Different way of coding
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
Maybe its to much and not possible but maybe the way of coding can be different:
Now we have this
blocks[43] = {} // RPI USB USAGE
blocks[43]['width'] = 3;
blocks[43]['title'] = 'RPi CPU';
blocks[43]['image'] = 'pi3.png';
blocks[43]['switch'] = true;
But if we can code something like this
// RPI USB USAGE
blocks[43] = {} : ['width'] = 3 : ['title'] = 'RPi CPU' : ['image'] = 'pi3.png' : ['switch'] = true;
So the : i use as example to split the options for that blocks. and the ; is to end the whole line so coding will goto new blocks then
or
blocks[43] = {
     ['width'] = 3;
     ['switch'] = true
This will make the config shorter and much easier to handle when you use lot of blocks.
MiloshCZ
Re: Different way of coding
Post by MiloshCZ »
I agree. Becaouse if you need change IDX, you need change it at many places.
aiolos
Domoticz version: stable
Post by aiolos »
You can define the config like this:
blocks[43] = {
     width: 3,
     title: 'RPi CPU',
     image: 'pi3.png',
     switch: true
More information about different types of notation can be found here: https://developer.mozilla.org/en-US/doc ... th_Objects
It's basically the different ways javascript accepts object notation, or associative arrays.
These other notation can sometimes easier introduce errors in your config if you don't have a good editor that highlights the code (for example the ',' on the end of a line, instead of a ';')
Contributor to Dashticz
More on my Github profile
poudenes
Post by poudenes »
Ok cool. So this will work on the config of Dashticz as well?
aiolos wrote: Wednesday 14 March 2018 21:33 You can define the config like this:
blocks[43] = {
     width: 3,
     title: 'RPi CPU',
     image: 'pi3.png',
     switch: true
DewGew
Domoticz version: V4.10618
Post by DewGew »
poudenes wrote: Thursday 15 March 2018 10:23 Ok cool. So this will work on the config of Dashticz as well?
blocks[43] = {
     width: 3,
     title: 'RPi CPU',
     image: 'pi3.png',
     switch: true
Yes ,It does..
