Just a question what the best way to monitor domoticz to be offline..
since 2 days's my domoticz got offline sometimes. I'm setting up my system, so it's no problem, but i've some questions:
1. what is the best way to scan on bugs/failures [logfiles]
2. What is better for domoticz running on raspberry py to automaticly restart when crashed, watchdog or monit?
regards
leon
watchdog or monit Domoticz crashing
- lsp242
- Domoticz version: 16960
Gadget freak - Domoticz beginner - ios and android user
SweetPants
Re: watchdog or monit
domoticz.loglsp242 wrote: Sunday 11 March 2018 11:23 1. what is the best way to scan on bugs/failures [logfiles]
I use monit for years now, advantage is you can monitor/auto(re)start other services alsolsp242 wrote: Sunday 11 March 2018 11:23 2. What is better for domoticz running on raspberry py to automaticly restart when crashed, watchdog or monit?
- lsp242
Thnx..
In the wiki i can 't find to start writhing the logfile with...
sudo nano /etc/init.d/domoticz.sh
- waaren
My configfile to check domoticz with monit (in monit.d)
# Check domoticz
check process Domoticz with pidfile /var/run/domoticz.pid
start program = "/etc/init.d/domoticz.sh start"
stop program = "/etc/init.d/domoticz.sh stop"
if not exist for 8 cycles then restart
if failed
url http://xxx.xxx.xxx.xxx:domoticz-port/json.htm?type=command¶m=getversion # change to yourIP:yourPort
and content = '"status" : "OK"'
for 9 cycles then restart
if memory usage > 80% then restart
if 5 restarts within 5 cycles then alert
alert [email protected] # change to your Pushover Email adress
#endDebian buster, bullseye on RPI-4, Intel NUC.
- lsp242
Re: watchdog or monit domoticz crashing!!
I can't get the logfile written, how does the start file domoticz have to look like in domoticz.sh
Domoticz crashed again and manual start gives the folowing
and it is mutch longer, but when i restart rasp berry the system is running again..
./domoticz
2018-03-12 08:09:35.362 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-03-12 08:09:35.363 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2018-03-12 08:09:35.363 System: Raspberry Pi
2018-03-12 08:09:35.363 Startup Path: /home/pi/domoticz/
2018-03-12 08:09:35.365 Error: SQL Query("SELECT name FROM sqlite_master WHERE type='table' AND name='DeviceStatus'") : unable to open database file
2018-03-12 08:09:35.365 Error: SQL Query("CREATE TABLE IF NOT EXISTS [DeviceStatus] ([ID] INTEGER PRIMARY KEY, [HardwareID] INTEGER NOT NULL, [DeviceID] VARCHAR(25) NOT NULL, [Unit] INTEGER DEFAULT 0, [Name] VARCHAR(100) DEFAULT Unknown, [Used] INTEGER DEFAULT 0, [Type] INTEGER NOT NULL, [SubType] INTEGER NOT NULL, [SwitchType] INTEGER DEFAULT 0, [Favorite] INTEGER DEFAULT 0, [SignalLevel] INTEGER DEFAULT 0, [BatteryLevel] INTEGER DEFAULT 0, [nValue] INTEGER DEFAULT 0, [sValue] VARCHAR(200) DEFAULT null, [LastUpdate] DATETIME DEFAULT (datetime('now','localtime')),[Order] INTEGER BIGINT(10) default 0, [AddjValue] FLOAT DEFAULT 0, [AddjMulti] FLOAT DEFAULT 1, [AddjValue2] FLOAT DEFAULT 0, [AddjMulti2] FLOAT DEFAULT 1, [StrParam1] VARCHAR(200) DEFAULT '', [StrParam2] VARCHAR(200) DEFAULT '', [LastLevel] INTEGER DEFAULT 0, [Protected] INTEGER DEFAULT 0, [CustomImage] INTEGER DEFAULT 0, [Description] VARCHAR(200) DEFAULT '', [Options] TEXT DEFAULT null);") : unable to open database file
2018-03-12 08:09:35.366 Error: SQL Query("CREATE TRIGGER IF NOT EXISTS devicestatusupdate AFTER INSERT ON DeviceStatus
BEGIN
UPDATE DeviceStatus SET [Order] = (SELECT MAX([Order]) FROM DeviceStatus)+1 WHERE DeviceStatus.ID = NEW.ID;
END;
2018-03-12 08:09:35.366 Error: SQL Query("CREATE TABLE IF NOT EXISTS [EventActions] ([ID] INTEGER PRIMARY KEY, [ConditionID] INTEGER NOT NULL, [ActionType] INTEGER NOT NULL, [DeviceRowID] INTEGER DEFAULT 0, [Param1] VARCHAR(120), [Param2] VARCHAR(120), [Param3] VARCHAR(120), [Param4] VARCHAR(120), [Param5] VARCHAR(120), [Order] INTEGER BIGINT(10) default 0);") : unable to open database file
2018-03-12 08:09:35.366 Error: SQL Query("CREATE TRIGGER IF NOT EXISTS eventactionsstatusupdate AFTER INSERT ON EventActions
BEGIN
UPDATE EventActions SET [Order] = (SELECT MAX([Order]) FROM EventActions)+1 WHERE EventActions.ID = NEW.ID;
END;
2018-03-12 08:09:35.367 Error: SQL Query("CREATE TABLE IF NOT EXISTS [LightingLog] ([DeviceRowID] BIGINT(10) NOT NULL, [nValue] INTEGER DEFAULT 0, [sValue] VARCHAR(200), [User] VARCHAR(100) DEFAULT (''), [Date] DATETIME DEFAULT (datetime('now','localtime')));") : unable to open database file
2018-03-12 08:09:35.367 Error: SQL Query("CREATE TABLE IF NOT EXISTS [SceneLog] ([SceneRowID] BIGINT(10) NOT NULL, [nValue] INTEGER DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')));") : unable to open database file
2018-03-12 08:09:35.367 Error: SQL Query("CREATE TABLE IF NOT EXISTS [Preferences] ([Key] VARCHAR(50) NOT NULL, [nValue] INTEGER DEFAULT 0, [sValue] VARCHAR(200));") : unable to open database file
2018-03-12 08:09:35.367 Error: SQL Query("CREATE TABLE IF NOT EXISTS [Rain] ([DeviceRowID] BIGINT(10) NOT NULL, [Total] FLOAT NOT NULL, [Rate] INTEGER DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')));") : unable to open database file
2018-03-12 08:09:35.368 Error: SQL Query("CREATE TABLE IF NOT EXISTS [Rain_Calendar] ([DeviceRowID] BIGINT(10) NOT NULL, [Total] FLOAT NOT NULL, [Rate] INTEGER DEFAULT 0, [Date] DATE NOT NULL);") : unable to open database file
- lsp242
Re: watchdog or monit Domoticz crashing
Anybody an idea about the crash
franzelare
i used the watchdog on the domoticz.log file, but i located the file now on a ramdisk, in order not to exhaust my sd card and slow down my system
i noticed that my system crashes less after i made this change
first i created a folder to map the ramdisk to
sudo mkdir -p /media/ramdisk
than i added the creation of a ramdisk to fstab
nano /etc/fstab
none /media/ramdisk tmpfs nodev,nosuid,noexec,nodiratime,size=300M 0 0
in order to keep the file size in control i run truncate from crontab at one o'clock at night
nano crontab -e
0 1 * * * truncate -s 0 /media/ramdisk/domoticz.log
nano /etc/fstab
nano crontab -e
- lsp242
My systemen didn't crash before
Manuel schreef restart shows failure on datatabel
I truncate every night, but first crash in 2 days, restart only by Power off raspberry. Or reboot via ssh, start domototicz doesn't work while datatabel error.
