DsVents global var lastupdate
Deluka
Post by Deluka »
Is it possible to get the lastupdate time of a global var
Form what i can tell reading the wiki it could be possible but i can’t get it working
Re: DsVents global var lastupdate
Yes, it is possible if you mean a global var within dzVents
Look at the A special kind of persistent variables: history = true (Historical variables API) section in
https://www.domoticz.com/wiki/DzVents:_ ... _variables
relevant scriptlines:
data = {
		myGlobalVar = { history = true, maxItems = 1 }
local myPersistentVar = domoticz.data.myGlobalVar
myPersistentVar.add("test data")
print ( 'Oldest time stamp in history: ' ..  myPersistentVar.getOldest().time.getISO())
print ( 'Last added value in history: ' ..  myPersistentVar.getLatest().data)
Deluka
Post by Deluka »
Thx and what About script level vars
Please elaborate on what your exact requirement is. A sample script might help me understand what you try to achieve
Deluka
Post by Deluka »
Its for a lux meter.
If the lux level is below or above a set level for a set time turn on or off the lights
Made this in plain lua and want to port this to dzvents
There the var is only updated once and only if the current lux is above or under the set level.
If the var is not changed for a set time the lights a turned off or on
Hope this makes sence ;)
Deluka wrote: Friday 09 March 2018 19:11 Its for a lux meter.
Could you try this and come back with your result ?
luxStateTest
	on 	= { timer = { "every minute" } 	},
	data 	= { luxLevel = { history = true, maxItems = 1, initial = "Empty" } },
	execute = function(domoticz, _)
		local currentLux = domoticz.devices("Name of your lux device").lux or 'fail'
		local luxSwitchLevel = 100   		-- change to lux value where you want to switch on
		local timeFence = 30   			-- change to how many minutes you want to wait with switching the device on / off
		local luxDependendLight = domoticz.devices("Name of your light")
		local luxState = domoticz.data.luxLevel
		local luxRecord = luxState.getLatest()
		local luxData = luxRecord.data
		local luxTime = luxRecord.time
		if currentLux ~= 'fail' then
			if currentLux >= luxSwitchLevel then
				if luxData ~= "High" then
					luxState.add("High")
			    	elseif luxTime.minutesAgo > timeFence then
					luxDependendLight.switchOff().checkFirst()
			elseif currentLux < luxSwitchLevel then
				if luxData ~= "Low" then
					luxState.add("Low")
					luxDependendLight.switchOn().checkFirst()
			print ( 'Skipped adding lux to my (Wrong lux reading) ' )
Deluka
Post by Deluka »
Thx for your help but getting a error
attempt to index local 'luxRecord' (a nil value)
Deluka wrote: Saturday 10 March 2018 7:45 Thx for your help but getting a error
Probably because it is not defined yet at the first time the script is executed.
You could try to change the luxReord line into
local luxRecord.data = luxState.getLatest().data or 'fail'
If it still gives you an error please come back with the relevant lines in your logging.
Deluka
Post by Deluka »
still getting a error
2018-03-10 18:41:28.354 dzVents: Error (2.4.1): error loading module 'lux' from file '/home/pi/domoticz/scripts/dzVents/scripts/lux.lua':
/home/pi/domoticz/scripts/dzVents/scripts/lux.lua:16: unexpected symbol near '.'
When I alter this line in
local luxRecord.date = luxState.getLatest() or 'fail'
into
local luxRecord = luxState.getLatest() or 'fail'
The scripts works perfect
Thanks for your help with my first baby steps in DZvents :D
:!: Happy to see that you managed to get it working :!:
