Slider change or on/off button change
pvklink
Domoticz version: latest b
Post by pvklink »
I have finished my first upgrade from LUA to dzvents scipt
I only have one issue left.
I have a switch with volumeslider. With lua it was
if (devicechanged[RECEIVER_VOLUME] == 'On') then .. do things belonging to on button
Elsif (devicechanged[RECEIVER_VOLUME] == 'Off') then do things belonging to off button
Else was a volume change...
I tried to migrate this, but only ON or OFF works and a volume change does not work, it takes the current_state on or off!
Someone an idea ?
i marked the else tree where the volumechange was coded with: --- FROM HERE IT DOES NOT WORK WHEN VOLUME IS CHANGED
   active = true,
		devices = {
			'denon_volume'
execute = function(domoticz, RECEIVER_VOLUME)
    local scriptnaam = 'dztest_volume'
    local TVSTATUS = domoticz.devices('tv')        -- switch met tv status
    local RECEIVER_SOURCE = domoticz.devices('denon_source')                                                -- switch met DENON devices
    local RECEIVER_MIXER = domoticz.devices('denon_mixer')                                                -- switch met DENON mixer
    local RADIO_SENDER = 'denon_radio'        -- switch met DENON radio zender
    local IPTV = domoticz.variables('iptv').value                                                           -- ip adress tv
    local DENONSTATUS = domoticz.variables('denonstatus')                                                   -- USER variabele in domoticz waar DENON status wordt bijgehouden
    local MAXLEVEL = 30        -- MAximaal volume DENON
    domoticz.log('PRG: ' ..scriptnaam ..' tv:' .. IPTV .. ' Status:' .. TVSTATUS.state)                     -- voor debugging
    if (RECEIVER_VOLUME.state == 'On') then        -- denon wordt AAN gezet
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON" );            -- zet denon aan
        DENONSTATUS.set('On')        -- zet uservariabele aan
        domoticz.log('PRG: ' ..scriptnaam ..': denon is aangezet')                                              -- debugging
	    if (TVSTATUS.state == 'On') then        --TV staat AAN
            RECEIVER_SOURCE.switchSelector(20)        -- zet versterker op tv             .afterSec(2)
            RECEIVER_MIXER.switchSelector(10)        -- set versterker op stereo
            domoticz.log('PRG: ' ..scriptnaam ..': denon op tv gezet')                                              -- debugging
        elseif (TVSTATUS.state == 'Off') then        --TV staat UIT
            RECEIVER_SOURCE.switchSelector(10)        -- zet versterker op RADIO         .afterSec(2)
            RADIO_SENDER.switchSelector(10)        -- set radio zender sky
            RECEIVER_MIXER.switchSelector(20)        -- set versterker op mch stereo
            domoticz.log('PRG: ' ..scriptnaam ..': denon op radio gezet')                                           -- debugging
        else        --TV heeft geen status
            domoticz.log('PRG: ' ..scriptnaam ..': Geen tv status bekend')                                      -- debugging
    elseif  (RECEIVER_VOLUME.state == 'Off') then                                                           -- denon wordt UIT gezet
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF" );           -- zet denon uit
        DENONSTATUS.set('Off')        -- zet uservariabele aan
        domoticz.log('PRG: ' ..scriptnaam ..': denon is uitgezet')                                              -- debugging
    else        -- denon VOLUME wordt veranderd
        domoticz.log('PRG: ' ..scriptnaam ..': VOLUME aangepast')                                              -- debugging
         if (DENONSTATUS == 'Off') then        -- als denon uitstaat
        NewLevel = RECEIVER_VOLUME.volume - 80 ;                                                            -- Apply offset from absolute to relative
        if tonumber(NewLevel) > MAXLEVEL then                                                               -- Peter toegevoegd volume maxlevel
            NewLevel = MAXLEVEL        -- maximaal geluidsniveau nog checken of dit wel werkt met math.min constructie
        end        -- einde toevoeging maxvolume
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel)); --set volume
        domoticz.log('PRG: ' ..scriptnaam .. 'Device:' .. RECEIVER_VOLUME .. ' send command Mute = Off; Set Volume = ' .. NewLevel)                                              -- debugging
Jablotron connection, Ikea
dannybloe
Re: Slider change or on/off button change
Post by dannybloe »
Can you isolate the problem and reduce it to a simple example? This script is way too long to disect and figure out what’s wrong.
@pvklink Are you sure state can have other values then "On" and "Off" ?
To debug I would add
print("***********************")
print("RECEIVER_VOLUME.state: " .. RECEIVER_VOLUME.state)
print("***********************  start DUMP")
RECEIVER_VOLUME.dump()
print("***********************  end DUMP")
just before the
