I would like to create a plugin to support the following virtual device
A device I am calling "fake-o-stat" - I need a SINGLE device that can take a setpoint, return a temperature and (for now) optionally have a "demandHeat" function if current temp < setpoint (with some maths to adjust for tolerance)
The "fake-o-stat" would allow you to map other domoticz devices to the various input/out like this:
Device - fake-o-stat setpoint = Domoticz IDX of a thermostat setpoint device
Device - fake-o-stat temperature = Domoticz IDX of a temperature device
Device - fake-o-stat demandHeat = Domoticz IDX of a switch.
Why? - Because I have a hybrid solution for a couple of rooms - a heater controlled by a zwave plug, a temperature sensor from mysensors and I want the whole thing to be represented to alexa (via the EXCELLENT controlicz) as a temperature device - so voice control can say "what is the study temperature", "set study temperature to 22 degrees"
The problem - device type thermostat setpoint doesn't have current temperature, device type temperature doesn't support setpoint.
I have faked it bu having two devices (one called study temperature, one called study target) and presenting both to alexa - but it's not ideal (on has not met high WAF (wife acceptance factor) - so thinking of other approaches
I see in other threads some looking for the dummy device "thermostat setpoint" to have a current temperature attribute, this is the same thing approached from a different angle.
Thoughts, insights and suggestions welcomes.
Can we create new or custom device types via python plugin (thermostat setpoint + temperature + demandHeat)
- Domoticz version: current
Re: Can we create new or custom device types via python plugin (thermostat setpoint + temperature + demandHeat)
Have a look at the Smart Virtual Thermostat plugin and go from there?
- Dnpwwo
@malarcy,
The Python plugins can't really new device types because the user interface wouldn't know what to do with them (the plugins wouldn't care because its just a 'Type' and 'SubType' as far as they are concerned).
The current devices have a lot of hardcoded logic in the web pages which you would need to uplift.
I've the same idea for the set point device. Would you found the solution is more butifull like SetPoint+Temperature device?malarcy wrote: ↑Sunday 14 January 2018 21:37 I would like to create a plugin to support the following virtual device
