Adding a Dome Water shut off to Domoticz
rlschulz
Domoticz version: 3.5877
Post by rlschulz »
I have found this information about the valve:
https://github.com/OpenZWave/open-zwave ... 2400635e0b
This is the manual to it:
https://s3.amazonaws.com/shopify-custom ... Manual.pdf
It appears in Domoticz as
008 (0x08) Water Shut Off Unknown: id=021f Unknown: type=0003, id=0002+ Unknown: id=021f 0x0002 0x0003 2018-03-21 01:06:18
I can't control it from the application and would like some ideas on how I could make that happen.
Thank you.
davidaguilar10
Re: Adding a Dome Water shut off to Domoticz
Post by davidaguilar10 »
hi friend, did you can to solve the problem? i have the same problem..
rlschulz
Post by rlschulz »
I have not found a solution yet. It appears in the Hardware, but not in the devices.
