timer trigger
devros
timer trigger
Post by devros »
hello i did simple script that shoud write to log, when is some device on or off at specific time
but only START TEST is displayed on log
tried few things but cant figure out what could be wrong
thanks
    active = true,
        timer = {'at 23:09'}
    execute = function(domoticz)
        domoticz.log('START_TEST', domoticz.LOG_FORCE)
        if (domoticz.devices(472).state == 'on') then
			domoticz.log('on', domoticz.LOG_FORCE)
        elseif (domoticz.devices(472).state == 'off') then
            domoticz.log('off', domoticz.LOG_FORCE)
when i add code to report state
domoticz.log(domoticz.devices(472).state, domoticz.LOG_FORCE)
in log is: dzVents: !Info: On
Re: timer trigger
State returns the string On or Off (case matters)
devros
Re: timer trigger
Post by devros »
waaren wrote: Thursday 22 March 2018 23:37 State returns the string On or Off (case matters)
Thanks :) that was sooo simple
dannybloe
Re: timer trigger
Post by dannybloe »
You can also do: if (domoticz.devices(472).active) then ...
That will internally check for On/Off, Open/Close etc.
