Zipato keypad: disarm without rfid/pin
heggink
Domoticz version: 12451
Post by heggink »
Fellow Domoticz users,
I use my zipato keypad to arm/disarm my alarm which all works really well.
Next step is to automate switching off the alarm as soon as one of the family members enters the house by detecting a mobile phone accessing the wifi.
Only challenge is that, whilst the alarm gets disarmed, the keypad alarm level is still "On" until you use the RFID tag or a pin to switch it off :-(.
Has anyone successfully managed to change the keypad state through a blocky/lua? I tried blocky but it did not work.
Thanks for helping!
H
DASHTICZ 🙃
P1 meter & solar panel
maomanna
Re: Zipato keypad: disarm without rfid/pin
Post by maomanna »
Can you switch it with json?
heggink
Post by heggink »
not tried Just yet but will do soon
DASHTICZ 🙃
ben92
Post by ben92 »
i think u cant because its a battery node.
But you can work around your problem by creating a virtual switch that will be ON / OFF when you activated or deactivated by RFID.
it'll be this switch that you should use in your alarm activation scripts
Home with RFID -> Zipato ON -> virtual switch ON
Away with RFID -> Zipato OFF -> virtual switch OFF
Phone detected -> virtual switch OFF -> dont care of Zipato state
hennykarreman
Post by hennykarreman »
Ik wil Zipato keypad gebruiken voor een Domticz alarm systeem.
Nu zie ik bij Robbshop dat enkel gebruikercode zonder tag niet ondersteund wordt in Domoticz.
Wat betekent dat precies? Dat je alleen een code kan gebruiken als die gekoppeld is aan een tag?
Henny
