Again, thx for the good work.
I'm really happy with this plugin
![Cool 8-)](./images/smilies/icon_cool.gif)
GrR
2018-01-16 17:56:34.995 (Sonos) Sonos mute status: 0
2018-01-16 17:56:35.015 (Sonos) Update Sonos - Control: 0 - '0'
2018-01-16 17:57:01.620 (Sonos) Calling message handler 'onCommand'.
2018-01-16 17:57:01.620 (Sonos) onCommand called for Unit 2: Parameter 'Set Level'
2018-01-16 17:57:04.927 (Sonos) Calling message handler 'onHeartbeat'.
2018-01-16 17:57:04.941 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetTransportInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><CurrentTransportState>PLAYING</CurrentTransportState><CurrentTransportStatus>OK</CurrentTransportStatus><CurrentSpeed>1</CurrentSpeed></u:GetTransportInfoResponse></s:Body></s:Envelope>
2018-01-16 17:57:04.942 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetTransportInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><CurrentTransportState>PLAYING</CurrentTransportState><CurrentTransportStatus>OK</CurrentTransportStatus><CurrentSpeed>1</CurrentSpeed></u:GetTransportInfoResponse></s:Body></s:Envelope>
2018-01-16 17:57:04.942 (Sonos) Sonos state: PLAYING
2018-01-16 17:57:04.953 (Sonos) Update Sonos - Control: 1 - '0'
2018-01-16 17:57:04.967 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>1</Track><TrackDuration>NOT_IMPLEMENTED</TrackDuration><TrackMetaData>NOT_IMPLEMENTED</TrackMetaData><TrackURI>x-rincon:RINCON_7828CA24905201400</TrackURI><RelTime>NOT_IMPLEMENTED</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
2018-01-16 17:57:05.006 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><CurrentVolume>10</CurrentVolume></u:GetVolumeResponse></s:Body></s:Envelope>
2018-01-16 17:57:05.007 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><CurrentVolume>10</CurrentVolume></u:GetVolumeResponse></s:Body></s:Envelope>
2018-01-16 17:57:05.007 (Sonos) Sonos volume: 10
2018-01-16 17:57:05.020 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMuteResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><CurrentMute>0</CurrentMute></u:GetMuteResponse></s:Body></s:Envelope>
2018-01-16 17:57:05.021 (Sonos) <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMuteResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><CurrentMute>0</CurrentMute></u:GetMuteResponse></s:Body></s:Envelope>
2018-01-16 17:57:05.021 (Sonos) Sonos mute status: 0
2018-01-16 17:57:05.032 (Sonos) Update Sonos - Control: 0 - '0'
Renaming the AwoxSMP folder did not work for me either. After a reboot, domoticz does not come back online. Only thing that helps is renaming the plugin folder and reboot.d3rax wrote: ↑Thursday 22 February 2018 21:01 Small update:
Instead of renaming the plugin folder i renamed the folder AwoxSMP in the plugin folder. I don't know what this plugin does, but after I rebooted, domoticz came back online AND the sonos plugin works! But I would like know whats going on here, hope there are some suggestions!
Changing to the last beta seems to have solved it for me.mvzut wrote:I have the same... Reverted to a previous version which doesn't give these messages.
I don't think Python plugins are intended to be added to a release. The plugin works fine by the way in the betas.leecollings wrote:Hey all,
Can anyone give a status update as to the roadmap for this eventually being added to the stable release?
Python plugins only appear when you manually add the files to the plugin folder. Usually with some sort of git pull command, this is normally explained in the corresponding forum topic. Or alternatively with the plugin manager (which is a plugin in itself). Only a few examples are included in the plugin folder by default.leecollings wrote:Okay, sorry I didnt' mean to the release of Domoticz, I meant to be included in the dropdown of hardware on the stable version. What needs to happen for that?
No, even though I am not the author I am pretty sure it will not become part of a stable version, simply because no Python plugin has ever been included in a stable version. But it's very much ready for use! Just follow the installation instructions and start using it, like I did a couple of months ago.leecollings wrote:So is this plugin ready to be pulled into the stable version of Domoticz yet, or not? You still haven't made it clear if it's ready for use or not...
The devices in the long list are there because people experienced in C coding worked on them in the past, and had them included in the main code. The Python framework was created to make it possible for more people to create plugins. There are already tens of those, all described somewhere in this forum, but none of them added to the list by default.leecollings wrote:This is why I find this confusing, so you're saying it's ready to use int he stable version.. However it has to be manually added. Why is this?
And is there a reason why it can't be automatically added to the dropdown list?
