Anyone any recomendations for a water leakage sensor working for RFXcom / Domoticz ?
I got one of these https://www.banggood.com/DY-SQ100B-Wate ... rehouse=CN but no luck seeing it with the RFXcom. I have all the common protocols enabled and have not seen it as a sensor.
Is there a debug mode to turn on so we can add the decode logic or will I have to use my RTL433 SDN antenna instead ?
Water Leakage Sensors
kevster
Re: Water Leakage Sensors
No one any ideas ?
Read my post.
viewtopic.php?f=44&t=19294
ResetElonex
I also got one of these. Solution was simple if you know; put the jumper on the inside in the open position. It will then be recognized as Lighting4 by RFXCOM.
FYI; it only switches on (repeatedly), not off. So it might be useful to have it switch a virtual switch, instead of directly using it for doing actions.
kevster
Never saw the email thread response. Ill have to dig it out now and try it ! Thanks
