This is not really Toon specific, but has to do something with Domoticz. I haven't used these before, but my guess is you have to search the forums/google or the wiki from domoticz to know how to enter the correct values.michel30 wrote: ↑Thursday 08 February 2018 20:16 Hello,
I use the analog scrip for GAS and POWER, that works super in my domoticz.
Now I want to add the price and I see under the tap setup > settings > Meters/Counters the following fields: RFXMeter/Counter Dividers:
I edit the price in here, but I don't see it in my Domoticz I only see the GAS or power use.
How can I see the price in domoticz? or will this only works if you have a P1 cable?
Controlling Toon [HACKED] from Domoticz
Re: Controlling Toon [HACKED] from Domoticz
Hit the Report button where you see the the power use graphs in the top right.michel30 wrote: ↑Thursday 08 February 2018 20:16 Hello,
Created a script to read some data from the boiler unit trough toon. It reads pressure, temperature and setpoint.
If you want to try to add other variables, here's a list of available variables.
#!/usr/bin/php
<?php
/* Version 1.0 written by FunFair */
/* 06-03-2018 */
Changelog version 1.0
- first attempt to read out information from the boiler.
/* Instructions:
- Place script in Domoticz folder /home/pi/domoticz/scripts/p1_meter/ or desired folder.
- Make sure Curl is installed (sudo apt-get install php-curl).
- Make sure script is executable (chmod +x filename.php).
- All echo's are used for debugging.
- Put script in 'crontab -e' to run every minute. */
#Example crontab: (*/1 * * * * /home/pi/domoticz/scripts/cvketel/cvketel_data_json.php)
/* Set IP addresses and idx*/
$IPDomoticz = '192.168.0.200:8080'; #use 'username:password@domoticz-ip:port' in case of password protection.
$IPToon = '192.168.0.11';
$idx_pressure = 254;
$idx_temp = 255;
$idx_setpoint = 256;
/* Get current date */
$datum = date("d-m-Y");
echo "Request for FROM date: " . $datum . "\n";
echo "Now: ". date("Y-m-d H:i:s") . "\n";
/* Get Boiler Pressure from Toon */
$file_string_pressure = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=thermstat_boilerChPressure&rra=30days&readableTime=1&nullForNaN=1&from=$datum");
$parsed_json = json_decode($file_string_pressure, true);
if ( empty($parsed_json)) {
echo "Array is empty. Stop executing\n";
return;
/* Get last value of array */
$keys = array_keys($parsed_json);
end($parsed_json);
$key = key($parsed_json);
$BoilerPressureToon = $parsed_json[$key];
echo "Boiler Pressure from Toon = " . $BoilerPressureToon. " Bar";
echo "\n";
/* Get Boiler Temperature from Toon */
$file_string_pressure = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=thermstat_boilerTemp&rra=30days&readableTime=1&nullForNaN=1&from=$datum");
return;
end($parsed_json);
$BoilerTempToon = $parsed_json[$key];
echo "Boiler Temperature from Toon = " . $BoilerTempToon. " degrees Celcius";
echo "\n";
/* Get Boiler Setpoint from Toon */
$file_string_pressure = file_get_contents("http://$IPToon/hcb_rrd?action=getRrdData&loggerName=thermstat_boilerSetpoint&rra=30days&readableTime=1&nullForNaN=1&from=$datum");
return;
end($parsed_json);
$BoilerSetpointToon = $parsed_json[$key];
echo "Boiler Setpoint from Toon = " . $BoilerSetpointToon. " degrees Celcius";
echo "\n";
/* write new values to Domoticz */
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx_pressure&nvalue=0&svalue=$BoilerPressureToon");
curl_exec($WriteInitValue);
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx_temp&nvalue=0&svalue=$BoilerTempToon");
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx_setpoint&nvalue=0&svalue=$BoilerSetpointToon");
- boiler_burner_minutes-10yrdays.csv
boiler_burner_minutes-5yrhours.csv
thermstat_boilerBurnerHours-30days.csv
thermstat_BoilerBurnerHours-30days.csv
thermstat_boilerBurnerHours-year.csv
thermstat_BoilerBurnerHours-year.csv
thermstat_boilerChPressure-30days.csv
thermstat_boilerChPressure-year.csv
thermstat_boilerDhwBurnerHours-30days.csv
thermstat_BoilerDhwBurnerHours-30days.csv
thermstat_boilerDhwBurnerHours-year.csv
thermstat_BoilerDhwBurnerHours-year.csv
thermstat_boilerFailedBurnerStarts-30days.csv
thermstat_BoilerFailedBurnerStarts-30days.csv
thermstat_boilerFailedBurnerStarts-year.csv
thermstat_BoilerFailedBurnerStarts-year.csv
thermstat_boilerOpMode-30days.csv
thermstat_boilerOpMode-year.csv
thermstat_boilerPumpStarts-30days.csv
thermstat_boilerPumpStarts-year.csv
thermstat_boilerRetTemp-30days.csv
thermstat_boilerRetTemp-year.csv
thermstat_boilerSetpoint-30days.csv
thermstat_boilerSetpoint-year.csv
thermstat_boilerSuccesfulBurnerStarts-30days.csv
thermstat_BoilerSuccesfulBurnerStarts-30days.csv
thermstat_boilerSuccesfulBurnerStarts-year.csv
thermstat_BoilerSuccesfulBurnerStarts-year.csv
thermstat_boilerTemp-30days.csv
thermstat_boilerTemp-year.csv
thermstat_dhwBurnerStarts-30days.csv
thermstat_dhwBurnerStarts-year.csv
thermstat_heatingFactor-30days.csv
thermstat_heatingFactor-year.csv
thermstat_internalSetpoint-30days.csv
thermstat_internalSetpoint-year.csv
thermstat_longTermOffset-30days.csv
thermstat_longTermOffset-year.csv
thermstat_outsideRate-30days.csv
thermstat_outsideRate-year.csv
thermstat_programState-30days.csv
thermstat_programState-year.csv
thermstat_realTemps-30days.csv
thermstat_realTemps-year.csv
thermstat_setpoint-30days.csv
thermstat_setpoint-year.csv
i red this topic, read the wiki and domoticaforum.eu
My toon is rooted and dont want to use it with Eneco.
For the wiki i need to use my username and password from my eneco (dont have)
In this and the other topic i saw many scripts, but now i am confused.
Where do i start to use my toon in Domoticz?
The default domoticz plugin doesnt work anymore.maomanna wrote: ↑Wednesday 07 March 2018 22:09 i red this topic, read the wiki and domoticaforum.eu
Use the LUA scripts in this thread.
The php scripts are for reading extra information from toon.
I put the lua scripts in event, but after that, my domoticz crashed. after restart, the same story. disable the script, then it runs ok.
1. Toon as device:
and Toonstates as Time
I changed a line to json = assert(loadfile "/dev-domoticz/scripts/lua/JSON.lua")() -- For Raspberry cause i'm on ubuntu 16.04
are there newer scripts?
EDIT:
Guess i forgot local json = assert(loadfile "/home/maes/domoticz/scripts/lua/JSON.lua")() -- For Linux
Not helping
Line of error: Error: EventSystem: in Toonstates: [string "-- Time script runs every minute, intended to..."]:26: attempt to index global 'jsonThermostatInfo' (a nil value)
I believe my toon is on softwareversion 3.7.x I'll update it when I get home.
1. Toon as device:
-- Script used for Toon Thermostaat utility device, upon changing temp in Domoticz, temperature is sent to Toon.
ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
ToonIP = uservariables['UV_ToonIP']
for deviceName,deviceValue in pairs(devicechanged) do
if (deviceName == ToonThermostatSensorName) then
if uservariables['UV_ToonChangedByDomoticz'] == 1 then
commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
SetPoint = otherdevices_svalues[ToonThermostatSensorName]
ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
print('Setting Toon setpoint to '.. SetPoint)
commandArray['OpenURL'] = ToonCommand
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
ToonScenesSensorName = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
DomoticzIP = uservariables['UV_DomoticzIP']
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
jsonThermostatInfo = json:decode(ThermostatInfo)
currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentProgramState = tonumber(jsonThermostatInfo.programState)
currentActiveState = tonumber(jsonThermostatInfo.activeState)
currentNextTime = jsonThermostatInfo.nextTime
currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
-- Update the thermostat sensor to current setpoint
if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
-- Update the temperature sensor to current room temperature
if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
print('Updating the temperature sensor to new value: ' ..currentTemperature)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
-- Update the toon scene selector sensor to current program state
CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
if currentActiveState == -1 then currentActiveState = '50' -- Manual
elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
elseif currentActiveState == 1 then currentActiveState = '30' -- Home
elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
elseif currentActiveState == 3 then currentActiveState = '10' -- Away
if CurrentToonScenesSensorValue ~= currentActiveState then -- Update toon selector if it has changed
print ('Updating Toon Scenes selector')
commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
-- Updates the toon auto program switch
CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
if currentProgramState == 0 then currentProgramState = '10' -- No
elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
print ('Updating Toon Auto Program selector')
commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
-- Updates the toon program information text box
CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
EDIT:
Not helping
- gijsje
- Domoticz version: Stable
I have the gas and electric script working now to get this data into domoticz.
I only have a strange issue.
The logging of the data stops at 17:00 and starts again at 00:00
I have the script running on the synology and if i look at the output there it is working fine and it can see the data in the log file but it is not comming into domoticz.
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
Seems the low tariff counter is not added correctly or something? Though 'laagtarief' starts after 22 oclock instead of 17 I think. Which script are you using? The last one I have posted?gijsje wrote: ↑Thursday 08 March 2018 19:41 I have the gas and electric script working now to get this data into domoticz.
- gijsje
I guess so
I have tried so many i lost count
/* Version 1.0 written by Ierlandfan */
/* Version 1.0 modified by DennisD */
/* Version 2.0 rewritten by FunFair */
/* Version 2.1 update by FunFair */
/* Version 3.0 modified by glsf91 for using RRD */
/* Version 3.1 update by FunFair */
/* 05-03-2018 */
Ifyou enable 'energieverbruik' does the graph show an increase in watt/h?gijsje wrote: ↑Friday 09 March 2018 20:56 I guess so
/* Version 1.0 written by Ierlandfan */ /* Version 1.0 modified by DennisD */ /* Version 2.0 rewritten by FunFair */ /* Version 2.1 update by FunFair */ /* Version 3.0 modified by glsf91 for using RRD */ /* Version 3.1 update by FunFair */ /* 05-03-2018 */
The value that is not updating is the current power usage in watt. I don't know why it stops doing this. If the counter doesn't update as well it looks like there is no connection to update the values or something... Maybe a dumb question, but is the wifi turned off during this time?
And what does the graph on the toon unit show?
- gijsje
How could i enable this?
On the Toon the graph is ok
Wifi is also working ok as in the the log of the nas i can see the data asked from the Toon.
I also have a Pi USb and there it works ok.
The night tarif is from 23:00 until 07:00 here and with the USB P1 it is ok.
- gijsje
Something strange i see now.
If i look at the data generated from the script on my nas, it makes a txt file every minut when enabled.
The time for the file itself for this on is 10-3-2018 10:11
But when i look in the file i see this
The time stamp there is 17:11
So it is off by a few hours.
The time on the nas is set ok.
So i have no clue where is comes from as the time on the toon is also ok
Request for FROM date: 10-03-2018
Now: 2018-03-10 17:11:03
Electricity Usage Toon = 400 Watt
Electricity Production Toon = 0 Watt
Electricity LT counter from Toon = 9530159 Wh
Electricity NT counter from Toon = 8221494 Wh
Electricity production counter LT from Toon = 13 Wh
Electricity production counter NT from Toon = 50 Wh
"status" : "OK",
"title" : "Update Device"
Updated the script again. Re-added the comparisments with domoticz db values.
When I updated my Toon to the latest version, for some reason domoticz wrote a value into the trillions while Toon was updating/rebooting/reconnecting and therefore I had to restore the database.
See new versions attached.
- p1_meter_v3.1.zip
- (5.32 KiB) Downloaded 134 times
That's strange. Maybe a timezone issue?gijsje wrote: ↑Saturday 10 March 2018 10:15 Something strange i see now.
But when i look in the file i see thisThe time stamp there is 17:11Code: Select all
Request for FROM date: 10-03-2018 Now: 2018-03-10 17:11:03 Electricity Usage Toon = 400 Watt Electricity Production Toon = 0 Watt Electricity LT counter from Toon = 9530159 Wh Electricity NT counter from Toon = 8221494 Wh Electricity production counter LT from Toon = 13 Wh Electricity production counter NT from Toon = 50 Wh { "status" : "OK", "title" : "Update Device" }
What happens if you type in "date" on your NAS? What time is it reporting?
My RPi reports: Mon 12 Mar 13:52:15 CET 2018 which is correct.
My Synology NAS reports the same.
Although the script uses only the date and not the time.
Maybe glsf91 can help?
- gijsje
There is a difference there
I have found that the time/date on the toon is Mon Mar 12 14:42:57 UTC 2018
The time and date on the nas is Mon Mar 12 15:43:34 CET 2018
i made a topic on the domoticaforum how to change the time zone and time
That is also the case with my Toon.
In the end it is the same time. CET = UTC +1 (wintertijd)
- gijsje
If i look at this line
and change it to to add the time zone i do get
So i do not know where this date is coming from.
Any suggestion were it is getting the date time from?
$datum = date("d-m-Y e");
Request for FROM date: 13-03-2018 Asia/Taipei
I think the timezone settings on your Synology NAS are wrong.gijsje wrote: ↑Monday 12 March 2018 23:58 If i look at this lineand change it toCode: Select all
to add the time zone i do getCode: Select all
So i do not know where this date is coming from.Code: Select all
So when it's a new day in asia, it's still an old day in the Netherlands and the script is asking for data from a day that doesn't excist yet.
On your NAS, go to Control Panel --> Regional Options (somewhere in the middle) and change it to (GMT+01:00 Amsterdam)
- gijsje
This is setup ok
Could the time of the php installed on the nas be different?
I have no idea if this one is coming from the nas clock but i guess so.
I've ran the date script on my synology and I get the same output.
Request for FROM date: 15-03-2018 Asia/Taipei
Now: 2018-03-15 22:19:26
But when I enter 'date' in the prompt it sais: Thu Mar 15 15:19:41 CET 2018
Change your code to:
date_default_timezone_set("Europe/Amsterdam");
echo "Timezone " . date_default_timezone_get() . "\n";
