On this forum I've found a (doorbell) BASH-script that will capture an image from my camera and send it through Telegram to our mobiles.
#!/bin/sh
SnapFile="/var/tmp/camsnapshot.jpg"
# Get snapshot via Domoticz server
wget -O $SnapFile "http://**IP_ADDRESS_DOMOTICZ**:**PORT**/camsnapshot.jpg?idx=1"
# Send Telegram message with image
curl -s -X POST "https://api.telegram.org/bot**TOKEN**/sendPhoto" -F chat_id=-**CHATID** -F photo="@$SnapFile" -F caption="Er staat iemand aan de deur!"
# Remove Image
/bin/rm $SnapFileI've created a blocky-event that should run the script Whenever I press the doorbell button in Domoticz, the script will run and the doorbell will ring. Whenever I use the doorbell the script isn't run and the doorbell will ring like expected. All devices are running the latest stable versions. When am I doing wrong or have I forgotten to set?
It has worked like I wanted it, but after a crash all settings where lost since I haven't made notes or backups
