Energy measurement with espeasy and pzem-004t
Alitoy
Re: Energy measurement with espeasy and pzem-004t
Post by Alitoy »
More information about the connection PZEM-004T :
tontze
Domoticz version: Beta Ch
Post by tontze »
Yeah ok, so this is not ideal for computing one devices energy usage(without braking its cable), shame :/
But, i would still prefer clamp. Using clamp i wouldnt need to take wire off from main electric box to fit it in to wire.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Alitoy
Post by Alitoy »
aleph0 wrote: Tuesday 13 March 2018 21:44 Hi ! The PZEM-004T is in the "testing" mode, and I'm pretty sure we didn't port it to the 2018-03-13 version. I might try to compile it for this version on week-end, but won't have any hardware to test it anymore :/ Or you can use our development version here https://www.letscontrolit.com/forum/vie ... =30#p21383
Hi, aleph0
Did you have time to compile a newer version? ))
tontze
Post by tontze »
gajotnt wrote: Monday 18 December 2017 12:19 Officially supported in Tasmota 5.10.0b :D
On which device name ? Just did install latest sonoff-tasmota, but cannot find pzem under devices ?
I can see it enabled in config.user, but its not in devices list ? Is it supported only through sonoff device ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
aleph0
Domoticz version: 11838
Post by aleph0 »
Alitoy wrote: Tuesday 13 March 2018 22:19 No problems ! I can test the new version.
And report the results. )))
I would be happy if you trust me to test the new 2018-03-13 version. )
Ok then ! Here it is in version 2018-03-26, tell us what ;-)
http://megzou.freeboxos.fr/photos/domot ... re.bin.zip
I expect some problems because I recompiled it against the ESPeasySoftwareSerial provided in the 2018-03-26 to avoid duplicating the libraries, but it's not the version recommended by the original author of the plugin. So let's try and see !
tontze
Post by tontze »
JST 2.5 XH 4-Pin Connector Plug
That seems to be the connector that fits to white 4pin connector on pzem.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
lyubomir
Post by lyubomir »
Today I tried to setup PZEM-004t with domoticz but without success.
I received this error in domoticz log:
2018-04-01 20:00:49.208 Error: EventSystem: in pzem1: [string "--[[Script to read infos from espeasy/pzem-00..."]:42: bad argument #1 to 'match' (string expected, got nil)
Can you please tell me how can solve the issue?
PS. I solved the issue with domoticz update.
Dim33
Post by Dim33 »
Hello everybody,
My energy measurement is operationnal by following this post and this one https://www.letscontrolit.com/forum/vie ... f=5&t=2595.
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
corederoma82
Post by corederoma82 »
Thanks for this great job,
but I don't understand how link pzem004 to the power (I mean physical connection).
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
Dim33
Post by Dim33 »
Dim33 wrote: Wednesday 29 August 2018 0:14 Hello everybody,
Can you help me ?
Thanks in advance.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.
ayasystems
Post by ayasystems »
Could be better use ESPEASY rules to split and send data to Domoticz
on Energy#Current do
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=30&nvalue=0&svalue=[Energy#Voltage]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=31&nvalue=0&svalue=[Energy#Current]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=32&nvalue=0&svalue=[Energy#ActivePower]
endon
aleph0
Post by aleph0 »
Right ! Much better solution :-) Thanks for pointing this out
sincze
Domoticz version: 2024.4
Post by sincze »
I started with this pzem-004t as well, but due to some posts regarding it's safety I switched to POW R2, however some nice things to know.
To avoid 'spamming' domoticz you could add a virtual device as well.. store the 'on change' values in that device.. and send the data (if changed) to domoticz every 30 sec or so. Great examples on the website: https://www.letscontrolit.com/forum/vie ... =50#p30912
Examples:
On System#Boot do
	TaskValueSet 5,1,0
	TaskValueSet 5,2,0
	TaskValueSet 5,3,0
	TaskValueSet 5,4,0
	TimerSet,1,30
EndOn
on Rules#Timer=1 do
	if [Calculation#Voltage]!=[Energy#Voltage]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=600&nvalue=0&svalue=[Energy#Voltage] // Voltage
		TaskValueSet 5,1,[Energy#Voltage]
	endif
	if [Calculation#Power]!=[Energy#Power]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=603&nvalue=0&svalue=[Energy#Power] // KwH.
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=608&nvalue=0&svalue=[Energy#Power] // Watt
		TaskValueSet 5,2,[Energy#Power]
	endif
	if [Calculation#Current]!=[Energy#Current]
		SendToHTTP <ipadres>,8080,/json.htm?type=command&param=udevice&idx=604&nvalue=0&svalue=[Energy#Current] // Amp
		TaskValueSet 5,3,[Energy#Current]
	endif
	TaskValueSet 5,4,[Energy#Pulses]
	TimerSet,1,30
endon
on Clock#Time=All,**:*0 do
endon
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Piacco
Post by Piacco »
I want to push the data of the pzem script into influxdb, but this doesn't work.
After som reading on the wiki I found out that i should use JSON API to update my Dummy sensors in stead of ['UpdateDevice'], how can i change this?
Domoticz wiki:
Note to Virtual / Dummy sensors: If the HTTP link or MQTT is not sending any values to the database, check the update method of your virtual sensors in your scripts. If using the ['UpdateDevice'] method, you will directly write the value to the internal database without triggering an HTTPlink or MQTT update for this sensor. Better is to use the JSON API of Domoticz and update your virtual sensors this way.
An alternative is to use ESPEASY but i don´t no how to do this :(
ayasystems wrote: Wednesday 19 September 2018 14:25 Could be better use ESPEASY rules to split and send data to Domoticz
endon
etrubin
Post by etrubin »
Piacco!
1. In ESP EASY go to Tools-Advanced and enable Rules.
2. In ESP EASY go to your pzem device set name pzem1
3. In ESP EASY set Values as on pic:
4. In ESP EASY go to Rules tab and place in text field:
on pzem1#Current do
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=30&nvalue=0&svalue=[pzem1#Voltage]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=31&nvalue=0&svalue=[pzem1#Current]
SendToHTTP 192.168.0.100,8080,/json.htm?type=command&param=udevice&idx=32&nvalue=0&svalue=[pzem1#Power]
endon
do not forget to change IP, Port and IDX of each device.
yo3hjv
Post by yo3hjv »
Hello and thank you for the nice "How to".
I did it and it is working.
Seems to work properly, I also included the ">0" mod.
I have only one observation: the "Current" value is showing the last maximum current.
I wonder if someone can help me with LUA script to make the "Current" show the "now" value of the current.
Thank you and please forgive my stupidity.
LE. I think I got it like this:
if tonumber(val_V)>1 then UpdateDev(dev_V,0,val_V)
UpdateDev(dev_A,0,val_A) end
-- if tonumber(val_A)>0 then UpdateDev(dev_A,0,val_A) end--
yo3hjv
Post by yo3hjv »
Can anyone help me to relate the costs of energy with the Elec happy switch?
I do have T1 and T2 energy on the Energy report... T1 is with Elec Happy switch OFF and T2 with switch ON?
Thank you,
Adrian
aleph0
Post by aleph0 »
Yes, it's exactly add you said
Envoyé de mon moto g(6) en utilisant Tapatalk
Dim33
Post by Dim33 »
I used the script (page 1) since one year and all is OK but I would like displayed also (as active power) :
- Reactive power (P=UxI)
- Reactive Energy consumption
Is it possible to modify the script to update two additionnal virtual sensors ?
Thanks.
NiCOOLaS
Post by NiCOOLaS »
yo3hjv wrote: Thursday 25 April 2019 4:22 Hello and thank you for the nice "How to".
Can you please show full script and how it's run :oops:
