTemperatureSensorName).updateTemperature(currentTemperature)
--        end
        -- Update the toon scene selector sensor to current program state
        if domoticz.devices(ToonScenesSensorName).level ~= currentActiveState then  -- Update toon selector if it has changed
            domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
            domoticz.devices(ToonScenesSensorName).switchSelector(currentActiveState).silent()
        -- Updates the toon auto program switch
        if domoticz.devices(ToonAutoProgramSensorName).level ~= currentProgramState then -- Update toon auto program selector if it has changed
            domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
            domoticz.devices(ToonAutoProgramSensorName).switchSelector(currentProgramState).silent()
        -- Updates the toon program information text box
        if currentNextTime == 0 or currentNextSetPoint == 0 then
            ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
            ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
        if domoticz.devices(ToonProgramInformationSensorName).text ~= ToonProgramInformationSensorValue then
            domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
            domoticz.devices(ToonProgramInformationSensorName).updateText(ToonProgramInformationSensorValue)
Thanks.
Regards,
Smiggel
Post by Smiggel »
I am have a secondhand toon at home. And when I boot the device I notice I have to activate it. I think the Toon was set to factory defaults. I can not do anything with it now.
Will this script unlock/activate my Toon as well?
FunFair
Post by FunFair »
Smiggel wrote: Wednesday 11 April 2018 7:52 Hi,
This script is for rooted toons. You can't activate it with this. If you havent rooted your toon call eneco.
If they wont help visit https://www.domoticaforum.eu/viewforum.php?f=87 and root it. Then you can manually activate it by changing some files.
Smiggel
Post by Smiggel »
FunFair wrote: Saturday 14 April 2018 6:53
Thanks! Will look into it. :-)
