Yes, this evening I'll try with english tablet.Madgeni wrote: Wednesday 21 March 2018 18:10 The Test works, but it does seem to cache results in a cookie - which can lead to false results.
Your setup seems fine - and Controlicz sends back a response to Google, the discoveries aren't timing out, they range between 6 and 11 seconds. There is a hard limit on devices with Google, but i thought it was 150, so don't think it's that.
Can you try the English language change?
Maybe sign the times I test the site and the app so you can check the logs on your server.
I will let you know,
Thanks again
