json.html structure
YellowSky
Domoticz version: Last
json.html structure
Post by YellowSky »
Hi everyone,
i have a question about json structure.
In the wiki some of the sensor does not require nvalue=0 in the url.
For example the counter require:
/json.htm?type=command&param=udevice&idx=idx&svalue=COUNTER
But if i try:
/json.htm?type=command&param=udevice&idx=idx&svalue=COUNTER&nvalue=0
The answer is the same and the counter is updated.
Therefore why some sensors does not require this nvalue? And I wonder if there is any trouble to put one.
Indeed some others sensors must be finished by a
;0
. If not the wiki says there could be a problem of database.
Thank you
asjmcguire
Domoticz version: 3.5877
Re: JSON structure
Post by asjmcguire »
OK - first it isn't the JSON structure, JSON is something different - it's just that the URL is json.html which is a bit confusing.
svalue = STRING value
nvalue = NUMBER value
Sensors that require ;0 are devices that store more than one value - eg a Temperature and Humidity sensor, when it is updated requires TEMP;HUM and obviously it can't be a number if it has ; in it so it has to be a svalue eg: svalue=18.7;85
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
YellowSky
Re: json.htlm structure
Post by YellowSky »
Thank you for this answer.
So if i send a non expected nvalue, there is no problem?
Users browsing this forum: willemd and 1 guest
