Hi, i need script to get sum "PowerMeter1"+ "PowerMeter2" and send result to virtual incremental counter.
Two power meters(incremental) data need to put together.
Please help.
How to get summary power consumption from different counters ?
Re: How to get summary power consumption from different counters ?
working for me
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- Domoticz IDX and names of the needed devices
local DeviceName1 = "HallBathroom"
local DeviceName2 = "KitchenWallPlug"
local DeviceName3 = "LogiaChildroomWallPlug"
local DeviceName4 = "Appliance"
local DeviceName5 = "LivingroomChildroom"
local ConsumptionIDX = 399 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "Total" -- Name of the energy device that shows calculated Consumption
-- Script parameters
Energy1 = 0 -- in Watt hours
Power1 = 0 -- in Watts
Energy2 = 0 -- in Watt hours
Power2 = 0 -- in Watts
Energy3 = 0 -- in Watt hours
Power3 = 0 -- in Watts
Energy4 = 0 -- in Watt hours
Power4 = 0 -- in Watts
Energy5 = 0 -- in Watt hours
Power5 = 0 -- in Watts
Energy6 = 0 -- in Watt hours
Power6 = 0 -- in Watts
EnergyConsumption = 0 -- in Watt hours
PowerConsumption = 0 -- in Watts
Debug = "NO" -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
Power1, Energy1 = otherdevices_svalues[DeviceName1]:match("([^;]+);([^;]+)")
if Debug=="YES" then
print(" ----- ".. DeviceName1 .. "Power = " .. Power1 .. " W");
print(" ----- ".. DeviceName1 .. "Energy = " .. Energy1 .. " Wh");
Power2, Energy2 = otherdevices_svalues[DeviceName2]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName2 .. "Power = " .. Power2 .. " W");
print(" ----- ".. DeviceName2 .. "Energy = " .. Energy2 .. " Wh");
Power3, Energy3 = otherdevices_svalues[DeviceName3]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName3 .. "Power = " .. Power3 .. " W");
print(" ----- ".. DeviceName3 .. "Energy = " .. Energy3 .. " Wh");
Power4, Energy4 = otherdevices_svalues[DeviceName4]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName4 .. "Power = " .. Power4 .. " W");
print(" ----- ".. DeviceName4 .. "Energy = " .. Energy4 .. " Wh");
Power5, Energy5 = otherdevices_svalues[DeviceName5]:match("([^;]+);([^;]+)")
print(" ----- ".. DeviceName5 .. "Power = " .. Power5 .. " W");
print(" ----- ".. DeviceName5 .. "Energy = " .. Energy5 .. " Wh");
-- Calculate consumption
PowerConsumption = Power1 + Power2 + Power3 + Power4 + Power5
print(" ----- PowerConsumption = " .. PowerConsumption .. " W");
EnergyConsumption = Energy1 + Energy2 + Energy3 + Energy4 + Energy5
print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
-- Update comsumption device in Domoticz
if devicechanged[DeviceName1] or devicechanged[DeviceName2] or devicechanged[DeviceName3] or devicechanged[DeviceName4] or devicechanged[DeviceName5] then
update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
you should use for statementderrij wrote:working for me
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua ---------------------------------------------------------------------------------------------------------- -- Domoticz IDX and names of the needed devices ---------------------------------------------------------------------------------------------------------- local DeviceName1 = "HallBathroom" local DeviceName2 = "KitchenWallPlug" local DeviceName3 = "LogiaChildroomWallPlug" local DeviceName4 = "Appliance" local DeviceName5 = "LivingroomChildroom" local ConsumptionIDX = 399 -- IDX of the energy device that shows calculated Consumption local ConsumptionDeviceName = "Total" -- Name of the energy device that shows calculated Consumption ---------------------------------------------------------------------------------------------------------- -- Script parameters ---------------------------------------------------------------------------------------------------------- Energy1 = 0 -- in Watt hours Power1 = 0 -- in Watts Energy2 = 0 -- in Watt hours Power2 = 0 -- in Watts Energy3 = 0 -- in Watt hours Power3 = 0 -- in Watts Energy4 = 0 -- in Watt hours Power4 = 0 -- in Watts Energy5 = 0 -- in Watt hours Power5 = 0 -- in Watts Energy6 = 0 -- in Watt hours Power6 = 0 -- in Watts EnergyConsumption = 0 -- in Watt hours PowerConsumption = 0 -- in Watts Debug = "NO" -- Turn debugging on ("YES") or off ("NO") ---------------------------------------------------------------------------------------------------------- -- Lua Functions ---------------------------------------------------------------------------------------------------------- function update(device, id, power, energy, index) commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy} end ---------------------------------------------------------------------------------------------------------- -- CommandArray ---------------------------------------------------------------------------------------------------------- commandArray = {} Power1, Energy1 = otherdevices_svalues[DeviceName1]:match("([^;]+);([^;]+)") if Debug=="YES" then print(" ----- ".. DeviceName1 .. "Power = " .. Power1 .. " W"); print(" ----- ".. DeviceName1 .. "Energy = " .. Energy1 .. " Wh"); end Power2, Energy2 = otherdevices_svalues[DeviceName2]:match("([^;]+);([^;]+)") if Debug=="YES" then print(" ----- ".. DeviceName2 .. "Power = " .. Power2 .. " W"); print(" ----- ".. DeviceName2 .. "Energy = " .. Energy2 .. " Wh"); end Power3, Energy3 = otherdevices_svalues[DeviceName3]:match("([^;]+);([^;]+)") if Debug=="YES" then print(" ----- ".. DeviceName3 .. "Power = " .. Power3 .. " W"); print(" ----- ".. DeviceName3 .. "Energy = " .. Energy3 .. " Wh"); end Power4, Energy4 = otherdevices_svalues[DeviceName4]:match("([^;]+);([^;]+)") if Debug=="YES" then print(" ----- ".. DeviceName4 .. "Power = " .. Power4 .. " W"); print(" ----- ".. DeviceName4 .. "Energy = " .. Energy4 .. " Wh"); end Power5, Energy5 = otherdevices_svalues[DeviceName5]:match("([^;]+);([^;]+)") if Debug=="YES" then print(" ----- ".. DeviceName5 .. "Power = " .. Power5 .. " W"); print(" ----- ".. DeviceName5 .. "Energy = " .. Energy5 .. " Wh"); end -- Calculate consumption PowerConsumption = Power1 + Power2 + Power3 + Power4 + Power5 if Debug=="YES" then print(" ----- PowerConsumption = " .. PowerConsumption .. " W"); end EnergyConsumption = Energy1 + Energy2 + Energy3 + Energy4 + Energy5 if Debug=="YES" then print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh"); end -- Update comsumption device in Domoticz if devicechanged[DeviceName1] or devicechanged[DeviceName2] or devicechanged[DeviceName3] or devicechanged[DeviceName4] or devicechanged[DeviceName5] then update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1) end return commandArray
I created a dummy device. The new device has a button: create virtual sensor. What type of virtual sensor should be selected to work on the script.
Thanks.
Thanks.
- Domoticz version: 4.97
Hello derrij,
i would like to make a calculation from 2 counters
1 meter "gas quantity" (m³)
2 counter "Condensate quantity" (liters)
3 Counters "fuel efficiency" (%)
From the counters, the following calculation would have to be made:
"Condensate quantity" divided ("gas quantity" multiplied by 1.63) multiplied by 100 = .....%
Can you help me?
Grettings Berno
Can you help me?
Grettings Berno
don't drink whisky without water and don't drink water without whisky...
