Present Detection error in script
Btje
Post by Btje »
I'm trying to run the present detection script provided by domoticz : http://www.domoticz.com/wiki/Presence_detection
It always starts with the phone is offline when running in a putty window:
command: python check_device_online.py 192.168.1.50 44 10 30
and this is the response:
20:56:36- script started.
20:56:36- according to domoticz, 192.168.1.50 is offline
20:56:37- 192.168.1.50 offline, waiting for it to come back
20:57:00- 192.168.1.50 online, tell domoticz it's back
File "check_device_online.py", line 117, in <module>
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=On&level=0" + "&passcode=" + domoticzpasscode)
File "check_device_online.py", line 96, in domoticzrequest
response = urllib2.urlopen(request)
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 435, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 548, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 473, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 400: Bad Request
The logfile states it is offline and then online:
19:48:26- script started.
19:48:26- according to domoticz, 192.168.1.50 is offline
19:48:43- 192.168.1.50 offline, waiting for it to come back
19:49:29- 192.168.1.50 online, tell domoticz it's back
Question is why is it offline and then online and where does the error come from.The switches in domoticz are not turned on.
blauwebuis
Domoticz version: current
Re: Present Detection error in script
Post by blauwebuis »
Btje
Post by Btje »
Tried changing the python version and this did not help.
