Not because it has to, but just because it is possible.
Therefore I want to see how much revenue I get from my Hotwater Solar Boiler. The picture below shows how my hotwater boiler works.
When the collector temperatur is at least 6 degrees above the boiler temperature, then pump starts and the glycol is circulating and heating the boiler. When this temperature difference is smaller then 6 degrees or even negative (Boiler hotter then the collector) the pump stops circulating.
At the moment the pump is on, I measure the temperature increase in the boiler. The temperature increase is converted to kWh. The kWh is a unit to see the revenue of my Solar Hotwater Boiler.
And the dzVents code of my script
-- dzVents script Heat-Counter - Created and run in Domoticz events
-- Time based Script to see how much revenue I get from my Solar Hotwater Boiler
-- The temperature increase is calculated and converted to kWh to make it comparable with Solar generated energy
-- The energy is counted by an Energy counter device
-- The increase of the temperature is stored in a user variable HeatBattery
--Manually create and/or define below (newly created virtual) devices and 'User Variables' by user given names
local Btemp = 62 -- Temperature of the Solar Hotwater Boiler
local Bpump = 64 -- Boiler pump activity
-- To be created virtual devices in the hardware section of Domoticz:
local idxvsec = 82 -- (1) Custom Sensor name for the 'Virtual Solarheat Energy Counter'
-- User Variables:
local battery = 'HeatBattery' -- User Variable name for the 'Heat Battery Capacity' increase °K
local VarHeat = 'Temp_Heat' -- User Variable to store temporary temperature
-- Define variables, used in this script. Don't change!!!
local new_temp
local old_temp
local delta_temp
local boiler_gain
local boiler_usage
local old_bat_value
local new_bat_value
local ScriptVersion = '0.0.1'
active = true,
logging = {
level = domoticz.LOG_DEBUG, -- Uncomment this line to override the dzVents global logging setting
marker = 'VSEB '.. ScriptVersion
timer = { 'every minute' },
devices = { Bpump }
execute = function(domoticz, triggerItem)
-- Execute every minute, but only when the boiler pump is running.
if (triggerItem.isTimer and domoticz.devices(Bpump).percentage > 0) then
domoticz.log('Script is running.', domoticz.LOG_DEBUG)
-- Get actual temperature of the Solar Hotwater Boiler
local temp = domoticz.devices(Btemp).rawData
new_temp = tonumber(temp[1])
old_temp = tonumber(domoticz.variables(VarHeat).value)
domoticz.log('New Boiler temperatuur = '.. new_temp, domoticz.LOG_DEBUG)
domoticz.variables(VarHeat).set(new_temp)
-- Check the temperature change since last update.
-- A positive number means an increase of the Boiler temperature and negative number means a decrease of the Boiler temperature
delta_temp = (new_temp - old_temp)
domoticz.log('Temperature change = '.. delta_temp ..' °K', domoticz.LOG_DEBUG)
if delta_temp <= 0 then
local boiler_usage = delta_temp
domoticz.log('Decrease of the Boiler temperature with '.. boiler_usage ..' °K', domoticz.LOG_DEBUG)
-- An increase of the Boiler temperatur. Get the last value from the HeatBattery
local boiler_gain = delta_temp
old_bat_value = tonumber(domoticz.variables(battery).value)
domoticz.log('Increase of the Boiler temperature with '.. boiler_gain ..' °K', domoticz.LOG_DEBUG)
-- Calculate the new battery value by adding the delta_temp to the previous battery value. (only increase of the battery)
new_bat_value = (old_bat_value + boiler_gain)
domoticz.variables(battery).set(new_bat_value)
-- Convert temperature increase to kWh ==> 1 °K increase = (200 L * 4.186 J * 1 °K ) / 3600 = 0.23256 kWh
local count_val = tonumber(domoticz.utils.round((new_bat_value * 0.23256),3))
domoticz.log('New counter value = '.. count_val ..' kWh', domoticz.LOG_DEBUG)
-- Energy valaue is added to the Virtual Solarheat Energy Counter
domoticz.devices(idxvsec).updateCustomSensor(count_val)
end -- delta_temp
end -- triggerItem
end -- execute
Comments and improvements are more then welcome
